    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 225.2k Views 6 Watching
    • evroomE
      evroom @evroom
      I see in your code that the HTML requests are successful (status code 200), so next step is to determine if the parsing was successful.
      I know how json parsing works using Perl, but in MM context I have no clue, so I am not much of help there.
      MagicMirror version: 2.37.0
      • A
        AxLed Module Developer @Cr4z33
        @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
        maybe I am misunderstanding everything, but I need to understand whether it’s just a Dreambox information module or whether I can actually stream into an omxplayer iframe?
        @Cr4z33
        Its an entertainment module, means it show informations of your receiver and you can stream the channels with the omxplayer as overlay on your monitor (monitor must be local connected to pi). The displayed informations are needed to control the dreambox/receiver.
        Your config looks ok.
        Can you please answer following questions:
        1. do you have timers in your receiver (can be checked by http://IPofyourReceiver/web/timerlist)?
        2. what if you open MM in a browser in the same network and use F12. Are there any errors?
        AxLED
        • A
          @evroom
          I think we are getting closer to a working module.
          The 5 requests are successful, so config should be ok.
          3. Can you send me following 5 xml files: …/web/about, …/web/getallservices, …/web/timerlist, …/web/servicelistplayable, … /web/epgnow
          After this i can modifiy the node_helper.js of development branch for further debugging.
          AxLED
          evroomE Cr4z33C 2 Replies Last reply
          • evroomE
            evroom @AxLed
            @axled
            1. Yes
            2. Perhaps stupid, but do not how to do that. Cannot open MM using the MM IP.
            3. Yes. Probably by pm.
            evroomE A Cr4z33C 3 Replies Last reply
            • evroomE
              evroom @evroom
              Can only upload pictures.
              Do not see a pm option.
              Hate it when you need to solve problems before you can solve problems.
              • A
                AxLed Module Developer @evroom
                @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                My MM config.js for IP looks like
                config = {
                	address: "192.168.56.101",
                	port: 8080,
                	ipWhitelist: [], // Set [] to allow all IP addresses
                So can can open a browser in the same network and enter http://192.168.56.101:8080 to open MM in my browser. F12 shows a console where you can filter for errors.
                Just send me the files by email ak10zeichen-xy@yahoo.de
                AxLED
                evroomE 1 Reply Last reply
                • Cr4z33C
                  Cr4z33 @AxLed
                  @AxLed
                  1. No timers are set right now.
                  2. Here is what it came out on the console running MM into Dev mode:
                  MMM-Dreambox.js:228 Uncaught TypeError: Cannot read property '0' of undefined
                      at Class.socketNotificationReceived (MMM-Dreambox.js:228)
                      at module.js:246
                      at r.<anonymous> (socketclient.js:25)
                      at r.emit (index.js:133)
                      at r.onevent (socket.js:270)
                      at r.MMSocket.self.socket.onevent (socketclient.js:19)
                      at r.onpacket (socket.js:228)
                      at r.<anonymous> (index.js:21)
                      at r.ondecoded (manager.js:345)
                  socketNotificationReceived @ MMM-Dreambox.js:228
                  (anonymous) @ module.js:246
                  (anonymous) @ socketclient.js:25
                  r.emit @ index.js:133
                  r.onevent @ socket.js:270
                  MMSocket.self.socket.onevent @ socketclient.js:19
                  r.onpacket @ socket.js:228
                  (anonymous) @ index.js:21
                  r.ondecoded @ manager.js:345
                  s.add @ index.js:241
                  r.ondata @ manager.js:335
                  r.onPacket @ socket.js:456
                  (anonymous) @ socket.js:273
                  r.onPacket @ transport.js:145
                  r.onData @ transport.js:137
                  ws.onmessage @ websocket.js:147
                  • Cr4z33C
                    Cr4z33 @evroom
                    1. Perhaps stupid, but do not how to do that. Cannot open MM using the MM IP.
                    Just run MM into DEV mode and in the right panel switch to the tab ‘Console’
                    cd ~/MagicMirror/
                    npm start dev
                    • A
                      Can you send me following 5 xml files: …/web/about, …/web/getallservices, …/web/timerlist, …/web/servicelistplayable, … /web/epgnow by email ak10zeichen-xy@yahoo.de
                      AxLED
                      Cr4z33C 1 Reply Last reply
                      • evroomE
                        evroom @AxLed
                        @axled
                        Forgot the port.
                        I see this error:
                        TypeError: undefined is not an object (evaluating 'json.e2servicelistrecursive.e2bouquet.e2servicelist.e2service')
                        In line 229 of MMM-Dreambox.js:
                        this.sender = json.e2servicelistrecursive.e2bouquet.e2servicelist.e2service;
                        Mailed you the files.
                        • Cr4z33C
                          Cr4z33 @AxLed
                          @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                          AxLED
                          Me?
                          • A
                            @Cr4z33
                            Yes.
                            • Cr4z33C
                              Cr4z33 @AxLed
                              @axled OK gimme a minute and I send them. :winking_face:
                              A 1 Reply Last reply
                              • evroomE
                                evroom
                                “You talking to me ?” (Robert de Niro - Taxi Driver).
                                I sent the files, just in case.
                                • A
                                  I sent the files
                                  @evroom
                                  Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
                                  My “getallservices” xml only has one “bouquet”, so i checked only for one.
                                  As your “getallservices” xml has three “bouquets” i changed the code.
                                  If you do a git pull (master repository) it should work.
                                  So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
                                  AxLED
                                  • A
                                    @Cr4z33
                                    Thanks for your files, one a fast view you also have more than one bouquet in “getallservices”, so my last fix should work for you also.
                                    Try agit pull (master repository).
                                    AxLED
                                    • evroomE
                                      evroom
                                      @AxLed
                                      The services list now is present.
                                      Next step is to stream one.
                                      • Cr4z33C
                                        Cr4z33 @AxLed
                                        @axled the situation now is like in the below screenshot and I still don’t know how I am supposed to stream a channel (if I don’t have to specify its url). :smiling_face_with_open_mouth_cold_sweat:
                                        • evroomE
                                          evroom
                                          All actions:
                                          http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                                          http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-PREV
                                          http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                                          http://192.168.178.30:8080/remote?action=NOTIFICATION&notification=DB-STOP
                                          Result in:
                                          Cannot GET /remote
                                          • A
                                            @evroom
                                            How do you plan to interact with your MM?
                                            I have a rotary encoder. Buttons or touch is also fine.
                                            For the beginning you can use MMM-Remote-Control to send notifications.
                                            I have to complete my Readme, that the sample links only work with MMM-Remote-Control
                                            So install MMM-Remote-Control, open an browser, modify the links matching to your environment and you should be able to select channels and stream them.
                                            Important: Try with SD Channels first, as for HD channels the mpg2 codec is needed.
                                            AxLED
                                            • 2 / 8
