    Stuck at Unable to install dependencies!
    13 Posts 4 Posters 8.0k Views 4 Watching
    • DæmonEyesD
      DæmonEyes
      So this is my first time working with a R Pi, or even any programming really. I got the Raspberry Pi 3 B+ and a 32gb micro sd card so I could finally build a smart mirror.
      I’ve been following the EASY SMART MIRROR SETUP video by Grensom on Youtube.
      But when I try to install Magic Mirror, it gets stuck at this line.
      alt text
      Any help would be very much appreciated. Also as I mentioned, I really have little clue what I’m doing so please talk to me like I’m an idiot who called up technical support haha.
      TIA
      • DæmonEyesD
        DæmonEyes
        Here is a pic of the terminal screen
        • cowboysdudeC
          How are you installing? Manually? Using the install script?
          DæmonEyesD 1 Reply Last reply
          • DæmonEyesD
            DæmonEyes @cowboysdude
            @cowboysdude Well on a fresh rasbian stretch R Pi 3 B+, I typed this in the terminal:
            curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
            And then it runs that install until the line
            “unable to install dependencies!”
            Hmmm I’m not sure if you can see the pic I uploaded in my post (it’s not showing up when i look at my post), but it right click in the blank spot on my original post, below the word ‘But’ and above the word ‘Any’ you can open the image in a new tab to see everything I did and where I get stuck
            • DæmonEyesD
              DæmonEyes
                sdetweil @DæmonEyes
                @dæmoneyes said in Stuck at Unable to install dependencies!:
                yes, stretch doesn’t install npm or node, which are required…
                follow this
                https://linuxhint.com/install_npm_debian/
                • DæmonEyesD
                  DæmonEyes @sdetweil
                  @sdetweil Thanks! I’ve installed nodejs and npm according to that.
                  Now do I try installing MagicMirror with that curl script again?
                    sdetweil @DæmonEyes
                    @dæmoneyes yes… best to erase the MM folder and start again
                    cd ~
                    rm -rf MagicMirror
                    then run the install script again
                    what versions of node and npm were installed
                    node -v
                    and
                    npm -v
                    • DæmonEyesD
                      DæmonEyes @sdetweil
                      @sdetweil node v8.15.0
                      npm v6.4.1
                      Ok going to try to erase MM with your script now! Thank you so much for your help!
                        sdetweil @DæmonEyes
                        @dæmoneyes looks good (node/npm)… let us know how it goes
                        • DæmonEyesD
                          DæmonEyes @sdetweil
                          @sdetweil IT WORKED!!! Thank you so much for all your guidance! I found so many people online stuck with same issue, so I’ll link this topic page so everyone else can benefit from your genius too!
                          • DæmonEyesD
                            DæmonEyes
                            • F
                              fulmik Project Sponsor
                              Thank you for the much needed help, ive been reading everything possible to get things going.
