    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 560.9k Views 48 Watching
      sdetweil @rakostamas
      @rakostamas run
      npm start dev
      to open the development screen, select the console tab… are there any errors (in red) shown?
        rakostamas @sdetweil
        Yes it seems :D
          wrong folder… in MagicMirror always for start. not module folder
            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
            2 info using npm@6.6.0
            3 info using node@v9.11.2
            4 verbose stack Error: missing script: start
            4 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
            4 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:63:5
            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5
            4 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45)
            4 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3)
            4 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:364:12
            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:90:16
            4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
            5 verbose cwd /home/pi/MagicMirror/modules/MMM-Fuel
            6 verbose Linux 4.14.79-v7+
            7 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
            8 verbose node v9.11.2
            9 verbose npm  v6.6.0
            10 error missing script: start
            11 verbose exit [ 1, true ]
            S strawberry 3.141S 2 Replies Last reply Reply Quote 0
              @rakostamas said in MMM-Fuel:
              please do
              then
              npm start dev
                rakostamas
                Yes I got errors.
                GET http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js net : : ERR_CACHE_READ_FAILURE
                Error on loading script: modules/MMM-Fuel//MMM-Fuel.js
                  sorry, I do not know why reading from the local disk would fail with cache read failure error
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @rakostamas
                    @rakostamas as @sdetweil already mentioned you need to start the mirror not the module.
                    cd ~/MagicMirror && npm start dev
                      rakostamas @strawberry 3.141
                      @strawberry-3-141
                      yes, I have opened it, and I got the errors what I wrote in my last comment
                        @rakostamas did you check that the file exists? Maybe something went wrong during the cloning of the module
                        • V Offline
                          VanDerPol
                          hello
                          I have the same problem like rakostamas.
                          As headline there stands Spritpreise und below there stands loading.
                          I am from Austria and I use provider Spritpreisrechner.
                          Unfortunately I can’t find the mistake. Could you please help me?
                          Sorry My english is not the yellow from the egg :)
                          My Config:
                                               module: "MMM-Fuel",
                                                       lat: 48.527710,
                                                       lng: 16.361530,
                                                       radius: 15,
                                                       max: 5,
                                                       map_api_key: false,
                                                       zoom: 12,
                                                       width: 600,
                                                       height: 600,
                                                       colored: true,
                                                       open: false,
                                                       shortenText: false,
                                                       showAddress: true,
                                                       showOpenOnly: false,
                                                       iconHeader: true,
                                                       rotate: true,
                                                       types: ['diesel'],
                                                       sortBy: 'diesel',
                                                       rotateInterval: 60 * 1000, // every minute
                                                       updateInterval: 15 * 60 * 1000, // every 15 minutes
                                                       provider: 'spritpreisrechner',
                                                       toFixed: false
                            I just merged a new version of this module into master.
                            New: Support for gas stations in new south wales australia
                            Changed: I rewrote most of the module, make sure you also install the dependencies after the update.
                            [card:fewieden/MMM-Fuel]
                              Daugenix
                              Can I only show 3 specific gas stations?
                              The gas stations that are displayed to me, I never go there
                                Daugenix @Daugenix
                                @Daugenix said in MMM-Fuel:
                                Statement:
                                max: 3
                                is not what I mean.
                                  strawberry 3.141 Project Sponsor Module Developer @Daugenix
                                  @Daugenix this is currently not implemented as most providers give not many results back
                                    Version 2.0.1
                                    Fixed: Ellipsis rendering in nunjuck template with config option shortenText active
                                      db1mso
                                        anno1972
                                        Hi all
                                        tankerkoenig does not provide API keys anomore - as far as I see there is no free provider anymore.
                                        How will this module run in future?
                                        Cheers
                                        Andy
                                        FoziF cowboysdudeC 2 Replies Last reply Reply Quote 0
                                        • FoziF Offline
                                          Fozi Project Sponsor @anno1972
                                          @anno1972 you can still register for a API key
                                          https://creativecommons.tankerkoenig.de/ —> API-key
                                            anno1972 @Fozi
                                            @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
                                            Happy New Year
                                            • 6 / 9
