Solved Stuck at Unable to install dependencies!
How are you installing? Manually? Using the install script?
@cowboysdude Well on a fresh rasbian stretch R Pi 3 B+, I typed this in the terminal:
curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bashAnd then it runs that install until the line
“unable to install dependencies!”Hmmm I’m not sure if you can see the pic I uploaded in my post (it’s not showing up when i look at my post), but it right click in the blank spot on my original post, below the word ‘But’ and above the word ‘Any’ you can open the image in a new tab to see everything I did and where I get stuck
This post is deleted! -
@dæmoneyes said in Stuck at Unable to install dependencies!:
yes, stretch doesn’t install npm or node, which are required…
follow this
https://linuxhint.com/install_npm_debian/ -
@sdetweil Thanks! I’ve installed nodejs and npm according to that.
Now do I try installing MagicMirror with that curl script again? -
@dæmoneyes yes… best to erase the MM folder and start again
cd ~ rm -rf MagicMirror
then run the install script again
what versions of node and npm were installed
node -v
and
npm -v
@sdetweil node v8.15.0
npm v6.4.1Ok going to try to erase MM with your script now! Thank you so much for your help!
@dæmoneyes looks good (node/npm)… let us know how it goes
@sdetweil IT WORKED!!! Thank you so much for all your guidance! I found so many people online stuck with same issue, so I’ll link this topic page so everyone else can benefit from your genius too!
