    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.8k Views 6 Watching
    • A
      AxLed Module Developer @evroom
      @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
      Perhaps stupid, but do not how to do that. Cannot open MM using the MM IP.
      My MM config.js for IP looks like
      config = {
      	address: "192.168.56.101",
      	port: 8080,
      	ipWhitelist: [], // Set [] to allow all IP addresses
      So can can open a browser in the same network and enter http://192.168.56.101:8080 to open MM in my browser. F12 shows a console where you can filter for errors.
      Just send me the files by email ak10zeichen-xy@yahoo.de
      AxLED
      evroomE 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @AxLed
        @AxLed
        1. No timers are set right now.
        2. Here is what it came out on the console running MM into Dev mode:
        MMM-Dreambox.js:228 Uncaught TypeError: Cannot read property '0' of undefined
            at Class.socketNotificationReceived (MMM-Dreambox.js:228)
            at module.js:246
            at r.<anonymous> (socketclient.js:25)
            at r.emit (index.js:133)
            at r.onevent (socket.js:270)
            at r.MMSocket.self.socket.onevent (socketclient.js:19)
            at r.onpacket (socket.js:228)
            at r.<anonymous> (index.js:21)
            at r.ondecoded (manager.js:345)
        socketNotificationReceived @ MMM-Dreambox.js:228
        (anonymous) @ module.js:246
        (anonymous) @ socketclient.js:25
        r.emit @ index.js:133
        r.onevent @ socket.js:270
        MMSocket.self.socket.onevent @ socketclient.js:19
        r.onpacket @ socket.js:228
        (anonymous) @ index.js:21
        r.ondecoded @ manager.js:345
        s.add @ index.js:241
        r.ondata @ manager.js:335
        r.onPacket @ socket.js:456
        (anonymous) @ socket.js:273
        r.onPacket @ transport.js:145
        r.onData @ transport.js:137
        ws.onmessage @ websocket.js:147
        • Cr4z33C
          Cr4z33 @evroom
          1. Perhaps stupid, but do not how to do that. Cannot open MM using the MM IP.
          Just run MM into DEV mode and in the right panel switch to the tab ‘Console’
          cd ~/MagicMirror/
          npm start dev
          • A
            Can you send me following 5 xml files: …/web/about, …/web/getallservices, …/web/timerlist, …/web/servicelistplayable, … /web/epgnow by email ak10zeichen-xy@yahoo.de
            AxLED
            Cr4z33C 1 Reply Last reply
            • evroomE
              evroom @AxLed
              @axled
              Forgot the port.
              I see this error:
              TypeError: undefined is not an object (evaluating 'json.e2servicelistrecursive.e2bouquet.e2servicelist.e2service')
              In line 229 of MMM-Dreambox.js:
              this.sender = json.e2servicelistrecursive.e2bouquet.e2servicelist.e2service;
              Mailed you the files.
              MagicMirror version: 2.37.0
              • Cr4z33C
                Cr4z33 @AxLed
                @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                AxLED
                Me?
                • A
                  @Cr4z33
                  Yes.
                  • Cr4z33C
                    Cr4z33 @AxLed
                    @axled OK gimme a minute and I send them. :winking_face:
                    A 1 Reply Last reply
                    • evroomE
                      evroom
                      “You talking to me ?” (Robert de Niro - Taxi Driver).
                      I sent the files, just in case.
                      • A
                        I sent the files
                        @evroom
                        Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
                        My “getallservices” xml only has one “bouquet”, so i checked only for one.
                        As your “getallservices” xml has three “bouquets” i changed the code.
                        If you do a git pull (master repository) it should work.
                        So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
                        AxLED
                        • A
                          AxLed Module Developer @Cr4z33
                          @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                          @Cr4z33
                          Thanks for your files, one a fast view you also have more than one bouquet in “getallservices”, so my last fix should work for you also.
                          Try agit pull (master repository).
                          AxLED
                          • evroomE
                            evroom
                            @AxLed
                            The services list now is present.
                            Next step is to stream one.
                            • Cr4z33C
                              Cr4z33 @AxLed
                              @axled the situation now is like in the below screenshot and I still don’t know how I am supposed to stream a channel (if I don’t have to specify its url). :smiling_face_with_open_mouth_cold_sweat:
                              • evroomE
                                evroom
                                All actions:
                                http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                                http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-PREV
                                http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                                http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-STOP
                                Result in:
                                Cannot GET /remote
                                • A
                                  @evroom
                                  How do you plan to interact with your MM?
                                  I have a rotary encoder. Buttons or touch is also fine.
                                  For the beginning you can use MMM-Remote-Control to send notifications.
                                  I have to complete my Readme, that the sample links only work with MMM-Remote-Control
                                  So install MMM-Remote-Control, open an browser, modify the links matching to your environment and you should be able to select channels and stream them.
                                  Important: Try with SD Channels first, as for HD channels the mpg2 codec is needed.
                                  AxLED
                                  • evroomE
                                    evroom @AxLed
                                    @axled
                                    I was about to ask about this.
                                    Suppose it works, how will I use it in practise?
                                    I have a Pi with a monitor connected hanging in the kitchen.
                                    No fancy mirror like many, with speech and buttons and PIRs.
                                    So, basically no interaction.
                                    I plan on getting speech running, but I have other projects running at this moment (for instance Homematic IP and ioBroker).
                                    I will try to install MMM-Remote-Control and see if that will work.
                                    • A
                                      @Cr4z33
                                      I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                                      Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                                      Do you have MMM-Remote-Control installed?
                                      Se my previous answer to evroom.
                                      AxLED
                                      Cr4z33C 2 Replies Last reply
                                      • Cr4z33C
                                        Cr4z33 @AxLed
                                        @axled oh now I understand.
                                        Thanks for the information.
                                        However I don’t have MMM-Remote-Control and I rather prefer to control everything by voice commands (MMM-AssistantMk2).
                                        Sorry, but then this module doesn’t suit my needs. :winking_face:
                                        • A
                                          @Cr4z33
                                          You should be able to send notifications by voice commands also.
                                          AxLED
                                          • A
                                            @evroom
                                            I have a PIR-Sensor (for turning screen on/off) and a rotary encoder connected (to the GPIO PINs of the Pi).
                                            In the bottom right corner you see my “first” module MMM-Navigate which interacts with the rotary encoder.
                                            So depending on the navigation menu i am able to:
                                            • swipe pages (i have four)
                                            • show Details to newsfeeds (opens website to the newsfeed)
                                            • adjust brightness
                                            • select dreambox channels
                                            • start/stop streaming dreambox channels
                                            • control the mirror (restart mm, shutdown, reboot)
                                            • and for the future: everything which can handle the MM notification system
                                            AxLED
                                            • 2 / 8
