    HELP to use a cam with MM PLEASE
    19 Posts 6 Posters 8.8k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @axel
      @axel
      I would go with MMM-SleepWake because it’s a newer module and it’s fully supported by our friend, @sdetweil
        axel
        thank toi guys for your answers but what i want is to see my usb cam in live on the mirror! is there a module for that please?
        ? S 2 Replies Last reply Reply Quote 0
          A Former User @axel
          @axel
          If your webcam has IP or URL address to stream video output, MMM-RTSP… or some iFrame modules could work.
            shbatm Module Developer @axel
            @axel said in HELP to use a cam with MM PLEASE:
            If you can get an RTSP stream URL from your IP camera you can use my module: MMM-RTSPStream. Use the develop branch right now–and search this forum if you’re having issues getting it to work.
            If you want to stream your USB camera by hooking it up to the Pi, you can look at something like mjpg-streamer (Google ‘OctoPrint mjpg-streamer setup’ for some good guides) and then use MMM-iframe to show the image.
            A 1 Reply Last reply Reply Quote 1
              axel @shbatm
              @shbatm
              i try to use mjpg_streamer :
              $ mjpg_streamer -o “output_http.so -w ./www” -i “input_uvc.so -f 1 -q 75 -y”
              but i have this error : bind:Address already in use.
              also : Innappropriate ioctl for device (25)
              help!
                The default port is the same as the Mirror, 8080. Try adding -p 8081 to your command to change the port.
                A 2 Replies Last reply Reply Quote 0
                  axel @shbatm
                    axel @shbatm
                    @shbatm
                    it works well but now i tried To start mjpg on boot in vain. I used the crontab but how To write it with the options??
                    • bheplerB Offline
                      bhepler Module Developer @axel
                      @axel - Create a script with your command, name it something obvious like startcam.sh. Make it executable with chmod +x startcam.sh and then use pm2 to autostart and maintain the script: pm2 start startcam.sh When you’re satisfied with pm2’s handling, save the state: pm2 save
                      In the future, please use the markdown features of the board when posting code & logs.
                        axel @bhepler
                        @bhepler
                        i did it but the status is not online but stopped. After a moment, the status changed To errored!! Help please…
