    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 574.6k Views 48 Watching
    • strawberry 3.141S Offline
      I refactored the module and switched to nunjuck templates.
      I’m looking for people who are willing to test prices
      • tankerkoenig germany
      • spritpreisrechner austria
      how to test:
      • if not already done, clone the repository to your modules cd ~/MagicMirror/modules/ && git clone https://github.com/fewieden/MMM-Fuel.git
      • go to the module cd ~/MagicMirror/modules/MMM-Fuel
      • run git checkout develop
      • run npm i
      • test various config options
      [card:fewieden/MMM-Fuel]
        rakostamas
        Hey, I have just installed the module, but I realized one minor mistake. The distances in the table have too much numbers after the decimal point. Where can I change it to just one decimal number?
        • O Offline
          othomys
          I use the tankerkoenig-api to let me see the German fuel prices. Unfortunately, the special characters (ä, ö, ü, ß, …) are not displayed correctly. At which point can I adapt the encoding?
          Thank you in advance.
            dazza120
            Is there anyway to to get this for UK fuel prices?
              @rakostamas I try to adjust it in the next update.
              @othomys I think that’s a problem with the nunjuck templates that I didn’T figure out yet.
              @dazza120 is there a public api for it?
              D R 2 Replies Last reply Reply Quote 0
                dazza120 @strawberry 3.141
                @strawberry-3-141 doesn’t look like the UK does have an api for fuel prices
                  rakostamas @strawberry 3.141
                  @strawberry-3-141
                  I reinstalled the mirror and installed the module again, however it stopped working. (It’s shows only “loading”) I’m using the same config file as before. Every module beside this working :/ Is it possible, that there is a bug in the module?
                    strawberry 3.141 Project Sponsor Module Developer @rakostamas
                    @rakostamas which branch are you using? Develop or master? On develop I’m working on a refactoring, so bugs are definetly possible. Master was probably not changed in a year.
                    Any errors in the console?
                    Did you install the dependencies?
                    Can you post your confit part without the API key and a bit modified gps position?
                      @strawberry-3-141
                      here is my config:
                      			module: "MMM-Fuel",
                      				provider: "spritpreisrechner",
                      				lat: 47.041194,
                      				lng: 15.453377,
                      				types: ["e5", "diesel"],
                      				radius: 6,
                      				max: 4,
                      				sortBy: "e5",
                      				open: true,
                      The mirror only displays the header and loading…
                      I have installed it in the following way:
                        sdetweil @rakostamas
                        @rakostamas run
                        npm start dev
                        to open the development screen, select the console tab… are there any errors (in red) shown?
                          rakostamas @sdetweil
                          Yes it seems :D
                            wrong folder… in MagicMirror always for start. not module folder
                              1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
                              2 info using npm@6.6.0
                              3 info using node@v9.11.2
                              4 verbose stack Error: missing script: start
                              4 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
                              4 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:63:5
                              4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
                              4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5
                              4 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45)
                              4 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3)
                              4 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
                              4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:364:12
                              4 verbose stack     at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:90:16
                              4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
                              5 verbose cwd /home/pi/MagicMirror/modules/MMM-Fuel
                              6 verbose Linux 4.14.79-v7+
                              7 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
                              8 verbose node v9.11.2
                              9 verbose npm  v6.6.0
                              10 error missing script: start
                              11 verbose exit [ 1, true ]
                              S strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                @rakostamas said in MMM-Fuel:
                                please do
                                then
                                npm start dev
                                  rakostamas
                                  Yes I got errors.
                                  GET http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js net : : ERR_CACHE_READ_FAILURE
                                  Error on loading script: modules/MMM-Fuel//MMM-Fuel.js
                                    sorry, I do not know why reading from the local disk would fail with cache read failure error
                                      @rakostamas as @sdetweil already mentioned you need to start the mirror not the module.
                                      cd ~/MagicMirror && npm start dev
                                        @strawberry-3-141
                                        yes, I have opened it, and I got the errors what I wrote in my last comment
                                          @rakostamas did you check that the file exists? Maybe something went wrong during the cloning of the module
                                          • V Offline
                                            VanDerPol
                                            hello
                                            I have the same problem like rakostamas.
                                            As headline there stands Spritpreise und below there stands loading.
                                            I am from Austria and I use provider Spritpreisrechner.
                                            Unfortunately I can’t find the mistake. Could you please help me?
                                            Sorry My english is not the yellow from the egg :)
                                            My Config:
        module: "MMM-Fuel",
        lat: 48.527710,
        lng: 16.361530,
        radius: 15,
        max: 5,
        map_api_key: false,
        zoom: 12,
        width: 600,
        height: 600,
        colored: true,
        open: false,
        shortenText: false,
        showAddress: true,
        showOpenOnly: false,
        iconHeader: true,
        rotate: true,
        types: ['diesel'],
        sortBy: 'diesel',
        rotateInterval: 60 * 1000, // every minute
        updateInterval: 15 * 60 * 1000, // every 15 minutes
        provider: 'spritpreisrechner',
        toFixed: false
                                            • 6 / 9
