    Debian 9 as VM, running npm start makes it all "freeze" but...
    11 Posts 3 Posters 3.9k Views 3 Watching
      Quoting @THeStigh from private message
      THeStigh
      After messing a lot, I kind of figured it out. I needed to install Linux for Windows, and got it all up ready to run.
      Though, I havent figured out the microphone yet, but I cant either get the gif to show from Helly Lucy.
      How should the entry in config.js look like?
      module: ‘Hello-Lucy’,
      position: ‘upper_third’
      just gives a black screen…
      T THeStigh
      But I would like to move my PC to a linux installation, find it fun to play with, but what do you suggest? Ubuntu or Debian? 32 or 64 bit? I plan to mostly play with MagicMirror
      • T Offline
        THeStigh @Mykle1
        @mykle1
        I created the config.js and still it just stops after stating.
        I’ve verified it doesn’t freeze, as I can use Alt-Tab.
        See the Electron in the upper taskbar? But there is nothing opened.
        Again, can this be a VM and/or 64 bit issue?
        Mykle1M ? 2 Replies Last reply Reply Quote 0
          My friend, you have to follow the readme in Hello-Lucy
          1. The gif from Hello-Lucy is displayed by MMM-EasyPix so you have to install that (It’s in the readme)
          2. There is no entry for Hello-Lucy in the config.js. Lucy is an enhancement to MMM-voice so you’ll need your entry for MMM-voice
          3. I’ve never used Debian so I can’t say about that
          4. I use ubuntu 16.04LTS 64 bit
          • T Offline
            THeStigh @Mykle1
            @mykle1
            If there is any excuse… It’s 03:30 AM.
            But still; the config.js in the Debian 9 installation is clean, it is default.
            So that is not the issue (regarding the message you pasted; that is for me running Linux through Windows :) )
              Mykle1 Project Sponsor Module Developer @THeStigh
              @thestigh said in Debian 9 as VM, running npm start makes it all "freeze" but...:
              I’ve never used a VM environment. I strictly run ubuntu on all my machines except for 1 Pi mirror It’s definitely NOT a 64 bit issue.
                You copied and renamed it?
                So that is not the issue (regarding the message you pasted; that is for me running Linux through Windows )
                I don’t know about running Linux through windows because I don’t do that.
                  Go to sleep. This will all be here tomorrow. I promise. :-)
                  • T Offline
                    THeStigh @Mykle1
                    @mykle1 Could it be the output is wrong? Meaning - trying to output to a different display?
                      A Former User @THeStigh
                      @thestigh
                      I’m not sure this is exact solution. However,
                      Some system (like ATB) has an issue to execute Electron of MM (after 2.x - new GPU acceleration).
                      You can run MM as serveronly mode to use your existing Chrome Browser instead Electron.
                      You can make a script to execute MM serveronly mode and Chrome to display it.
                      Or you can try this to disable GPU.
                      npm start -- --disable-gpu
