    New Install From Raspbian Stretch
    raspberry pi 3raspbian stretch
    14 Posts 4 Posters 7.8k Views 4 Watching
      sebien0077
      OK, i have forced upgrade node with this command:
      curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
      I install Node:
      sudo apt install -y nodejs
      now node version :
      pi@raspberrypi:~/MagicMirror $ node -v
      v10.15.0
      I have remove MagicMirror folder, and reinstall from the beginning:
      pi@raspberrypi:~ $ rm -rf MagicMirror/
      pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      All seem OK, but they are vulnerabillity…
      Cloning MagicMirror Done!
      Installing dependencies ...
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      successfully dowloaded and extracted!
      > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      Downloading SHASUMS256.txt
      [============================================>] 100.0% of 5.39 kB (5.39 kB/s)
      > magicmirror@2.6.0 install /home/pi/MagicMirror
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      added 82 packages from 57 contributors and audited 220 packages in 15.326s
      found 3 low severity vulnerabilities
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
      > sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
      > cd fonts && npm install
      added 1 package from 1 contributor and audited 1 package in 3.955s
      found 0 vulnerabilities
      npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
      added 921 packages from 1366 contributors and audited 2466 packages in 170.898s
      found 8 vulnerabilities (7 low, 1 high)
      Dependencies installation Done!
      Check plymouth installation ...
      Splashscreen: Checking themes directory.
      Splashscreen: Create theme directory if not exists.
      Splashscreen: Theme copied successfully.
      Splashscreen: Changed theme to MagicMirror successfully.
        sdetweil @sebien0077
        @sebien0077
        run
        npm audit fix
          sebien0077 @sdetweil
          yes i have made , only one resist :
          pi@raspberrypi:~/MagicMirror $ npm audit
                                 === npm audit security report ===
          │                                Manual Review                                 │
          │            Some vulnerabilities require your attention to resolve            │
          │         Visit https://go.npm.me/audit-guide for additional guidance          │
          │ Low           │ Prototype Pollution                                          │
          │ Package       │ lodash                                                       │
          │ Patched in    │ >=4.17.5                                                     │
          │ Dependency of │ express-ipfilter                                             │
          │ Path          │ express-ipfilter > lodash                                    │
          │ More info     │ https://nodesecurity.io/advisories/577                       │
          S lavolp3L 2 Replies Last reply
            @sebien0077
            npm i lodash@latest
              dazza120
              Hi guys instead of me starting a new thread for the same thing can I jump in as it seems the last thing may have fixed OP’s issue, I have two vulnerabilities that are not fixing ate all 😢 can you help please I’ve tried the npm I lodash@latest but that doesn’t work
                                     Manual Review                                 │
              │ Moderate      │ Regular Expression Denial of Service                         │
              │ Package       │ underscore.string                                            │
              │ Patched in    │ >=3.3.5                                                      │
              │ Dependency of │ fix                                                          │
              │ Path          │ fix > underscore.string                                      │
              │ More info     │ https://npmjs.com/advisories/745                             │
              │ More info     │ https://npmjs.com/advisories/577
              • lavolp3L
                lavolp3 Module Developer
                Guys be careful with the npm vulnerabilities!
                It’s not advisable to always fix all of them.
                E.g. if a vulnerability wants to have a most recent version of an important dependency, fixing it might even break your working MM because MM can’t work with this new dependency.
                If you’re not completely sure what you’re doing then leave them.
                They are not errors after all, your modules should work with these vulnerabilities as well.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                D 1 Reply Last reply
                Reply Quote 2
                  dazza120 @lavolp3
                  @lavolp3 understood thanks ill leave well alone now then thanks
                  • lavolp3L
                    lavolp3 Module Developer @sebien0077
                    @sebien0077 better leave lodash alone is my suggestion. YOur mirror should work with this vulnerability as well.
                    HOwever, you can of course try it out IF YOU DARE!!!
                    Go on the presented link and do as suggested.
                    npm install lodash@4.17.5
                    (that’s what I would try)
                      sebien0077 @lavolp3
                      @lavolp3 said in New Install From Raspbian Stretch:
                      Thx for your help. I just don’t like vulnerability :)
                      i have try 4.17.5 and 4.17.11 … nothing work :(
                      pi@raspberrypi:~/MagicMirror $ npm install lodash@4.17.5
                      + lodash@4.17.5
                      updated 1 package and audited 4407 packages in 42.128s
                      found 1 low severity vulnerability
                      pi@raspberrypi:~/MagicMirror $ npm audit fix
                      up to date in 31.654s
                      fixed 0 of 1 vulnerability in 4407 scanned packages
                        1 vulnerability required manual review and could not be updated
                      │                                Manual Review                                 │
                      found 1 low severity vulnerability in 4407 scanned packages
                        1 vulnerability requires manual review. See the full report for details.
                      pi@raspberrypi:~/MagicMirror $ npm install lodash@4.17.11
                      + lodash@4.17.11
                      updated 1 package and audited 4407 packages in 39.671s
                      up to date in 32.389s
                      │                                Manual Review                                 │
                      lavolp3L 1 Reply Last reply
                        as you will be the only user of the app (in your house, no public consumers, not open to internet)…
                        the vulnerabilities really don’t matter…
                        • lavolp3L
                          @sebien0077 Have you done a reboot? I hear they can do wonders!
                            sebien0077 @lavolp3
                            @lavolp3 yes, a lot of time ^^
