    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.8k Views 6 Watching
    • evroomE
      evroom
      “You talking to me ?” (Robert de Niro - Taxi Driver).
      I sent the files, just in case.
      MagicMirror version: 2.37.0
      A 1 Reply Last reply
      • A
        AxLed Module Developer @evroom
        @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
        I sent the files
        @evroom
        Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
        My “getallservices” xml only has one “bouquet”, so i checked only for one.
        As your “getallservices” xml has three “bouquets” i changed the code.
        If you do a git pull (master repository) it should work.
        So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
        AxLED
        • A
          AxLed Module Developer @Cr4z33
          @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
          @axled OK gimme a minute and I send them.
          @Cr4z33
          Thanks for your files, one a fast view you also have more than one bouquet in “getallservices”, so my last fix should work for you also.
          Try agit pull (master repository).
          AxLED
          Cr4z33C 1 Reply Last reply
          • evroomE
            evroom
            @AxLed
            The services list now is present.
            Next step is to stream one.
            • Cr4z33C
              Cr4z33 @AxLed
              @axled the situation now is like in the below screenshot and I still don’t know how I am supposed to stream a channel (if I don’t have to specify its url). :smiling_face_with_open_mouth_cold_sweat:
              • evroomE
                evroom
                All actions:
                http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-PREV
                http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-STOP
                Result in:
                Cannot GET /remote
                • A
                  @evroom
                  How do you plan to interact with your MM?
                  I have a rotary encoder. Buttons or touch is also fine.
                  For the beginning you can use MMM-Remote-Control to send notifications.
                  I have to complete my Readme, that the sample links only work with MMM-Remote-Control
                  So install MMM-Remote-Control, open an browser, modify the links matching to your environment and you should be able to select channels and stream them.
                  Important: Try with SD Channels first, as for HD channels the mpg2 codec is needed.
                  AxLED
                  evroomE 1 Reply Last reply
                  • evroomE
                    evroom @AxLed
                    @axled
                    I was about to ask about this.
                    Suppose it works, how will I use it in practise?
                    I have a Pi with a monitor connected hanging in the kitchen.
                    No fancy mirror like many, with speech and buttons and PIRs.
                    So, basically no interaction.
                    I plan on getting speech running, but I have other projects running at this moment (for instance Homematic IP and ioBroker).
                    I will try to install MMM-Remote-Control and see if that will work.
                    • A
                      @Cr4z33
                      I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                      Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                      Do you have MMM-Remote-Control installed?
                      Se my previous answer to evroom.
                      AxLED
                      Cr4z33C 2 Replies Last reply
                      • Cr4z33C
                        Cr4z33 @AxLed
                        @axled oh now I understand.
                        Thanks for the information.
                        However I don’t have MMM-Remote-Control and I rather prefer to control everything by voice commands (MMM-AssistantMk2).
                        Sorry, but then this module doesn’t suit my needs. :winking_face:
                        • A
                          @Cr4z33
                          You should be able to send notifications by voice commands also.
                          AxLED
                          • A
                            @evroom
                            I have a PIR-Sensor (for turning screen on/off) and a rotary encoder connected (to the GPIO PINs of the Pi).
                            In the bottom right corner you see my “first” module MMM-Navigate which interacts with the rotary encoder.
                            So depending on the navigation menu i am able to:
                            • swipe pages (i have four)
                            • show Details to newsfeeds (opens website to the newsfeed)
                            • adjust brightness
                            • select dreambox channels
                            • start/stop streaming dreambox channels
                            • control the mirror (restart mm, shutdown, reboot)
                            • and for the future: everything which can handle the MM notification system
                            AxLED
                            • evroomE
                              evroom
                              Okay, I have MMM-Remote-Control running and I can open the menu.
                              Now using:
                              I get this:
                              {"status":"success"}
                              Now I see a stream on my monitor !!
                              With DB-SERVICE-NEXT and DB-SERVICE-PREV I can scroll through the services list
                              Also gives
                              But I cannot switch to another service with DB-PLAY.
                              And I have a side effect that it takes 3 or 4 services on my Dreambox.
                              I have the plugin InfoBarTunerState installed and I see that MM is trying to stream multiple services.
                              At this moment I see one stream on my MM monitor, but my Dreambox tells me there are 2 MM streams present (on 2 different services).
                              Here the OMXPlayer processes at this moment:
                              pi@MagicPi:~/MagicMirror/modules $ ps -eaf | grep omxplayer | grep -v grep
                              pi       28431 28259  0 18:06 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                              pi       28432 28431  0 18:06 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                              pi       28455 28432 10 18:06 ?        00:02:50 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                              pi       28522 28259  0 18:15 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                              pi       28523 28522  0 18:15 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                              pi       28546 28523  3 18:15 ?        00:00:31 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                              • evroomE
                                evroom
                                Btw, is there a possibility to have the start, next, prev and stop URL’s configured in MMM-Remote-Control ?
                                • evroomE
                                  evroom
                                  Okay, rebooted in order to start fresh.
                                  Now 1 stream.
                                  Looks like one actual omxplayer active:
                                  pi       29320 29185  0 18:39 ?        00:00:00 /bin/sh -c omxplayer  --win 0,0,480,320  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                  pi       29321 29320  0 18:39 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                  pi       29344 29321 10 18:39 ?        00:00:01 /usr/bin/omxplayer.bin --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                  InfoBarTunerState also states there is one stream.
                                  The will do for today.
                                  Will do some more testing tomorrow.
                                  Thanks a lot AxLed for the support so far !!
                                  • A
                                    @evroom
                                    Good to hear you had success and thanks for your challenge with more than one bouquet 😂, helped debugging the module.
                                    AxLED
                                    • evroomE
                                      evroom
                                      @AxLed
                                      I have opened 4 feature requests on GitHub.
                                      To be honest, my MM is hanging a meter or so away from the TV, so I most probably will not make use of the module.
                                      Navigating through the services list and starting & stopping a stream is not that comfortable
                                      Although it might be practical to see on my MM what is currently playing and I might use it solely as a program guide.
                                      Will be available though for some testing.
                                      • A
                                        Hi, if the to monitors are close together you can still view 2 different shows :-) .
                                        I checked your 4 feature requests and added 2 of them in the module.
                                        For the other two i can not promise, if they will be implemented.
                                        AxLED
                                        • A
                                          @evroom
                                          In your feature request, you wanted to select a bouquet (if there is more than one):
                                          Okay.
                                          Let’s say I have the bouquet “MagicMirror (TV)”, could there be an option to use this one, instead of the default “Favourites (TV)” ?
                                          I assume “Favourites (TV)” is the default.
                                          Please check the dev branch of my module.
                                          1. Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                                          2. do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                                          3. add new parameters to your config.js, as descriped in readme. (see apibouquet and listmax).
                                          Regards
                                          AxLED
                                          • evroomE
                                            evroom
                                            Hi @AxLed ,
                                            Busy trying your updated module.
                                            I am struggling a bit with it.
                                            1/ I suppose I set
                                            apibouquet: 1,
                                            Is that correct ?
                                            What does it do ?
                                            When just enabling, then why not true or false to make it more clear?
                                            Or do I set it to 1 for bouquet 1 and 2 for 2, etc?
                                            Please explain.
                                            2/ The parameter
                                            listmax: 10,
                                            is working, but after play or stop, it jumps to the bouquet name.
                                            3/ On my install, when I do DB-PLAY, it starts the stream twice.
                                            So, I have 2 omxplayer process-sets and it takes up 2 streams on my Dreambox.
                                            EDIT: now streaming Das Erste HD. No other process-sets present.
                                            Perhaps decoding takes to long and omxplayer is respawning.
                                            4/ Even though I have employer processes, I do not see anything on my screen.
                                            I think I have a local issue, as I cannot stream decoded content anymore.
                                            My MPG2 license is still valid.
                                            Perhaps a performance issue.
                                            • 2 / 8
