    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 225.1k Views 6 Watching
    • Cr4z33C
      Cr4z33 @AxLed
      @axled OK gimme a minute and I send them. :winking_face:
      • evroomE
        evroom
        “You talking to me ?” (Robert de Niro - Taxi Driver).
        I sent the files, just in case.
        MagicMirror version: 2.37.0
        • A
          AxLed Module Developer @evroom
          @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
          I sent the files
          @evroom
          Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
          My “getallservices” xml only has one “bouquet”, so i checked only for one.
          As your “getallservices” xml has three “bouquets” i changed the code.
          If you do a git pull (master repository) it should work.
          So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
          AxLED
          • A
            AxLed Module Developer @Cr4z33
            @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
            @Cr4z33
            Thanks for your files, one a fast view you also have more than one bouquet in “getallservices”, so my last fix should work for you also.
            Try agit pull (master repository).
            AxLED
            • evroomE
              evroom
              @AxLed
              The services list now is present.
              Next step is to stream one.
              • Cr4z33C
                Cr4z33 @AxLed
                @axled the situation now is like in the below screenshot and I still don’t know how I am supposed to stream a channel (if I don’t have to specify its url). :smiling_face_with_open_mouth_cold_sweat:
                • evroomE
                  evroom
                  All actions:
                  http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                  http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-PREV
                  http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                  http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-STOP
                  Result in:
                  Cannot GET /remote
                  • A
                    @evroom
                    How do you plan to interact with your MM?
                    I have a rotary encoder. Buttons or touch is also fine.
                    For the beginning you can use MMM-Remote-Control to send notifications.
                    I have to complete my Readme, that the sample links only work with MMM-Remote-Control
                    So install MMM-Remote-Control, open an browser, modify the links matching to your environment and you should be able to select channels and stream them.
                    Important: Try with SD Channels first, as for HD channels the mpg2 codec is needed.
                    AxLED
                    • evroomE
                      evroom @AxLed
                      @axled
                      I was about to ask about this.
                      Suppose it works, how will I use it in practise?
                      I have a Pi with a monitor connected hanging in the kitchen.
                      No fancy mirror like many, with speech and buttons and PIRs.
                      So, basically no interaction.
                      I plan on getting speech running, but I have other projects running at this moment (for instance Homematic IP and ioBroker).
                      I will try to install MMM-Remote-Control and see if that will work.
                      • A
                        @Cr4z33
                        I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                        Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                        Do you have MMM-Remote-Control installed?
                        Se my previous answer to evroom.
                        AxLED
                        Cr4z33C 2 Replies Last reply Reply Quote 0
                        • Cr4z33C
                          Cr4z33 @AxLed
                          @axled oh now I understand.
                          Thanks for the information.
                          However I don’t have MMM-Remote-Control and I rather prefer to control everything by voice commands (MMM-AssistantMk2).
                          Sorry, but then this module doesn’t suit my needs. :winking_face:
                          • A
                            @Cr4z33
                            You should be able to send notifications by voice commands also.
                            AxLED
                            • A
                              @evroom
                              I have a PIR-Sensor (for turning screen on/off) and a rotary encoder connected (to the GPIO PINs of the Pi).
                              In the bottom right corner you see my “first” module MMM-Navigate which interacts with the rotary encoder.
                              So depending on the navigation menu i am able to:
                              • swipe pages (i have four)
                              • show Details to newsfeeds (opens website to the newsfeed)
                              • adjust brightness
                              • select dreambox channels
                              • start/stop streaming dreambox channels
                              • control the mirror (restart mm, shutdown, reboot)
                              • and for the future: everything which can handle the MM notification system
                              AxLED
                              • evroomE
                                evroom
                                Okay, I have MMM-Remote-Control running and I can open the menu.
                                Now using:
                                I get this:
                                {"status":"success"}
                                Now I see a stream on my monitor !!
                                With DB-SERVICE-NEXT and DB-SERVICE-PREV I can scroll through the services list
                                Also gives
                                But I cannot switch to another service with DB-PLAY.
                                And I have a side effect that it takes 3 or 4 services on my Dreambox.
                                I have the plugin InfoBarTunerState installed and I see that MM is trying to stream multiple services.
                                At this moment I see one stream on my MM monitor, but my Dreambox tells me there are 2 MM streams present (on 2 different services).
                                Here the OMXPlayer processes at this moment:
                                pi@MagicPi:~/MagicMirror/modules $ ps -eaf | grep omxplayer | grep -v grep
                                pi       28431 28259  0 18:06 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                pi       28432 28431  0 18:06 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                pi       28455 28432 10 18:06 ?        00:02:50 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                pi       28522 28259  0 18:15 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                pi       28523 28522  0 18:15 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                pi       28546 28523  3 18:15 ?        00:00:31 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                • evroomE
                                  evroom
                                  Btw, is there a possibility to have the start, next, prev and stop URL’s configured in MMM-Remote-Control ?
                                  • evroomE
                                    evroom
                                    Okay, rebooted in order to start fresh.
                                    Now 1 stream.
                                    Looks like one actual omxplayer active:
                                    pi       29320 29185  0 18:39 ?        00:00:00 /bin/sh -c omxplayer  --win 0,0,480,320  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                    pi       29321 29320  0 18:39 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                    pi       29344 29321 10 18:39 ?        00:00:01 /usr/bin/omxplayer.bin --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                    InfoBarTunerState also states there is one stream.
                                    The will do for today.
                                    Will do some more testing tomorrow.
                                    Thanks a lot AxLed for the support so far !!
                                    • A
                                      @evroom
                                      Good to hear you had success and thanks for your challenge with more than one bouquet 😂, helped debugging the module.
                                      AxLED
                                      • evroomE
                                        evroom
                                        @AxLed
                                        I have opened 4 feature requests on GitHub.
                                        To be honest, my MM is hanging a meter or so away from the TV, so I most probably will not make use of the module.
                                        Navigating through the services list and starting & stopping a stream is not that comfortable
                                        Although it might be practical to see on my MM what is currently playing and I might use it solely as a program guide.
                                        Will be available though for some testing.
                                        • A
                                          Hi, if the to monitors are close together you can still view 2 different shows :-) .
                                          I checked your 4 feature requests and added 2 of them in the module.
                                          For the other two i can not promise, if they will be implemented.
                                          AxLED
                                          • A
                                            @evroom
                                            In your feature request, you wanted to select a bouquet (if there is more than one):
                                            Okay.
                                            Let’s say I have the bouquet “MagicMirror (TV)”, could there be an option to use this one, instead of the default “Favourites (TV)” ?
                                            I assume “Favourites (TV)” is the default.
                                            Please check the dev branch of my module.
                                            1. Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                                            2. do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                                            3. add new parameters to your config.js, as descriped in readme. (see apibouquet and listmax).
                                            Regards
                                            AxLED
                                            • 2 / 8
