    Stuck at Unable to install dependencies!
    13 Posts 4 Posters 8.0k Views 4 Watching
    • DæmonEyesD
      DæmonEyes @cowboysdude
      @cowboysdude Well on a fresh rasbian stretch R Pi 3 B+, I typed this in the terminal:
      curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
      And then it runs that install until the line
      “unable to install dependencies!”
      Hmmm I’m not sure if you can see the pic I uploaded in my post (it’s not showing up when i look at my post), but it right click in the blank spot on my original post, below the word ‘But’ and above the word ‘Any’ you can open the image in a new tab to see everything I did and where I get stuck
      • DæmonEyesD
        DæmonEyes
          sdetweil @DæmonEyes
          @dæmoneyes said in Stuck at Unable to install dependencies!:
          yes, stretch doesn’t install npm or node, which are required…
          follow this
          https://linuxhint.com/install_npm_debian/
          DæmonEyesD 1 Reply Last reply
          • DæmonEyesD
            DæmonEyes @sdetweil
            @sdetweil Thanks! I’ve installed nodejs and npm according to that.
            Now do I try installing MagicMirror with that curl script again?
              sdetweil @DæmonEyes
              @dæmoneyes yes… best to erase the MM folder and start again
              cd ~
              rm -rf MagicMirror
              then run the install script again
              what versions of node and npm were installed
              node -v
              and
              npm -v
              • DæmonEyesD
                DæmonEyes @sdetweil
                @sdetweil node v8.15.0
                npm v6.4.1
                Ok going to try to erase MM with your script now! Thank you so much for your help!
                  sdetweil @DæmonEyes
                  @dæmoneyes looks good (node/npm)… let us know how it goes
                  • DæmonEyesD
                    DæmonEyes @sdetweil
                    @sdetweil IT WORKED!!! Thank you so much for all your guidance! I found so many people online stuck with same issue, so I’ll link this topic page so everyone else can benefit from your genius too!
                    • DæmonEyesD
                      DæmonEyes
                      • F
                        fulmik Project Sponsor
                        Thank you for the much needed help, ive been reading everything possible to get things going.
