    Installing on Pi 3B | Unable to install dependencies! | Error 128 in debug logs
    7 Posts 3 Posters 3.6k Views 2 Watching
      Roskafarian
      OS: Raspbian Linux JARVIS 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
      Issue: Unable to install dependencies! Error 128
      Description: Attempted running Auto installer with failure at dependencies. Received error listed below.
      9923 warn grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      9924 warn acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
      9925 verbose stack Error: exited with error code: 128
      9925 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/util/finished.js:12:19)
      9925 verbose stack     at emitTwo (events.js:126:13)
      9925 verbose stack     at ChildProcess.emit (events.js:214:7)
      9925 verbose stack     at maybeClose (internal/child_process.js:925:16)
      9925 verbose stack     at Socket.stream.socket.on (internal/child_process.js:346:11)
      9925 verbose stack     at emitOne (events.js:116:13)
      9925 verbose stack     at Socket.emit (events.js:211:7)
      9925 verbose stack     at Pipe._handle.close [as _onclose] (net.js:567:12)
      9926 verbose cwd /root/MagicMirror
      9927 verbose Linux 4.14.79-v7+
      9928 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install"
      9929 verbose node v8.11.1
      9930 verbose npm  v6.7.0
      9931 error Error while executing:
      9931 error /usr/bin/git ls-remote -h -t ssh://git@github.com/patriksimek/vm2.git
      9931 error
      9931 error fatal: Could not change back to '/root/MagicMirror': Permission denied
      9931 error
      9931 error exited with error code: 128
      9932 verbose exit [ 1, true ]
      As this is my first time installing, I tried manually installing npm but with no luck. The error does say I need to install peer dependencies manually. I researched manually installing the peer dependencies to no luck. Any pointers?
      • bheplerB Offline
        bhepler Module Developer
        It looks like you’re attempting to install the Magic Mirror as the root user. You don’t want to do that. I would delete the /root/MagicMirrordirectory, change back to the pi and then install from the home directory of that user.
          Roskafarian
          Thanks for getting back to me @bhepler! I ran it as the normal PI user but ran into this:
          Installing dependencies ...
          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
          npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
          > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
          > node ./download-chromedriver.js
          successfully dowloaded and extracted!
          > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
          > node install.js
          Downloading electron-v2.0.16-linux-arm.zip
          Error: read ECONNRESET
          /home/pi/MagicMirror/node_modules/electron/install.js:54
            throw err
              at _errnoException (util.js:1022:11)
              at TLSWrap.onread (net.js:628:25)
          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! electron@2.0.16 postinstall: `node install.js`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the electron@2.0.16 postinstall script.
          npm ERR!     /home/pi/.npm/_logs/2019-01-25T18_59_27_944Z-debug.log
          Although, I got a little further this time around!
            Roskafarian
            I was an idjit. I thought I had removed the directories but it seems there was another hidden one. We’re fine!
            • bheplerB Offline
              bhepler Module Developer @Roskafarian
              @roskafarian Glad to hear it! Does that mean this issue is resolved?
                Roskafarian
                Oh yes! We’re cooking with lighter fluid as we speak
                • DæmonEyesD Offline
                  DæmonEyes
                  In case you didn’t find a solution yet, a user by the name sdetweil just helped me with a similar problem with my RPi 3 B+ running the latest Rasbian Stretch.
                  Here is the link to that discussion for everyone else who is stuck at this step too:
                  https://forum.magicmirror.builders/topic/9636/stuck-at-unable-to-install-dependencies/8?page=1
