MMM-Fuel
@strawberry-3-141
I reinstalled the mirror and installed the module again, however it stopped working. (It’s shows only “loading”) I’m using the same config file as before. Every module beside this working :/ Is it possible, that there is a bug in the module? -
@rakostamas which branch are you using? Develop or master? On develop I’m working on a refactoring, so bugs are definetly possible. Master was probably not changed in a year.
Any errors in the console?
Did you install the dependencies?
Can you post your confit part without the API key and a bit modified gps position? -
@strawberry-3-141
here is my config:{ module: "MMM-Fuel", position: "top_right", config: { provider: "spritpreisrechner", lat: 47.041194, lng: 15.453377, types: ["e5", "diesel"], radius: 6, max: 4, sortBy: "e5", open: true, } },
The mirror only displays the header and loading…
I have installed it in the following way:
@rakostamas run
npm start dev
to open the development screen, select the console tab… are there any errors (in red) shown?
Yes it seems :D -
wrong folder… in MagicMirror always for start. not module folder
0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ] 2 info using npm@6.6.0 3 info using node@v9.11.2 4 verbose stack Error: missing script: start 4 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19) 4 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:63:5 4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5 4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5 4 verbose stack at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45) 4 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3) 4 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5) 4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:364:12 4 verbose stack at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:90:16 4 verbose stack at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3) 5 verbose cwd /home/pi/MagicMirror/modules/MMM-Fuel 6 verbose Linux 4.14.79-v7+ 7 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev" 8 verbose node v9.11.2 9 verbose npm v6.6.0 10 error missing script: start 11 verbose exit [ 1, true ]
@rakostamas said in MMM-Fuel:
please do
then
npm start dev
Yes I got errors.
GET http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js net : : ERR_CACHE_READ_FAILURE Error on loading script: modules/MMM-Fuel//MMM-Fuel.js
sorry, I do not know why reading from the local disk would fail with cache read failure error
