Unsolved Installation
Well. I thought I’d finished. It shut down and wouldn’t start up. So I rebooted the pi and now it wants a password. It wont recognise raspberry and I haven’t set one. Seriously never thought this would be so difficult.
@jonathane haven’t set one… then just hit enter…
but the base PI os install usually has a password… try 'pi ’ too
@sdetweil thanks nothing worked. Very odd. Back to the drawing board.
@jonathane what OS image did u use for memory card?
@sdetweil Raspian. I 're flashed the card and have it going again but can find a way to stop it from “sleeping” I tried some script but it didn’t work. Any idea?
@jonathane u mean screensaver?
@sdetweil yes
Personally, I would install xscreensaver and use that to disable the screensaver.
In your terminal
sudo apt-get install xscreensaver
THEN
sudo reboot
Run xscreensaver. Choose Disable Screensaver. Done.
@mykle1 will give it a go, thanks
I just got magic mirror downloaded but when i launch it it gives me an error
“WARNING! Can not find a config file” then launches and says “MagicMirror2 ‘Please create a config file’ if you have a config file use javascript linter to validate your file” Pls help!:frowning_face:
