    Installation
    24 Posts 7 Posters 12.0k Views 7 Watching
    • L
      leroyhab
      Hello Jonathane.
      your installation errors were like this ?
      https://forum.magicmirror.builders/topic/9632/absolute-beginner-needing-help-installing-dependencies
      What did you do to resolve your installation issues?
      Best regards
      K 1 Reply Last reply
        jonathane
        Well. I thought I’d finished. It shut down and wouldn’t start up. So I rebooted the pi and now it wants a password. It wont recognise raspberry and I haven’t set one. Seriously never thought this would be so difficult.
          sdetweil @jonathane
          @jonathane haven’t set one… then just hit enter…
          but the base PI os install usually has a password… try 'pi ’ too
          J 1 Reply Last reply
            jonathane @sdetweil
            @sdetweil thanks nothing worked. Very odd. Back to the drawing board.
              sdetweil @jonathane
              @jonathane what OS image did u use for memory card?
                jonathane @sdetweil
                @sdetweil Raspian. I 're flashed the card and have it going again but can find a way to stop it from “sleeping” I tried some script but it didn’t work. Any idea?
                  sdetweil @jonathane
                  @jonathane u mean screensaver?
                    jonathane @sdetweil
                    @sdetweil yes
                    Mykle1M 1 Reply Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @jonathane
                      @jonathane
                      Personally, I would install xscreensaver and use that to disable the screensaver.
                      In your terminal
                      sudo apt-get install xscreensaver
                      THEN
                      sudo reboot
                      Run xscreensaver. Choose Disable Screensaver. Done.
                        jonathane @Mykle1
                        @mykle1 will give it a go, thanks
                        • K
                          kdavis @leroyhab
                          I just got magic mirror downloaded but when i launch it it gives me an error
                          “WARNING! Can not find a config file” then launches and says “MagicMirror2 ‘Please create a config file’ if you have a config file use javascript linter to validate your file” Pls help!:frowning_face:
                          lavolp3L S 2 Replies Last reply
                          • lavolp3L
                            lavolp3 Module Developer @kdavis
                            @kdavis Have you done what is described in the README and copied the config.js.sample to a config.js file?
                            How to troubleshoot modules
                            MMM-soccer v2, MMM-AVStock
                              sdetweil @kdavis
                              @kdavis the instructions say to copy the sample over to config. js in the config folder
                              • K
                                kdavis @sdetweil
                                @sdetweil thank you for the advice. My raspberry decided to turn off and i lost the program. Ill try your advice once it downloads again.
                                • K
                                  kdavis
                                  Thank you @lavolp3 and @sdetweil …IT WORKS!!!
