    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 215.7k Views 6 Watching
      AxLed Module Developer
      @evroom
      here are some questions:
      to 1: apibouquet expects a number (integer) and in java it starts with 0. If i use the xml-sample file of /web/getallservices you send me its in your case as follows:
      0: Favourites (TV)
      1: Nederland (TV)
      2: Duitsland (TV)
      to 2: i cant reproduce this behavior
      to 3 & 4: try disabling some other modules, to find out if there is a intolerance beetween modules.
      AxLED
      • evroomE Offline
        evroom
        to 1: thanks. Very clear.
        to 2: does not happen always, or too fast to detect (I did ps manually).
        to 3: did this, but does not help. I have think I have an issue that is related to my install only.
        Thanks for the changes. It makes it more usable.
        MagicMirror version: 2.37.0
        • Cr4z33C Offline
          Cr4z33 @AxLed
          @axled I want to give this module another try for some testing, but I still didn’t understand how am I supposed to stream a Dreambox channel in MM? :hushed_face:
          • Cr4z33C Offline
            Cr4z33 @AxLed
            @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
            @Cr4z33
            I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
            Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
            Do you have MMM-Remote-Control installed?
            Se my previous answer to evroom.
            AxLED
            WHERE do I have to enter these commands?
            In a RPI terminal window?
            In my ie. Windows 10 Internet browser address box?
              @Cr4z33
              As you have MMM-Remote-Control installed you can test MMM-Dreambox with MMM-Remote-Control first, to make sure it works at all. (Requirement: Your mirror is reachable by browser in the same network). Open browser and enter (without the spaces around &):
              • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-SERVICE-NEXT (for selecting next service)
              • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-SERVICE-PREV (for selecting prev.service)
              • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-PLAY (for start streaming)
              • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-STOP (for stop streaming)
              Hint: HD Services need MPG License so maybe start with SD services.
              You can also try the dev branch, as this is the newer one with more functions.
              AxLED
              • Cr4z33C Offline
                Cr4z33 @AxLed
                @axled thanks got the remote module working, but then when I send the commands (succesfully confirmed by the web page) I see no streaming going on in MM.
                By the way I choosed to install the dev branch of your module.
                  @Cr4z33
                  Can you show me the MMM-Dreambox Part of your config and some logs?
                  Playing does not work, is selecting DB-SERVICE-NEXT (PREV) working?
                  AxLED
                  • Cr4z33C Offline
                    Cr4z33 @AxLed
                    @axled this is the config part:
                    			module: 'MMM-Dreambox',
                    			header: 'Vu+ Duo²',
                    			position: 'bottom_left',
                    			disabled: false,
                    				apiBase: 'http://*.*.*.*:****',
                    				omxargs: ' --win 320,180,1600,900  -o both ',
                    				refreshInterval: 1000 * 30, //refresh every 30 seconds
                    				apiabout: '/web/about',
                    				apiservices: '/web/getallservices',
                    				apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                    				apizap: '/web/zap?sRef=',
                    				apiTimerlist: '/web/timerlist',
                    				apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet'
                    I wanted then to paste here the logs and what was happening when sendings commands, but all I get now is
                    status	"error"
                    reason	"unknown_command"
                    info	"original input: {\"action\":\"NOTIFICATION \",\" notification\":\"DB-PLAY\"}"
                    I feel like I am missing something? :smiling_face_with_open_mouth_cold_sweat:
                    This is btw the MMM-Remote-Control config part:
                    			module: 'MMM-Remote-Control',
                      @Cr4z33
                      it is not easy to give support, with this less informations.
                      As you send me .xml files some days ago, i saw some minor errors in your config.js
                      1. apibouquet and listmax is missing, so module use defaults (apibouquet: 0, listmax: 15)
                      2. apiepgnow and apiServicelistplayable are wrong, to match to your receiver/xml file you send me the should look as follows:
                      • apiepgnow: ‘/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.TerrestrialTv.tv%22%20ORDER%20BY%20bouquet’,
                      • apiServicelistplayable: ‘/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.TerrestrialTv.tv%22%20ORDER%20BY%20bouquet’,
                      Can you please also answer my question:
                      To help you further i need some screenshots of the module on your mirror and some logs (pm2 or from the browser by using F12).
                      AxLED
                      • Cr4z33C Offline
                        Cr4z33 @AxLed
                        @axled sorry for the late reply. :smiling_face_with_open_mouth_cold_sweat:
                        I’ve installed your module from scratch and now every MMM-Remote-Control command (but streaming) is working.
                        Honestly I can’t understand what is wrong because before going to use my decoder with your module all Dreambox-like applications worked like a charm.
                        What if it depends on using a different WebIf port (I am not using the default 80/8080 port)?
                        And even if why not?
                        So far every Android Dreambox app (ie. DreamDroid) or Windows channel editor program for Dreambox that I’ve used worked perfectly.
                          Some ideas:
                          Start streaming takes up to 15 seconds, did you wait long enough?
                          Are you streaming SD or HD channels? HD needs mpg license.
                          Is the play symbol (triangle) shown after sending the command DB-PLAY?
                          AxLED
                          • Cr4z33C Offline
                            Cr4z33 @evroom
                            @evroom can you please let me chat with you?
                            Need to ask you something about this module. :)
                            • evroomE Offline
                              evroom @Cr4z33
                              @cr4z33
                              Yes, you can chat with me.
                              • Cr4z33C Offline
                                Cr4z33 @evroom
                                @evroom nope the forum keeps saying you have restricted the chats only to people you are following.
                                • evroomE Offline
                                  evroom @Cr4z33
                                  @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                  Okay, now I understand your request better.
                                  Unchecked it, should be working now.
                                  • evroomE Offline
                                    evroom
                                    Looks like it does not work VU+ boxes.
                                    I used the latest master branch (installed the complete module new).
                                    All api paths have been checked and return xml data.
                                    Dreambox DM7020HD:
                                    $ pm2 restart mm
                                    0|mm  | Starting node helper for: MMM-Dreambox
                                    On the Mirror a list of channels is seen.
                                    VU+ zero:
                                    0|mm  | Whoops! There was an uncaught exception...
                                    0|mm  | TypeError: Cannot read property 'code' of null
                                    0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:129:37)
                                    0|mm  |     at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                    0|mm  |     at emitTwo (events.js:126:13)
                                    0|mm  |     at Request.emit (events.js:214:7)
                                    0|mm  |     at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1157:10)
                                    0|mm  |     at emitOne (events.js:116:13)
                                    0|mm  |     at Request.emit (events.js:211:7)
                                    0|mm  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1079:12)
                                    0|mm  |     at Object.onceWrapper (events.js:313:30)
                                    0|mm  |     at emitNone (events.js:111:20)
                                    0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    121		//5.Request - Servicelistplayable
                                    122		request({url: myUrl+this.config.apiServicelistplayable }, function (error, response, body) {
                                    123			if (!error && response.statusCode == 200) {
                                    124				self.sendSocketNotification("DATA",['DB-SLP',body]);
                                    125			} else {
                                    126				if (!error && response.statusCode == 404){
                                    127					Errormessage = 'Error: '+response.statusCode+' in '+myUrl+self.config.apiServicelistplayable;
                                    128				} else {
                                    129					Errormessage = 'Error: '+error.code+' in '+myUrl+self.config.apiServicelistplayable;
                                    130				}
                                    131				self.sendSocketNotification("DATA",['ERROR',Errormessage]);
                                    132			}
                                    133		});
                                    apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                                    http://192.168.178.47/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet
                                    <e2servicelistplayable>
                                    Nothing is seen on the Mirror.
                                    • Cr4z33C Offline
                                      Cr4z33 @evroom
                                      @evroom that’s EXACTLY what happens on my mirror as an owner of a Vu+ product.
                                      @AxLed can you please look into this? :)
                                        @Cr4z33
                                        Can you please post your config for MMM-Dreambox (as i guess there are two problems):
                                        1. at least one of your links are wrong or VU+ uses different syntax (for the xml links)
                                        2. i think node_helper.js line 129 is wrong in my code, i cant correct it without testing (error.code is null and my code expects an value)
                                        apiBase:
                                        omxargs:
                                        refreshInterval:
                                        apiabout:
                                        apiservices:
                                        apiepgnow:
                                        apizap:
                                        apiTimerlist:
                                        apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices), important apiepgnow and apiServicelistplayable have to match to the selected bouquet
                                        listmax:
                                        AxLED
                                        • evroomE Offline
                                          evroom
                                          Hi AxLed,
                                          Here is my VU+ config:
                                          disabled: false,
                                          position:"top_left",
                                          header: 'Dreambox',
                                            apiBase: 'http://192.168.178.47:80',
                                            omxargs: ' --win 0,625,590,957 -o both ',
                                            apibouquet: 0,
                                            listmax: 10,
                                          To be honest, I do not see any difference between a Dreambox and a VU Plus, in fact the bRef and sRef are exactly the same and even the same as in the README.
                                          But if you say there is a difference …
                                          If the line 129 needs modifying, I can do so by hand.
                                          Perhaps will save you some time.
                                          And could you tell us if you tested on a VU+ or on a Dreambox (or both) ?
                                            @evroom
                                            To answer your questions:
                                            • i tested on a dreambox (dm800se) with a single dvb-c tuner
                                            • modifying line 129 could help, i need the output of ‘error’ and ‘response’, as i only check for ‘error’ (true/false) and only for response.Statuscode 200 and 404.
                                            I have some questions too:
                                            • if you enter http://192.168.178.47:80/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet in you browser, is there xml showing up?
                                            • if not, what else is shown?
                                            • the xml files you send me on 29th of december, where they from your dreambox or from VU+?
                                            • if the were from the dreambox, can you please send me the following file from your VU+ by email ak10zeichen-xy@yahoo.de :
                                            • http://192.168.178.47:80/web/getallservices
                                            So i can check what is going wrong.
                                            AxLED
                                            • 3 / 8
