Need help with a module
5 Posts 3 Posters 1.3k Views 2 Watching
  • E Offline
    esim
    could someone please tell me what is wrong here:
            module: 'MMM-NesteBussAtB',
            position: 'upper_third',
                showIcon: true, // Bus icon in front of row
                showNumber: true, // Bus number
                showFrom: true, // Bus stop name
                showTo: true, // Bus destination
                showMin: true, // "min" text after minutes
                size: "medium", // Text size, for example small, medium or large
                stopIds: [16011496, 16010496], // See https://www.atb.no/holdeplassoversikt/
                maxCount: 2, // Max number of next buses per route
                maxMinutes: 45, // Do not show buses more then this minutes into the future
                stacked: true // Show multiple buses on same row, if same route and destination
    because i can’t get it to work.
    S 1 Reply Last reply Jan 10, 2019, 4:58 PM Reply Quote 0
    • E Offline
      esim
      I solved it my self :-) using some very old programming knowledge.
      module: ‘MMM-NesteBussAtB’,
      position: ‘upper_third’,
      showMin: true, // “min” text after minutes
      size: “medium”, // Text size, for example small, medium or large
        sdetweil @esim
        @esim put that in your config.js,
        Then run
        node tests/configs/check_config.js
        From the MagicMirror folder. Find and fix the errors, starting at the top
        E 1 Reply Last reply Jan 10, 2019, 5:19 PM Reply Quote 0
        • E Offline
          esim
          • E Offline
            esim @sdetweil
            @sdetweil thanks, a very nice tip that one.
              bhepler Module Developer
              Please use the Markdown features of the board when posting code or logs.
