Unsolved HELP to use a cam with MM PLEASE
@shbatm
i try to use mjpg_streamer :
$ mjpg_streamer -o “output_http.so -w ./www” -i “input_uvc.so -f 1 -q 75 -y”but i have this error : bind:Address already in use.
also : Innappropriate ioctl for device (25)help!
@axel said in HELP to use a cam with MM PLEASE:
The default port is the same as the Mirror, 8080. Try adding
-p 8081
to your command to change the port. -
This post is deleted! -
@shbatm
it works well but now i tried To start mjpg on boot in vain. I used the crontab but how To write it with the options?? -
@axel - Create a script with your command, name it something obvious like
startcam.sh
. Make it executable withchmod +x startcam.sh
and then use pm2 to autostart and maintain the script:pm2 start startcam.sh
When you’re satisfied with pm2’s handling, save the state:pm2 save
In the future, please use the markdown features of the board when posting code & logs.
@bhepler
i did it but the status is not online but stopped. After a moment, the status changed To errored!! Help please… -
@axel - Okay. Let’s skip PM2 for now and just concentrate on getting your script running.
Edit the
startcam.sh
script and paste in the mjpg_streamer command:
mjpg_streamer -o “output_http.so -w ./www” -i “input_uvc.so -f 1 -q 75 -y” -p 8081
Once you have the script file to where it’s only that command, you can try to run that script manually by typing
./startcam.sh
. That should be the equivalent of typing the command in yourself.Try that and let us know how it goes.
@bhepler
Ok i can run manually the script.
and now?
@axel he said
you can try to run that script manually by typing ./startcam.sh.
he left off that you need to mark the script as executable
chmod +x ./startcam.sh
i did it before 😉
