    New Install From Raspbian Stretch
    raspberry pi 3raspbian stretch
    14 Posts 4 Posters 7.7k Views 4 Watching
      sdetweil @sebien0077
      @sebien0077
      run
      npm audit fix
        sebien0077 @sdetweil
        yes i have made , only one resist :
        pi@raspberrypi:~/MagicMirror $ npm audit
                               === npm audit security report ===
        │                                Manual Review                                 │
        │            Some vulnerabilities require your attention to resolve            │
        │         Visit https://go.npm.me/audit-guide for additional guidance          │
        │ Low           │ Prototype Pollution                                          │
        │ Package       │ lodash                                                       │
        │ Patched in    │ >=4.17.5                                                     │
        │ Dependency of │ express-ipfilter                                             │
        │ Path          │ express-ipfilter > lodash                                    │
        │ More info     │ https://nodesecurity.io/advisories/577                       │
        S lavolp3L 2 Replies Last reply Reply Quote 0
          @sebien0077
          npm i lodash@latest
            dazza120
            Hi guys instead of me starting a new thread for the same thing can I jump in as it seems the last thing may have fixed OP’s issue, I have two vulnerabilities that are not fixing ate all 😢 can you help please I’ve tried the npm I lodash@latest but that doesn’t work
                                   Manual Review                                 │
            │ Moderate      │ Regular Expression Denial of Service                         │
            │ Package       │ underscore.string                                            │
            │ Patched in    │ >=3.3.5                                                      │
            │ Dependency of │ fix                                                          │
            │ Path          │ fix > underscore.string                                      │
            │ More info     │ https://npmjs.com/advisories/745                             │
            │ More info     │ https://npmjs.com/advisories/577
            • lavolp3L Offline
              lavolp3 Module Developer
              Guys be careful with the npm vulnerabilities!
              It’s not advisable to always fix all of them.
              E.g. if a vulnerability wants to have a most recent version of an important dependency, fixing it might even break your working MM because MM can’t work with this new dependency.
              If you’re not completely sure what you’re doing then leave them.
              They are not errors after all, your modules should work with these vulnerabilities as well.
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              D 1 Reply Last reply Reply Quote 2
                dazza120 @lavolp3
                @lavolp3 understood thanks ill leave well alone now then thanks
                • lavolp3L Offline
                  lavolp3 Module Developer @sebien0077
                  @sebien0077 better leave lodash alone is my suggestion. YOur mirror should work with this vulnerability as well.
                  HOwever, you can of course try it out IF YOU DARE!!!
                  Go on the presented link and do as suggested.
                  npm install lodash@4.17.5
                  (that’s what I would try)
                    sebien0077 @lavolp3
                    @lavolp3 said in New Install From Raspbian Stretch:
                    Thx for your help. I just don’t like vulnerability :)
                    i have try 4.17.5 and 4.17.11 … nothing work :(
                    pi@raspberrypi:~/MagicMirror $ npm install lodash@4.17.5
                    npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                    + lodash@4.17.5
                    updated 1 package and audited 4407 packages in 42.128s
                    found 1 low severity vulnerability
                      run `npm audit fix` to fix them, or `npm audit` for details
                    pi@raspberrypi:~/MagicMirror $ npm audit fix
                    up to date in 31.654s
                    fixed 0 of 1 vulnerability in 4407 scanned packages
                      1 vulnerability required manual review and could not be updated
                    │                                Manual Review                                 │
                    found 1 low severity vulnerability in 4407 scanned packages
                      1 vulnerability requires manual review. See the full report for details.
                    pi@raspberrypi:~/MagicMirror $ npm install lodash@4.17.11
                    + lodash@4.17.11
                    updated 1 package and audited 4407 packages in 39.671s
                    up to date in 32.389s
                    │                                Manual Review                                 │
                      as you will be the only user of the app (in your house, no public consumers, not open to internet)…
                      the vulnerabilities really don’t matter…
                      • lavolp3L Offline
                        @sebien0077 Have you done a reboot? I hear they can do wonders!
                          sebien0077 @lavolp3
                          @lavolp3 yes, a lot of time ^^
