    Installing on Pi 3B | Unable to install dependencies! | Error 128 in debug logs
    7 Posts 3 Posters 2.9k Views 2 Watching
    • bheplerB Offline
      bhepler Module Developer
      It looks like you’re attempting to install the Magic Mirror as the root user. You don’t want to do that. I would delete the /root/MagicMirrordirectory, change back to the pi and then install from the home directory of that user.
        Roskafarian
        Thanks for getting back to me @bhepler! I ran it as the normal PI user but ran into this:
        Installing dependencies ...
        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
        npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
        > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
        > node ./download-chromedriver.js
        successfully dowloaded and extracted!
        > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
        > node install.js
        Downloading electron-v2.0.16-linux-arm.zip
        Error: read ECONNRESET
        /home/pi/MagicMirror/node_modules/electron/install.js:54
          throw err
            at _errnoException (util.js:1022:11)
            at TLSWrap.onread (net.js:628:25)
        npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! electron@2.0.16 postinstall: `node install.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the electron@2.0.16 postinstall script.
        npm ERR!     /home/pi/.npm/_logs/2019-01-25T18_59_27_944Z-debug.log
        Although, I got a little further this time around!
          Roskafarian
          I was an idjit. I thought I had removed the directories but it seems there was another hidden one. We’re fine!
          • bheplerB Offline
            bhepler Module Developer @Roskafarian
            @roskafarian Glad to hear it! Does that mean this issue is resolved?
              Roskafarian
              Oh yes! We’re cooking with lighter fluid as we speak
              • DæmonEyesD Offline
                DæmonEyes
                In case you didn’t find a solution yet, a user by the name sdetweil just helped me with a similar problem with my RPi 3 B+ running the latest Rasbian Stretch.
                Here is the link to that discussion for everyone else who is stuck at this step too:
                https://forum.magicmirror.builders/topic/9636/stuck-at-unable-to-install-dependencies/8?page=1
