    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.6k Views 6 Watching
    • evroomE
      evroom
      @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
      catching error if you want to DB-PLAY before selecting a channel: MM shows notification that no channel is selected
      I do see a white box on top of the Mirror, but I do not see the text.
      Can it be it is white text over a white background ?
      The rest is working as designed.
      MagicMirror version: 2.37.0
      • evroomE
        evroom
        @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
        I ran the update and now I get continuous PLAY without interruption,
        Can you explain what you mean by this ?
        Do you see the play symbol, but no stream ?
        And a stupid question, but I made this mistake just now:
        Do you do DB-PLAY or DB-START ?
        I did DB-START and it did not work, obviously.
        But before I found out it took a while.
        Cr4z33C 1 Reply Last reply
        • evroomE
          evroom
          @Cr4z33
          Can you add
          --genlog
          to your config.js omxargs string ?
          Like this:
          omxargs: ' --genlog --win 0,625,590,957 -o both ',
          The restart mm, select a service and do DB-PLAY.
          There should be a file generated:
          /home/pi/MagicMirror/omxplayer.log
          If not try to find it:
          $ sudo find / -name omxplayer.log
          It should have contents like this:
          pi@MagicPi:~ $ head -25 /home/pi/MagicMirror/omxplayer.log
          19:45:37 T:18446744073580839086   DEBUG: DllBcm: Using omx system library
          19:45:37 T:18446744073580840432   DEBUG: DllOMX: Using omx system library
          19:45:37 T:18446744073580841193   DEBUG: DllAvFormat: Using libavformat system library
          19:45:37 T:18446744073580843380   DEBUG: DBus connection succeeded
          19:45:37 T:18446744073580844574   DEBUG: Keyboard: DBus connection succeeded
          19:45:37 T:18446744073580844794   DEBUG: OMXThread::Create - Thread with id 1857024480 started
          19:45:37 T:18446744073580844987   DEBUG: DllAvUtilBase: Using libavutil system library
          19:45:37 T:18446744073580845018   DEBUG: DllAvCodec: Using libavcodec system library
          19:45:37 T:18446744073580845043   DEBUG: DllAvFormat: Using libavformat system library
          19:45:37 T:18446744073580846429   DEBUG: COMXPlayer::OpenFile - avformat_open_input http://192.168.178.47:8001/1:0:1:6DCA:44D:1:C00000:0:0:0:
          When no log file is generated, then I am out of options.
          AxLed is also using a non 80 port (90), so that can’t be it.
          • A
            AxLed Module Developer
            @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
            There is something wrong with the MM css of notifications on some MM versions, its not my module, i think there are already solutions in the forum.
            AxLED
            • Cr4z33C
              Cr4z33 @evroom
              @AxLed
              			module: 'MMM-Dreambox',
              			position: 'bottom_left',
              			disabled: false,
              			header: 'Vu+ Duo²',
              				apiBase: 'http://vuplusip:port',
              				omxargs: ' --genlog --win 320,180,1600,900  -o both ',
              				refreshInterval: 1000 * 30, //refresh every 30 seconds
              				apiabout: '/web/about',
              				apiservices: '/web/getallservices',
              				apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
              				apizap: '/web/zap?sRef=',
              				apiTimerlist: '/web/timerlist',
              				apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
              				apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices), important apiepgnow and apiServicelistplayable have to match to the selected bouquet
              				listmax: 10
              Exactly.
              I see the play triangle symbol on screen, but then there’s no streaming going on and yes I play DB-PLAY (not DB-START).
              Adding --genlog apparently does generate no log.
              I ran sudo find / -name omxplayer.log indeed, but it gave
              find: ‘/run/user/1000/gvfs’: Permission denied.
              I checked that directory in the file manager and it was empty…
              • evroomE
                evroom
                Then it means that omxplayer, so your stream, is not being started.
                Perhaps @AxLed can log something in the pm2 log when omxplayer is supposed to be called (the the exact command line).
                • evroomE
                  evroom
                  @Cr4z33
                  Btw, tried your config and it works using my IP and port 80.
                  Just to be sure, can you change your web IF HTTP port to 80 and try it again ?
                  And you do restart your MM after every change, right ?
                  I think you do, but just to rule it out.
                  • Cr4z33C
                    Cr4z33 @evroom
                    @evroom thanks for your suggestion, but honestly I don’t want to change to default port.
                    Even if it was working I don’t feel save because I use the Vu+ through DDNS service when I am out of home. ;)
                    • evroomE
                      evroom
                      I just tested port 137.
                      Works just fine.
                      As expected, but you never know.
                      • Cr4z33C
                        Cr4z33 @evroom
                        @evroom hmm I wonder what the hell can it be then? :smiling_face_with_open_mouth_cold_sweat:
                        MPEG2 License is OK, normal command line omxplayer streaming is OK, I am out of ideas too… :confounded_face:
                        Can you send me please by private chat the WHOLE module config you are using?
                        Let’s see if there’s any difference in it.
                        • A
                          @Cr4z33
                          Is the IP of your VU receiver from internal Lan or external (DDNS)?
                          AxLED
                          • Cr4z33C
                            Cr4z33 @AxLed
                            @AxLed it’s an internal LAN IP address.
                            • Cr4z33C
                              Cr4z33
                              @AxLed I tried @evroom 's module config, but it keeps not streaming.
                              • evroomE
                                evroom
                                @Cr4z33
                                Try this:
                                $ cd ~/MagicMirror/modules/MMM-Dreambox/
                                $ cp -p node_helper.js node_helper.js.orig
                                $ vi node_helper.js
                                Locate:
                                exec('omxplayer '
                                Append this line:
                                console.log('DB-PLAY(1): omxplayer '+self.config.omxargs+self.trimPort(self.config.apiBase)+':8001/'+payload[0]);
                                Locate next:
                                exec('omxplayer '
                                Append this line:
                                console.log('DB-PLAY(2): omxplayer '+self.config.omxargs+self.trimPort(self.config.apiBase)+':8001/'+payload[0]);
                                $ pm2 restart mm
                                $ pm2 logs
                                Select a service and play that service:
                                http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                                http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                                In pm2 logs should appear:
                                0|mm  | DB-PLAY(1): omxplayer  --genlog --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                or:
                                0|mm  | DB-PLAY(2): omxplayer  --genlog --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                In my case I see DB-PLAY(2).
                                If you see nothing then it is back to the drawing board.
                                Need to see what works and what not and where in the code.
                                Cr4z33C 3 Replies Last reply
                                • Cr4z33C
                                  Cr4z33 @evroom
                                  @evroom thanks I will try later today.
                                  • Cr4z33C
                                    Cr4z33 @evroom
                                    @evroom there are two instances of
                                    exec('omxplayer '
                                    one at line 40 and one at line 45.
                                    What shall I do?
                                    • evroomE
                                      evroom
                                      What shall I do?
                                      After both lines you need to put the console.log line, one with (1) and one with (2), see my post:
                                      Locate:
                                      exec('omxplayer '
                                      Append this line:
                                      Locate next:
                                      exec('omxplayer '
                                      Append this line:
                                      • Cr4z33C
                                        Cr4z33 @evroom
                                        Nothing reported into PM2 logs. :persevering_face:
                                        • evroomE
                                          evroom
                                          @Cr4z33
                                          That explains the missing stream.
                                          You are not getting to the DB-PLAY routine.
                                          To me it looks like you have an issue with MMM-Remote-Control.
                                          For example, I almost always get success, provide the IP is right, but the notification can be wrong
                                          {"status":"success"}
                                          Can you try this:
                                          $ cd /home/pi/MagicMirror/modules/MMM-Remote-Control
                                          $ git pull
                                          $ git status
                                          $ npm install
                                          And then restart mm and try again.
                                          You can also put a debug line in the DB-STOP call and do
                                          http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-STOP
                                          $ vi node_helper.js
                                                          if (notification === "DB-STOP") {
                                          console.log('DB-STOP: stop the stream');
        exec('pkill omxplayer', null);
                                          If you do not see this in the pm2 logs, then MMM-Remote-Control seems to be the culprit or the communication between the 2 modules.
                                          But as it works for both AxLed and me …
                                          • Cr4z33C
                                            Cr4z33 @evroom
                                            @evroom oh wait what version of MMM-Remote-Control are you using? 🤔
                                            The original developer (cannot remember the name sorry) one or the new one made by shbatm?
                                            evroomE 1 Reply Last reply
                                            • 7 / 8
