    Debian 9 as VM, running npm start makes it all "freeze" but...
    11 Posts 3 Posters 3.7k Views 3 Watching
    • T Offline
      THeStigh @Mykle1
      @mykle1
      I created the config.js and still it just stops after stating.
      I’ve verified it doesn’t freeze, as I can use Alt-Tab.
      See the Electron in the upper taskbar? But there is nothing opened.
      Again, can this be a VM and/or 64 bit issue?
      Mykle1M ? 2 Replies Last reply Reply Quote 0
        My friend, you have to follow the readme in Hello-Lucy
        1. The gif from Hello-Lucy is displayed by MMM-EasyPix so you have to install that (It’s in the readme)
        2. There is no entry for Hello-Lucy in the config.js. Lucy is an enhancement to MMM-voice so you’ll need your entry for MMM-voice
        3. I’ve never used Debian so I can’t say about that
        4. I use ubuntu 16.04LTS 64 bit
        • T Offline
          THeStigh @Mykle1
          @mykle1
          If there is any excuse… It’s 03:30 AM.
          But still; the config.js in the Debian 9 installation is clean, it is default.
          So that is not the issue (regarding the message you pasted; that is for me running Linux through Windows :) )
            Mykle1 Project Sponsor Module Developer @THeStigh
            @thestigh said in Debian 9 as VM, running npm start makes it all "freeze" but...:
            I’ve never used a VM environment. I strictly run ubuntu on all my machines except for 1 Pi mirror It’s definitely NOT a 64 bit issue.
              You copied and renamed it?
              So that is not the issue (regarding the message you pasted; that is for me running Linux through Windows )
              I don’t know about running Linux through windows because I don’t do that.
                Go to sleep. This will all be here tomorrow. I promise. :-)
                • T Offline
                  THeStigh @Mykle1
                  @mykle1 Could it be the output is wrong? Meaning - trying to output to a different display?
                    A Former User @THeStigh
                    @thestigh
                    I’m not sure this is exact solution. However,
                    Some system (like ATB) has an issue to execute Electron of MM (after 2.x - new GPU acceleration).
                    You can run MM as serveronly mode to use your existing Chrome Browser instead Electron.
                    You can make a script to execute MM serveronly mode and Chrome to display it.
                    Or you can try this to disable GPU.
                    npm start -- --disable-gpu
