    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 225.1k Views 6 Watching
    • A
      AxLed Module Developer
      @evroom
      I have a PIR-Sensor (for turning screen on/off) and a rotary encoder connected (to the GPIO PINs of the Pi).
      In the bottom right corner you see my “first” module MMM-Navigate which interacts with the rotary encoder.
      So depending on the navigation menu i am able to:
      • swipe pages (i have four)
      • show Details to newsfeeds (opens website to the newsfeed)
      • adjust brightness
      • select dreambox channels
      • start/stop streaming dreambox channels
      • control the mirror (restart mm, shutdown, reboot)
      • and for the future: everything which can handle the MM notification system
      AxLED
      • evroomE
        evroom
        Okay, I have MMM-Remote-Control running and I can open the menu.
        Now using:
        http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
        I get this:
        {"status":"success"}
        Now I see a stream on my monitor !!
        With DB-SERVICE-NEXT and DB-SERVICE-PREV I can scroll through the services list
        Also gives
        But I cannot switch to another service with DB-PLAY.
        And I have a side effect that it takes 3 or 4 services on my Dreambox.
        I have the plugin InfoBarTunerState installed and I see that MM is trying to stream multiple services.
        At this moment I see one stream on my MM monitor, but my Dreambox tells me there are 2 MM streams present (on 2 different services).
        Here the OMXPlayer processes at this moment:
        pi@MagicPi:~/MagicMirror/modules $ ps -eaf | grep omxplayer | grep -v grep
        pi       28431 28259  0 18:06 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
        pi       28432 28431  0 18:06 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
        pi       28455 28432 10 18:06 ?        00:02:50 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
        pi       28522 28259  0 18:15 ?        00:00:00 /bin/sh -c omxplayer  --win 320,180,1600,900  -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
        pi       28523 28522  0 18:15 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
        pi       28546 28523  3 18:15 ?        00:00:31 /usr/bin/omxplayer.bin --win 320,180,1600,900 -o both http://192.168.178.28:8001/1:0:16:36F8:C8C:3:EB0000:0:0:0:
        MagicMirror version: 2.37.0
        • evroomE
          evroom
          Btw, is there a possibility to have the start, next, prev and stop URL’s configured in MMM-Remote-Control ?
          • evroomE
            evroom
            Okay, rebooted in order to start fresh.
            Now 1 stream.
            Looks like one actual omxplayer active:
            pi       29320 29185  0 18:39 ?        00:00:00 /bin/sh -c omxplayer  --win 0,0,480,320  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
            pi       29321 29320  0 18:39 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
            pi       29344 29321 10 18:39 ?        00:00:01 /usr/bin/omxplayer.bin --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
            InfoBarTunerState also states there is one stream.
            The will do for today.
            Will do some more testing tomorrow.
            Thanks a lot AxLed for the support so far !!
            • A
              @evroom
              Good to hear you had success and thanks for your challenge with more than one bouquet 😂, helped debugging the module.
              AxLED
              • evroomE
                evroom
                @AxLed
                I have opened 4 feature requests on GitHub.
                To be honest, my MM is hanging a meter or so away from the TV, so I most probably will not make use of the module.
                Navigating through the services list and starting & stopping a stream is not that comfortable
                Although it might be practical to see on my MM what is currently playing and I might use it solely as a program guide.
                Will be available though for some testing.
                • A
                  Hi, if the to monitors are close together you can still view 2 different shows :-) .
                  I checked your 4 feature requests and added 2 of them in the module.
                  For the other two i can not promise, if they will be implemented.
                  AxLED
                  • A
                    @evroom
                    In your feature request, you wanted to select a bouquet (if there is more than one):
                    Okay.
                    Let’s say I have the bouquet “MagicMirror (TV)”, could there be an option to use this one, instead of the default “Favourites (TV)” ?
                    I assume “Favourites (TV)” is the default.
                    Please check the dev branch of my module.
                    1. Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                    2. do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                    3. add new parameters to your config.js, as descriped in readme. (see apibouquet and listmax).
                    Regards
                    AxLED
                    • evroomE
                      evroom
                      Hi @AxLed ,
                      Busy trying your updated module.
                      I am struggling a bit with it.
                      1/ I suppose I set
                      apibouquet: 1,
                      Is that correct ?
                      What does it do ?
                      When just enabling, then why not true or false to make it more clear?
                      Or do I set it to 1 for bouquet 1 and 2 for 2, etc?
                      Please explain.
                      2/ The parameter
                      listmax: 10,
                      is working, but after play or stop, it jumps to the bouquet name.
                      3/ On my install, when I do DB-PLAY, it starts the stream twice.
                      So, I have 2 omxplayer process-sets and it takes up 2 streams on my Dreambox.
                      EDIT: now streaming Das Erste HD. No other process-sets present.
                      Perhaps decoding takes to long and omxplayer is respawning.
                      4/ Even though I have employer processes, I do not see anything on my screen.
                      I think I have a local issue, as I cannot stream decoded content anymore.
                      My MPG2 license is still valid.
                      Perhaps a performance issue.
                      • evroomE
                        evroom
                        Example for observation/issue 3:
                        DB-PLAY:
                        pi        4190  4061  0 19:31 ?        00:00:00 /bin/sh -c omxplayer  --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                        pi        4191  4190  0 19:31 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                        pi        4214  4191  7 19:31 ?        00:00:00 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                        pi        4222  4061  0 19:31 ?        00:00:00 /bin/sh -c omxplayer  --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                        pi        4223  4222  0 19:31 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                        pi        4246  4223 13 19:31 ?        00:00:00 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                        After a few seconds and when the stream is visible on the screen:
                        pi        4214  4191 10 19:31 ?        00:00:02 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                        • A
                          @evroom
                          here are some questions:
                          to 1: apibouquet expects a number (integer) and in java it starts with 0. If i use the xml-sample file of /web/getallservices you send me its in your case as follows:
                          0: Favourites (TV)
                          1: Nederland (TV)
                          2: Duitsland (TV)
                          to 2: i cant reproduce this behavior
                          to 3 & 4: try disabling some other modules, to find out if there is a intolerance beetween modules.
                          AxLED
                          • evroomE
                            evroom
                            to 1: thanks. Very clear.
                            to 2: does not happen always, or too fast to detect (I did ps manually).
                            to 3: did this, but does not help. I have think I have an issue that is related to my install only.
                            Thanks for the changes. It makes it more usable.
                            • Cr4z33C
                              Cr4z33 @AxLed
                              @axled I want to give this module another try for some testing, but I still didn’t understand how am I supposed to stream a Dreambox channel in MM? :hushed_face:
                              • Cr4z33C
                                Cr4z33 @AxLed
                                @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                @Cr4z33
                                I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                                Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                                Do you have MMM-Remote-Control installed?
                                Se my previous answer to evroom.
                                AxLED
                                WHERE do I have to enter these commands?
                                In a RPI terminal window?
                                In my ie. Windows 10 Internet browser address box?
                                • A
                                  @Cr4z33
                                  As you have MMM-Remote-Control installed you can test MMM-Dreambox with MMM-Remote-Control first, to make sure it works at all. (Requirement: Your mirror is reachable by browser in the same network). Open browser and enter (without the spaces around &):
                                  • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-SERVICE-NEXT (for selecting next service)
                                  • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-SERVICE-PREV (for selecting prev.service)
                                  • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-PLAY (for start streaming)
                                  • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-STOP (for stop streaming)
                                  Hint: HD Services need MPG License so maybe start with SD services.
                                  You can also try the dev branch, as this is the newer one with more functions.
                                  AxLED
                                  • Cr4z33C
                                    Cr4z33 @AxLed
                                    @axled thanks got the remote module working, but then when I send the commands (succesfully confirmed by the web page) I see no streaming going on in MM.
                                    By the way I choosed to install the dev branch of your module.
                                    • A
                                      @Cr4z33
                                      Can you show me the MMM-Dreambox Part of your config and some logs?
                                      Playing does not work, is selecting DB-SERVICE-NEXT (PREV) working?
                                      AxLED
                                      • Cr4z33C
                                        Cr4z33 @AxLed
                                        @axled this is the config part:
                                        			module: 'MMM-Dreambox',
                                        			header: 'Vu+ Duo²',
                                        			position: 'bottom_left',
                                        			disabled: false,
                                        				apiBase: 'http://*.*.*.*:****',
                                        				omxargs: ' --win 320,180,1600,900  -o both ',
                                        				refreshInterval: 1000 * 30, //refresh every 30 seconds
                                        				apiabout: '/web/about',
                                        				apiservices: '/web/getallservices',
                                        				apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                                        				apizap: '/web/zap?sRef=',
                                        				apiTimerlist: '/web/timerlist',
                                        				apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet'
                                        I wanted then to paste here the logs and what was happening when sendings commands, but all I get now is
                                        status	"error"
                                        reason	"unknown_command"
                                        info	"original input: {\"action\":\"NOTIFICATION \",\" notification\":\"DB-PLAY\"}"
                                        I feel like I am missing something? :smiling_face_with_open_mouth_cold_sweat:
                                        This is btw the MMM-Remote-Control config part:
                                        			module: 'MMM-Remote-Control',
                                        • A
                                          @Cr4z33
                                          it is not easy to give support, with this less informations.
                                          As you send me .xml files some days ago, i saw some minor errors in your config.js
                                          1. apibouquet and listmax is missing, so module use defaults (apibouquet: 0, listmax: 15)
                                          2. apiepgnow and apiServicelistplayable are wrong, to match to your receiver/xml file you send me the should look as follows:
                                          • apiepgnow: ‘/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.TerrestrialTv.tv%22%20ORDER%20BY%20bouquet’,
                                          • apiServicelistplayable: ‘/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.TerrestrialTv.tv%22%20ORDER%20BY%20bouquet’,
                                          Can you please also answer my question:
                                          To help you further i need some screenshots of the module on your mirror and some logs (pm2 or from the browser by using F12).
                                          AxLED
                                          • Cr4z33C
                                            Cr4z33 @AxLed
                                            @axled sorry for the late reply. :smiling_face_with_open_mouth_cold_sweat:
                                            I’ve installed your module from scratch and now every MMM-Remote-Control command (but streaming) is working.
                                            Honestly I can’t understand what is wrong because before going to use my decoder with your module all Dreambox-like applications worked like a charm.
                                            What if it depends on using a different WebIf port (I am not using the default 80/8080 port)?
                                            And even if why not?
                                            So far every Android Dreambox app (ie. DreamDroid) or Windows channel editor program for Dreambox that I’ve used worked perfectly.
                                            • 3 / 8
