    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 225.1k Views 6 Watching
    • Cr4z33C
      Cr4z33 @AxLed
      @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
      Can you send me following 5 xml files: …/web/about, …/web/getallservices, …/web/timerlist, …/web/servicelistplayable, … /web/epgnow by email ak10zeichen-xy@yahoo.de
      AxLED
      Me?
      • A
        AxLed Module Developer
        @Cr4z33
        Yes.
        • Cr4z33C
          Cr4z33 @AxLed
          @axled OK gimme a minute and I send them. :winking_face:
          • evroomE
            evroom
            “You talking to me ?” (Robert de Niro - Taxi Driver).
            I sent the files, just in case.
            MagicMirror version: 2.37.0
            • A
              AxLed Module Developer @evroom
              @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
              I sent the files
              @evroom
              Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
              My “getallservices” xml only has one “bouquet”, so i checked only for one.
              As your “getallservices” xml has three “bouquets” i changed the code.
              If you do a git pull (master repository) it should work.
              So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
              AxLED
              • A
                AxLed Module Developer @Cr4z33
                @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                @Cr4z33
                Thanks for your files, one a fast view you also have more than one bouquet in “getallservices”, so my last fix should work for you also.
                Try agit pull (master repository).
                AxLED
                • evroomE
                  evroom
                  @AxLed
                  The services list now is present.
                  Next step is to stream one.
                  • Cr4z33C
                    Cr4z33 @AxLed
                    @axled the situation now is like in the below screenshot and I still don’t know how I am supposed to stream a channel (if I don’t have to specify its url). :smiling_face_with_open_mouth_cold_sweat:
                    • evroomE
                      evroom
                      All actions:
                      http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                      http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-PREV
                      http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                      http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-STOP
                      Result in:
                      Cannot GET /remote
                      • A
                        @evroom
                        How do you plan to interact with your MM?
                        I have a rotary encoder. Buttons or touch is also fine.
                        For the beginning you can use MMM-Remote-Control to send notifications.
                        I have to complete my Readme, that the sample links only work with MMM-Remote-Control
                        So install MMM-Remote-Control, open an browser, modify the links matching to your environment and you should be able to select channels and stream them.
                        Important: Try with SD Channels first, as for HD channels the mpg2 codec is needed.
                        AxLED
                        • evroomE
                          evroom @AxLed
                          @axled
                          I was about to ask about this.
                          Suppose it works, how will I use it in practise?
                          I have a Pi with a monitor connected hanging in the kitchen.
                          No fancy mirror like many, with speech and buttons and PIRs.
                          So, basically no interaction.
                          I plan on getting speech running, but I have other projects running at this moment (for instance Homematic IP and ioBroker).
                          I will try to install MMM-Remote-Control and see if that will work.
                          • A
                            @Cr4z33
                            I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                            Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                            Do you have MMM-Remote-Control installed?
                            Se my previous answer to evroom.
                            AxLED
                            Cr4z33C 2 Replies Last reply Reply Quote 0
                            • Cr4z33C
                              Cr4z33 @AxLed
                              @axled oh now I understand.
                              Thanks for the information.
                              However I don’t have MMM-Remote-Control and I rather prefer to control everything by voice commands (MMM-AssistantMk2).
                              Sorry, but then this module doesn’t suit my needs. :winking_face:
                              • A
                                @Cr4z33
                                You should be able to send notifications by voice commands also.
                                AxLED
                                • A
                                  @evroom
                                  I have a PIR-Sensor (for turning screen on/off) and a rotary encoder connected (to the GPIO PINs of the Pi).
                                  In the bottom right corner you see my “first” module MMM-Navigate which interacts with the rotary encoder.
                                  So depending on the navigation menu i am able to:
                                  • swipe pages (i have four)
                                  • show Details to newsfeeds (opens website to the newsfeed)
                                  • adjust brightness
                                  • select dreambox channels
                                  • start/stop streaming dreambox channels
                                  • control the mirror (restart mm, shutdown, reboot)
                                  • and for the future: everything which can handle the MM notification system
                                  AxLED
                                  • evroomE
                                    evroom
                                    Okay, I have MMM-Remote-Control running and I can open the menu.
                                    Now using:
                                    I get this:
                                    {"status":"success"}
                                    Now I see a stream on my monitor !!
                                    With DB-SERVICE-NEXT and DB-SERVICE-PREV I can scroll through the services list
                                    Also gives
                                    But I cannot switch to another service with DB-PLAY.
                                    And I have a side effect that it takes 3 or 4 services on my Dreambox.
                                    I have the plugin InfoBarTunerState installed and I see that MM is trying to stream multiple services.
                                    At this moment I see one stream on my MM monitor, but my Dreambox tells me there are 2 MM streams present (on 2 different services).
                                    Here the OMXPlayer processes at this moment:
                                    pi@MagicPi:~/MagicMirror/modules $ ps -eaf | grep omxplayer | grep -v grep
                                    pi       28431 28259  0 18:06 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                    pi       28432 28431  0 18:06 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                    pi       28455 28432 10 18:06 ?        00:02:50 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                    pi       28522 28259  0 18:15 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                    pi       28523 28522  0 18:15 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                    pi       28546 28523  3 18:15 ?        00:00:31 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                                    • evroomE
                                      evroom
                                      Btw, is there a possibility to have the start, next, prev and stop URL’s configured in MMM-Remote-Control ?
                                      • evroomE
                                        evroom
                                        Okay, rebooted in order to start fresh.
                                        Now 1 stream.
                                        Looks like one actual omxplayer active:
                                        pi       29320 29185  0 18:39 ?        00:00:00 /bin/sh -c omxplayer  --win 0,0,480,320  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                        pi       29321 29320  0 18:39 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                        pi       29344 29321 10 18:39 ?        00:00:01 /usr/bin/omxplayer.bin --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                        InfoBarTunerState also states there is one stream.
                                        The will do for today.
                                        Will do some more testing tomorrow.
                                        Thanks a lot AxLed for the support so far !!
                                        • A
                                          @evroom
                                          Good to hear you had success and thanks for your challenge with more than one bouquet 😂, helped debugging the module.
                                          AxLED
                                          • evroomE
                                            evroom
                                            @AxLed
                                            I have opened 4 feature requests on GitHub.
                                            To be honest, my MM is hanging a meter or so away from the TV, so I most probably will not make use of the module.
                                            Navigating through the services list and starting & stopping a stream is not that comfortable
                                            Although it might be practical to see on my MM what is currently playing and I might use it solely as a program guide.
                                            Will be available though for some testing.
                                            • 2 / 8
