    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.8k Views 6 Watching
    • A
      AxLed Module Developer @evroom
      @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
      I sent the files
      @evroom
      Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
      My “getallservices” xml only has one “bouquet”, so i checked only for one.
      As your “getallservices” xml has three “bouquets” i changed the code.
      If you do a git pull (master repository) it should work.
      So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
      AxLED
      • A
        AxLed Module Developer @Cr4z33
        @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
        @axled OK gimme a minute and I send them.
        @Cr4z33
        Thanks for your files, one a fast view you also have more than one bouquet in “getallservices”, so my last fix should work for you also.
        Try agit pull (master repository).
        AxLED
        Cr4z33C 1 Reply Last reply
        • evroomE
          evroom
          @AxLed
          The services list now is present.
          Next step is to stream one.
          MagicMirror version: 2.37.0
          • Cr4z33C
            Cr4z33 @AxLed
            @axled the situation now is like in the below screenshot and I still don’t know how I am supposed to stream a channel (if I don’t have to specify its url). :smiling_face_with_open_mouth_cold_sweat:
            • evroomE
              evroom
              All actions:
              http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
              http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-PREV
              http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
              http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-STOP
              Result in:
              Cannot GET /remote
              • A
                @evroom
                How do you plan to interact with your MM?
                I have a rotary encoder. Buttons or touch is also fine.
                For the beginning you can use MMM-Remote-Control to send notifications.
                I have to complete my Readme, that the sample links only work with MMM-Remote-Control
                So install MMM-Remote-Control, open an browser, modify the links matching to your environment and you should be able to select channels and stream them.
                Important: Try with SD Channels first, as for HD channels the mpg2 codec is needed.
                AxLED
                evroomE 1 Reply Last reply
                • evroomE
                  evroom @AxLed
                  @axled
                  I was about to ask about this.
                  Suppose it works, how will I use it in practise?
                  I have a Pi with a monitor connected hanging in the kitchen.
                  No fancy mirror like many, with speech and buttons and PIRs.
                  So, basically no interaction.
                  I plan on getting speech running, but I have other projects running at this moment (for instance Homematic IP and ioBroker).
                  I will try to install MMM-Remote-Control and see if that will work.
                  • A
                    @Cr4z33
                    I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                    Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                    Do you have MMM-Remote-Control installed?
                    Se my previous answer to evroom.
                    AxLED
                    Cr4z33C 2 Replies Last reply
                    • Cr4z33C
                      Cr4z33 @AxLed
                      @axled oh now I understand.
                      Thanks for the information.
                      However I don’t have MMM-Remote-Control and I rather prefer to control everything by voice commands (MMM-AssistantMk2).
                      Sorry, but then this module doesn’t suit my needs. :winking_face:
                      • A
                        @Cr4z33
                        You should be able to send notifications by voice commands also.
                        AxLED
                        • A
                          @evroom
                          I have a PIR-Sensor (for turning screen on/off) and a rotary encoder connected (to the GPIO PINs of the Pi).
                          In the bottom right corner you see my “first” module MMM-Navigate which interacts with the rotary encoder.
                          So depending on the navigation menu i am able to:
                          • swipe pages (i have four)
                          • show Details to newsfeeds (opens website to the newsfeed)
                          • adjust brightness
                          • select dreambox channels
                          • start/stop streaming dreambox channels
                          • control the mirror (restart mm, shutdown, reboot)
                          • and for the future: everything which can handle the MM notification system
                          AxLED
                          • evroomE
                            evroom
                            Okay, I have MMM-Remote-Control running and I can open the menu.
                            Now using:
                            I get this:
                            {"status":"success"}
                            Now I see a stream on my monitor !!
                            With DB-SERVICE-NEXT and DB-SERVICE-PREV I can scroll through the services list
                            Also gives
                            But I cannot switch to another service with DB-PLAY.
                            And I have a side effect that it takes 3 or 4 services on my Dreambox.
                            I have the plugin InfoBarTunerState installed and I see that MM is trying to stream multiple services.
                            At this moment I see one stream on my MM monitor, but my Dreambox tells me there are 2 MM streams present (on 2 different services).
                            Here the OMXPlayer processes at this moment:
                            pi@MagicPi:~/MagicMirror/modules $ ps -eaf | grep omxplayer | grep -v grep
                            pi       28431 28259  0 18:06 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                            pi       28432 28431  0 18:06 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                            pi       28455 28432 10 18:06 ?        00:02:50 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                            pi       28522 28259  0 18:15 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                            pi       28523 28522  0 18:15 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                            pi       28546 28523  3 18:15 ?        00:00:31 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
                            • evroomE
                              evroom
                              Btw, is there a possibility to have the start, next, prev and stop URL’s configured in MMM-Remote-Control ?
                              • evroomE
                                evroom
                                Okay, rebooted in order to start fresh.
                                Now 1 stream.
                                Looks like one actual omxplayer active:
                                pi       29320 29185  0 18:39 ?        00:00:00 /bin/sh -c omxplayer  --win 0,0,480,320  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                pi       29321 29320  0 18:39 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                pi       29344 29321 10 18:39 ?        00:00:01 /usr/bin/omxplayer.bin --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
                                InfoBarTunerState also states there is one stream.
                                The will do for today.
                                Will do some more testing tomorrow.
                                Thanks a lot AxLed for the support so far !!
                                • A
                                  @evroom
                                  Good to hear you had success and thanks for your challenge with more than one bouquet 😂, helped debugging the module.
                                  AxLED
                                  • evroomE
                                    evroom
                                    @AxLed
                                    I have opened 4 feature requests on GitHub.
                                    To be honest, my MM is hanging a meter or so away from the TV, so I most probably will not make use of the module.
                                    Navigating through the services list and starting & stopping a stream is not that comfortable
                                    Although it might be practical to see on my MM what is currently playing and I might use it solely as a program guide.
                                    Will be available though for some testing.
                                    • A
                                      Hi, if the to monitors are close together you can still view 2 different shows :-) .
                                      I checked your 4 feature requests and added 2 of them in the module.
                                      For the other two i can not promise, if they will be implemented.
                                      AxLED
                                      • A
                                        @evroom
                                        In your feature request, you wanted to select a bouquet (if there is more than one):
                                        Okay.
                                        Let’s say I have the bouquet “MagicMirror (TV)”, could there be an option to use this one, instead of the default “Favourites (TV)” ?
                                        I assume “Favourites (TV)” is the default.
                                        Please check the dev branch of my module.
                                        1. Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                                        2. do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                                        3. add new parameters to your config.js, as descriped in readme. (see apibouquet and listmax).
                                        Regards
                                        AxLED
                                        • evroomE
                                          evroom
                                          Hi @AxLed ,
                                          Busy trying your updated module.
                                          I am struggling a bit with it.
                                          1/ I suppose I set
                                          apibouquet: 1,
                                          Is that correct ?
                                          What does it do ?
                                          When just enabling, then why not true or false to make it more clear?
                                          Or do I set it to 1 for bouquet 1 and 2 for 2, etc?
                                          Please explain.
                                          2/ The parameter
                                          listmax: 10,
                                          is working, but after play or stop, it jumps to the bouquet name.
                                          3/ On my install, when I do DB-PLAY, it starts the stream twice.
                                          So, I have 2 omxplayer process-sets and it takes up 2 streams on my Dreambox.
                                          EDIT: now streaming Das Erste HD. No other process-sets present.
                                          Perhaps decoding takes to long and omxplayer is respawning.
                                          4/ Even though I have employer processes, I do not see anything on my screen.
                                          I think I have a local issue, as I cannot stream decoded content anymore.
                                          My MPG2 license is still valid.
                                          Perhaps a performance issue.
                                          • evroomE
                                            evroom
                                            Example for observation/issue 3:
                                            DB-PLAY:
                                            pi        4190  4061  0 19:31 ?        00:00:00 /bin/sh -c omxplayer  --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                            pi        4191  4190  0 19:31 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                            pi        4214  4191  7 19:31 ?        00:00:00 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                            pi        4222  4061  0 19:31 ?        00:00:00 /bin/sh -c omxplayer  --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                            pi        4223  4222  0 19:31 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                            pi        4246  4223 13 19:31 ?        00:00:00 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                            After a few seconds and when the stream is visible on the screen:
                                            pi        4214  4191 10 19:31 ?        00:00:02 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                            • 2 / 8
