    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 213.1k Views 6 Watching
    • Cr4z33C Offline
      Cr4z33 @evroom
      @evroom I confirm that everything you wrote is what I am getting (succesfully) BUT the ps part which gives no output after I enter the command.
      @AxLed I ran the update and now I get continuous PLAY without interruption, but there’s still no video output on screen.
        AxLed Module Developer
        @Cr4z33
        Are you trying to stream a sd or hd channel, as hd streaming needs mpg license on the pi.
        If you dont have a mpg license try streaming a sd channel.
        AxLed
        • Cr4z33C Offline
          Cr4z33 @AxLed
          @axled I am trying to stream an HD channel, but MPEG2 license is OK.
          Normal omxplayer syntax from terminal is just fine. ;)
            Can you post your MMM-Dreambox config.
            AxLED
            • evroomE Offline
              evroom
              @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
              catching error if you want to DB-PLAY before selecting a channel: MM shows notification that no channel is selected
              I do see a white box on top of the Mirror, but I do not see the text.
              Can it be it is white text over a white background ?
              The rest is working as designed.
              MagicMirror version: 2.36.0
              • evroomE Offline
                evroom
                @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                Can you explain what you mean by this ?
                Do you see the play symbol, but no stream ?
                And a stupid question, but I made this mistake just now:
                Do you do DB-PLAY or DB-START ?
                I did DB-START and it did not work, obviously.
                But before I found out it took a while.
                • evroomE Offline
                  evroom
                  @Cr4z33
                  Can you add
                  --genlog
                  to your config.js omxargs string ?
                  Like this:
                  omxargs: ' --genlog --win 0,625,590,957 -o both ',
                  The restart mm, select a service and do DB-PLAY.
                  There should be a file generated:
                  /home/pi/MagicMirror/omxplayer.log
                  If not try to find it:
                  $ sudo find / -name omxplayer.log
                  It should have contents like this:
                  pi@MagicPi:~ $ head -25 /home/pi/MagicMirror/omxplayer.log
                  19:45:37 T:18446744073580839086   DEBUG: DllBcm: Using omx system library
                  19:45:37 T:18446744073580840432   DEBUG: DllOMX: Using omx system library
                  19:45:37 T:18446744073580841193   DEBUG: DllAvFormat: Using libavformat system library
                  19:45:37 T:18446744073580843380   DEBUG: DBus connection succeeded
                  19:45:37 T:18446744073580844574   DEBUG: Keyboard: DBus connection succeeded
                  19:45:37 T:18446744073580844794   DEBUG: OMXThread::Create - Thread with id 1857024480 started
                  19:45:37 T:18446744073580844987   DEBUG: DllAvUtilBase: Using libavutil system library
                  19:45:37 T:18446744073580845018   DEBUG: DllAvCodec: Using libavcodec system library
                  19:45:37 T:18446744073580845043   DEBUG: DllAvFormat: Using libavformat system library
                  19:45:37 T:18446744073580846429   DEBUG: COMXPlayer::OpenFile - avformat_open_input http://192.168.178.47:8001/1:0:1:6DCA:44D:1:C00000:0:0:0:
                  When no log file is generated, then I am out of options.
                  AxLed is also using a non 80 port (90), so that can’t be it.
                    @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                    There is something wrong with the MM css of notifications on some MM versions, its not my module, i think there are already solutions in the forum.
                    AxLED
                    • Cr4z33C Offline
                      Cr4z33 @evroom
                      @AxLed
                      			module: 'MMM-Dreambox',
                      			position: 'bottom_left',
                      			disabled: false,
                      			header: 'Vu+ Duo²',
                      				apiBase: 'http://vuplusip:port',
                      				omxargs: ' --genlog --win 320,180,1600,900  -o both ',
                      				refreshInterval: 1000 * 30, //refresh every 30 seconds
                      				apiabout: '/web/about',
                      				apiservices: '/web/getallservices',
                      				apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                      				apizap: '/web/zap?sRef=',
                      				apiTimerlist: '/web/timerlist',
                      				apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                      				apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices), important apiepgnow and apiServicelistplayable have to match to the selected bouquet
                      				listmax: 10
                      Exactly.
                      I see the play triangle symbol on screen, but then there’s no streaming going on and yes I play DB-PLAY (not DB-START).
                      Adding --genlog apparently does generate no log.
                      I ran sudo find / -name omxplayer.log indeed, but it gave
                      find: ‘/run/user/1000/gvfs’: Permission denied.
                      I checked that directory in the file manager and it was empty…
                      • evroomE Offline
                        evroom
                        Then it means that omxplayer, so your stream, is not being started.
                        Perhaps @AxLed can log something in the pm2 log when omxplayer is supposed to be called (the the exact command line).
                        • evroomE Offline
                          evroom
                          @Cr4z33
                          Btw, tried your config and it works using my IP and port 80.
                          Just to be sure, can you change your web IF HTTP port to 80 and try it again ?
                          And you do restart your MM after every change, right ?
                          I think you do, but just to rule it out.
                          • Cr4z33C Offline
                            Cr4z33 @evroom
                            @evroom thanks for your suggestion, but honestly I don’t want to change to default port.
                            Even if it was working I don’t feel save because I use the Vu+ through DDNS service when I am out of home. ;)
                            • evroomE Offline
                              evroom
                              I just tested port 137.
                              Works just fine.
                              As expected, but you never know.
                              • Cr4z33C Offline
                                Cr4z33 @evroom
                                @evroom hmm I wonder what the hell can it be then? :smiling_face_with_open_mouth_cold_sweat:
                                MPEG2 License is OK, normal command line omxplayer streaming is OK, I am out of ideas too… :confounded_face:
                                Can you send me please by private chat the WHOLE module config you are using?
                                Let’s see if there’s any difference in it.
                                  @Cr4z33
                                  Is the IP of your VU receiver from internal Lan or external (DDNS)?
                                  AxLED
                                  • Cr4z33C Offline
                                    Cr4z33 @AxLed
                                    @AxLed it’s an internal LAN IP address.
                                    • Cr4z33C Offline
                                      Cr4z33
                                      @AxLed I tried @evroom 's module config, but it keeps not streaming.
                                      • evroomE Offline
                                        evroom
                                        @Cr4z33
                                        Try this:
                                        $ cd ~/MagicMirror/modules/MMM-Dreambox/
                                        $ cp -p node_helper.js node_helper.js.orig
                                        $ vi node_helper.js
                                        Locate:
                                        exec('omxplayer '
                                        Append this line:
                                        console.log('DB-PLAY(1): omxplayer '+self.config.omxargs+self.trimPort(self.config.apiBase)+':8001/'+payload[0]);
                                        Locate next:
                                        exec('omxplayer '
                                        Append this line:
                                        console.log('DB-PLAY(2): omxplayer '+self.config.omxargs+self.trimPort(self.config.apiBase)+':8001/'+payload[0]);
                                        $ pm2 restart mm
                                        $ pm2 logs
                                        Select a service and play that service:
                                        http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                                        http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                                        In pm2 logs should appear:
                                        0|mm  | DB-PLAY(1): omxplayer  --genlog --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                        or:
                                        0|mm  | DB-PLAY(2): omxplayer  --genlog --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                        In my case I see DB-PLAY(2).
                                        If you see nothing then it is back to the drawing board.
                                        Need to see what works and what not and where in the code.
                                        Cr4z33C 3 Replies Last reply Reply Quote 0
                                        • Cr4z33C Offline
                                          Cr4z33 @evroom
                                          @evroom thanks I will try later today.
                                          • Cr4z33C Offline
                                            Cr4z33 @evroom
                                            @evroom there are two instances of
                                            exec('omxplayer '
                                            one at line 40 and one at line 45.
                                            What shall I do?
                                            • 7 / 8
