    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 189.9k Views 6 Watching
    • Cr4z33C Offline
      Cr4z33 @AxLed
      @axled OK gimme a minute and I send them. :winking_face:
      • evroomE Offline
        evroom
        “You talking to me ?” (Robert de Niro - Taxi Driver).
        I sent the files, just in case.
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
          AxLed Module Developer @evroom
          @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
          I sent the files
          @evroom
          Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
          My “getallservices” xml only has one “bouquet”, so i checked only for one.
          As your “getallservices” xml has three “bouquets” i changed the code.
          If you do a git pull (master repository) it should work.
          So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
          AxLED
            AxLed Module Developer @Cr4z33
            @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
            @Cr4z33
            Thanks for your files, one a fast view you also have more than one bouquet in “getallservices”, so my last fix should work for you also.
            Try agit pull (master repository).
            AxLED
            • evroomE Offline
              evroom
              @AxLed
              The services list now is present.
              Next step is to stream one.
              Test environment:
              • Cr4z33C Offline
                Cr4z33 @AxLed
                @axled the situation now is like in the below screenshot and I still don’t know how I am supposed to stream a channel (if I don’t have to specify its url). :smiling_face_with_open_mouth_cold_sweat:
                • evroomE Offline
                  evroom
                  All actions:
                  http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                  http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-PREV
                  http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                  http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-STOP
                  Result in:
                  Cannot GET /remote
                  Test environment:
                    @evroom
                    How do you plan to interact with your MM?
                    I have a rotary encoder. Buttons or touch is also fine.
                    For the beginning you can use MMM-Remote-Control to send notifications.
                    I have to complete my Readme, that the sample links only work with MMM-Remote-Control
                    So install MMM-Remote-Control, open an browser, modify the links matching to your environment and you should be able to select channels and stream them.
                    Important: Try with SD Channels first, as for HD channels the mpg2 codec is needed.
                    AxLED
                    • evroomE Offline
                      evroom @AxLed
                      @axled
                      I was about to ask about this.
                      Suppose it works, how will I use it in practise?
                      I have a Pi with a monitor connected hanging in the kitchen.
                      No fancy mirror like many, with speech and buttons and PIRs.
                      So, basically no interaction.
                      I plan on getting speech running, but I have other projects running at this moment (for instance Homematic IP and ioBroker).
                      I will try to install MMM-Remote-Control and see if that will work.
                      Test environment:
                        @Cr4z33
                        I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                        Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                        Do you have MMM-Remote-Control installed?
                        Se my previous answer to evroom.
                        AxLED
                        Cr4z33C 2 Replies Last reply Reply Quote 0
                        • 15
                        • 16
                        • 3 / 16
