    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 574.6k Views 48 Watching
    • X Offline
      xray2607
      Chaps,
      Pethaps again a newbie question, but how do I configure this module for Austria, spritpreisrechner?
      Anything ‘special’ to consider?
      I do not get an error message for the config.js, but I also do not get a populated list for my Diesel.
      Do I need to specify the provider, or does the module do the look up based on my location?
      Any hint/help is greatly appreciated.
      Many thanks,
      XR
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @xray2607
        @xray2607 you need to specify provider: 'spritpreisrechner', also spritpreisrechner changed the api, so you might want to use the develop branch git checkout develop
        • K Offline
          killing joke
          Hey @ all,
          I think I have a small issue with the MMM-Fuel but I don´t know how to solve it. I installed the module as written in the manual but unfortunately it doesn´t show anything on the expected area (bottom_left)
          Below the snippet of the code within the config.js-file.
          			module: "MMM-Fuel",
          			postion: "bottom_left",
          				provider: "tankerkoenig",
          				api_key: "API-KEY",
          				lat: 52.9863800,
          				lng: 9.8433800,
          				types: ["diesel", "e5"],
          				sortby: "diesel",
          				radius: 10,
          				updateInterval: 900000,
          				max: 5
          Any ideas how I can fix it?
          Thanks in advance
            bjoern
            I’ve been using the module for a while, but since this morning I’m not getting any posts.
              @killing-joke you wrote postion instead of position
              @bjoern which provider (tankerkoenig or spritpreisrechner) just checked it and I’m getting results
                bjoern
                sorry, my mistake. I had no provider deposited. after I deposited Tankerkoenig everything works again now.
                • K Offline
                  killing joke @strawberry 3.141
                  @strawberry-3-141 said in MMM-Fuel:
                  Thank you very much. I checked a lot of times the comma and the spaces and braces but didn´t checked the writing.
                  It works fine. Cheers.
                    I refactored the module and switched to nunjuck templates.
                    I’m looking for people who are willing to test prices
                    • tankerkoenig germany
                    • spritpreisrechner austria
                    how to test:
                    • if not already done, clone the repository to your modules cd ~/MagicMirror/modules/ && git clone https://github.com/fewieden/MMM-Fuel.git
                    • go to the module cd ~/MagicMirror/modules/MMM-Fuel
                    • run git checkout develop
                    • run npm i
                    • test various config options
                    [card:fewieden/MMM-Fuel]
                      rakostamas
                      Hey, I have just installed the module, but I realized one minor mistake. The distances in the table have too much numbers after the decimal point. Where can I change it to just one decimal number?
                      • O Offline
                        othomys
                        I use the tankerkoenig-api to let me see the German fuel prices. Unfortunately, the special characters (ä, ö, ü, ß, …) are not displayed correctly. At which point can I adapt the encoding?
                        Thank you in advance.
                          dazza120
                          Is there anyway to to get this for UK fuel prices?
                            @rakostamas I try to adjust it in the next update.
                            @othomys I think that’s a problem with the nunjuck templates that I didn’T figure out yet.
                            @dazza120 is there a public api for it?
                            D R 2 Replies Last reply Reply Quote 0
                              dazza120 @strawberry 3.141
                              @strawberry-3-141 doesn’t look like the UK does have an api for fuel prices
                                rakostamas @strawberry 3.141
                                @strawberry-3-141
                                I reinstalled the mirror and installed the module again, however it stopped working. (It’s shows only “loading”) I’m using the same config file as before. Every module beside this working :/ Is it possible, that there is a bug in the module?
                                  strawberry 3.141 Project Sponsor Module Developer @rakostamas
                                  @rakostamas which branch are you using? Develop or master? On develop I’m working on a refactoring, so bugs are definetly possible. Master was probably not changed in a year.
                                  Any errors in the console?
                                  Did you install the dependencies?
                                  Can you post your confit part without the API key and a bit modified gps position?
                                    @strawberry-3-141
                                    here is my config:
                                    			module: "MMM-Fuel",
                                    				provider: "spritpreisrechner",
                                    				lat: 47.041194,
                                    				lng: 15.453377,
                                    				types: ["e5", "diesel"],
                                    				radius: 6,
                                    				max: 4,
                                    				sortBy: "e5",
                                    				open: true,
                                    The mirror only displays the header and loading…
                                    I have installed it in the following way:
                                      sdetweil @rakostamas
                                      @rakostamas run
                                      npm start dev
                                      to open the development screen, select the console tab… are there any errors (in red) shown?
                                        rakostamas @sdetweil
                                        Yes it seems :D
                                          wrong folder… in MagicMirror always for start. not module folder
                                            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
                                            2 info using npm@6.6.0
                                            3 info using node@v9.11.2
                                            4 verbose stack Error: missing script: start
                                            4 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
                                            4 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:63:5
                                            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
                                            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5
                                            4 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45)
                                            4 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3)
                                            4 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
                                            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:364:12
                                            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:90:16
                                            4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
                                            5 verbose cwd /home/pi/MagicMirror/modules/MMM-Fuel
                                            6 verbose Linux 4.14.79-v7+
                                            7 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
                                            8 verbose node v9.11.2
                                            9 verbose npm  v6.6.0
                                            10 error missing script: start
                                            11 verbose exit [ 1, true ]
                                            S strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                            • 6 / 9
