    MMM-NewsFeedTicker Make Banner and Scrolling Text Smaller
    25 Posts 3 Posters 13.8k Views 4 Watching
      dgregory19 @justjim1220
      @justjim1220 Can you dumb this down for me? Can those four lines go anywhere after module:? What am I putting in place of ****? I’m just learning this stuff. Thanks!
      I got the logo fixed.
      justjim1220J 2 Replies Last reply
      • justjim1220J
        justjim1220 Module Developer @dgregory19
        @dgregory19
        Sorry
        within the headline: headline.className = "bold small bright"; ****
        Change the size from what you have to small. I think I originally had it set to xlarge.
        I am working on making this a bit easier.
        Apologies!
        Jim Hallock - 1995
        • justjim1220J
          @dgregory19
          Ok, I’ve made some changes.
          If you do a git pull && npm i it will give you a warning about the changes made to your js and css files
          You can just delete those files, then do the git pull && npm i
          OR, you can just delete your NewsFeedTicker directory and re-install it
          Jim Hallock - 1995
          D 1 Reply Last reply
            @justjim1220 This is how my config looks now. I’m assuming that I need to add the, headline.className = “bold small bright”; ****
                                   disabled: false,
                                   module: "MMM-NewsFeedTicker",
                                   position: "bottom_bar",
                                   //classes: "day_scheduler",
                                       feeds: [
                                                   title: "New York Times",
                                                   url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                                                   encoding: "UTF-8", //ISO-8859-1
                                                   className: "myClass",
                                                   defaultLogo : ""
                                                   title: "USA Today",
                                                   url: "http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories",
                                                   defaultLogo : ""
                                                   title: "BBC World News",
                                                   url: "http://feeds.bbci.co.uk/news/world/rss.xml#",
                                                   defaultLogo : ""
            Thanks for helping me out with this!
            justjim1220J 1 Reply Last reply
            • justjim1220J
              @dgregory19
              No, with the update it is no longer needed, when you do the git pull && npm i it should be fixed to the right size
              Jim Hallock - 1995
              D 2 Replies Last reply
                @justjim1220 Deleted directory and did the git pull && npm. Now NewsFeedTicker isn’t working at all. It’s in config.js and looks just like it did before.
                  @justjim1220 Jim, nevermind. I got it working. Helps to put it in the modules directory. Looks great! Thanks for all your help. Now to see what else I can break. Need to learn more about how to program this stuff.
                  • justjim1220J
                    @dgregory19
                    Glad you figured it out! :slightly_smiling_face:
                    I have made that mistake many times, probably everyone has at some point I suppose. :winking_face:
                    Jim Hallock - 1995
                      @justjim1220 Quick question, would you know if there is a news feed for the Harvard Bussness Review?
                      justjim1220J cowboysdudeC 3 Replies Last reply
                      • justjim1220J
                        @dgregory19
                        It looks like you have to be a subscriber to the site
                        Jim Hallock - 1995
                        • cowboysdudeC
                          cowboysdude Module Developer @dgregory19
                          @dgregory19 said in MMM-NewsFeedTicker Make Banner and Scrolling Text Smaller:
                          Yes there is…it’s in xml format and it’s right here:
                          http://feeds.hbr.org/harvardbusiness
                          • justjim1220J
                            justjim1220 Module Developer @cowboysdude
                            @cowboysdude
                            I found that also, and I could not get it to work
                            Further research showed you have to be a subscriber to receive the RSS feeds
                            Jim Hallock - 1995
                            • cowboysdudeC
                              cowboysdude Module Developer @justjim1220
                              @justjim1220 said in MMM-NewsFeedTicker Make Banner and Scrolling Text Smaller:
                              @cowboysdude
                              Really because it seems to work fine for me…in the stock news reader…
                              • justjim1220J
                                @cowboysdude
                                Is this the link you used?
                                Jim Hallock - 1995
                                • cowboysdudeC
                                  What do you think? If it’s not working in your module then something is wrong with your module…
                                  • cowboysdudeC
                                    I literally in 15 minutes had this working… using an old module I wrote… no css but proof of concept…
                                    • justjim1220J
                                      @cowboysdude
                                      Then there is something wrong with my module I guess
                                      Apologies for the misinformation
                                      I will look into it further
                                      Thanks CBD for the follow-up
                                      Jim Hallock - 1995
                                      • justjim1220J
                                        @dgregory19
                                        Apologies for the misinformation regarding your question
                                        Although this question seemed to be in regard to this certain module, apparently, it does not work for some reason within this module.
                                        I will look further into this issue and see what would be the difference
                                        Again, I am sorry I gave you incorrect information regarding the feed for HBR
                                        Jim Hallock - 1995
                                        • cowboysdudeC
                                          @dgregory19 Yes it will work. If you have any issues please let me know I’ll be happy to help.
                                          • justjim1220J
                                            @dgregory19
                                            Yes, Talk to cowboysdude about this as he knows more about all this than I do
                                            Yes, I realize that your question was asked in reference to the module I created and not to any other module
                                            But apparently, even though it doesn’t work in my module, I am wrong to misinform you with the answer I gave you
                                            No, I did not test it in any other module, because the question was regarding this module.
                                            As I said, I will look into why it is not working in this module and I will let you know if I get it working.
                                            Thanks for your interest and I do apologize for any inconveniences I may have caused anyone!
                                            Jim Hallock - 1995
