    Need help with a module
    5 Posts 3 Posters 1.4k Views 2 Watching
    • E Offline
      esim
      could someone please tell me what is wrong here:
              module: 'MMM-NesteBussAtB',
              position: 'upper_third',
                  showIcon: true, // Bus icon in front of row
                  showNumber: true, // Bus number
                  showFrom: true, // Bus stop name
                  showTo: true, // Bus destination
                  showMin: true, // "min" text after minutes
                  size: "medium", // Text size, for example small, medium or large
                  stopIds: [16011496, 16010496], // See https://www.atb.no/holdeplassoversikt/
                  maxCount: 2, // Max number of next buses per route
                  maxMinutes: 45, // Do not show buses more then this minutes into the future
                  stacked: true // Show multiple buses on same row, if same route and destination
      because i can’t get it to work.
      • E Offline
        esim
        I solved it my self :-) using some very old programming knowledge.
        module: ‘MMM-NesteBussAtB’,
        position: ‘upper_third’,
        showMin: true, // “min” text after minutes
        size: “medium”, // Text size, for example small, medium or large
          sdetweil @esim
          @esim put that in your config.js,
          Then run
          node tests/configs/check_config.js
          From the MagicMirror folder. Find and fix the errors, starting at the top
          • E Offline
            esim
            • E Offline
              esim @sdetweil
              @sdetweil thanks, a very nice tip that one.
              • bheplerB Offline
                bhepler Module Developer
                Please use the Markdown features of the board when posting code or logs.
