    Stuck at Unable to install dependencies!
    13 Posts 4 Posters 7.6k Views 4 Watching
    • cowboysdudeC Offline
      How are you installing? Manually? Using the install script?
      DæmonEyesD 1 Reply Last reply Reply Quote 0
      • DæmonEyesD Offline
        DæmonEyes @cowboysdude
        @cowboysdude Well on a fresh rasbian stretch R Pi 3 B+, I typed this in the terminal:
        curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
        And then it runs that install until the line
        “unable to install dependencies!”
        Hmmm I’m not sure if you can see the pic I uploaded in my post (it’s not showing up when i look at my post), but it right click in the blank spot on my original post, below the word ‘But’ and above the word ‘Any’ you can open the image in a new tab to see everything I did and where I get stuck
          DæmonEyes
            sdetweil @DæmonEyes
            @dæmoneyes said in Stuck at Unable to install dependencies!:
            yes, stretch doesn’t install npm or node, which are required…
            follow this
            https://linuxhint.com/install_npm_debian/
            DæmonEyesD 1 Reply Last reply Reply Quote 1
              DæmonEyes @sdetweil
              @sdetweil Thanks! I’ve installed nodejs and npm according to that.
              Now do I try installing MagicMirror with that curl script again?
                sdetweil @DæmonEyes
                @dæmoneyes yes… best to erase the MM folder and start again
                cd ~
                rm -rf MagicMirror
                then run the install script again
                what versions of node and npm were installed
                node -v
                and
                npm -v
                  DæmonEyes @sdetweil
                  @sdetweil node v8.15.0
                  npm v6.4.1
                  Ok going to try to erase MM with your script now! Thank you so much for your help!
                    sdetweil @DæmonEyes
                    @dæmoneyes looks good (node/npm)… let us know how it goes
                      DæmonEyes @sdetweil
                      @sdetweil IT WORKED!!! Thank you so much for all your guidance! I found so many people online stuck with same issue, so I’ll link this topic page so everyone else can benefit from your genius too!
                        DæmonEyes
                        • F Offline
                          fulmik Project Sponsor
                          Thank you for the much needed help, ive been reading everything possible to get things going.
