    Config error
    13 Posts 5 Posters 4.6k Views 3 Watching
    • Cr4z33C Offline
      Cr4z33
      While editing my modules I might have deleted or forgotten some brackets or commas. 🤦🏽‍♂️
      I can’t figure out what is wrong so can someone here please help me?
       Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: [], // Set [] to allow all IP addresses
      	language: "it",
      	timeFormat: 24,
      	units: "metric",
      			module: 'MMM-Logging',
      			disabled: false,
      			// Module functions out of the box with nothing set here.
      			// See below for configurable options.
      			module: 'MMM-Remote-Control',
      			// position: 'bottom_left',
      			disabled: false
      			module: "MMM-RTSPStream",
      			position: "bottom_left",
      			disabled: false,
      				autoStart: false,
      				rotateStreams: true,
      				rotateStreamTimeout: 0,
      				shutdownDelay: 0,
      				moduleWidth: 440,
      				moduleHeight: 247,
      				// moduleOffset: {
      				//		left: -330,
      				//		top: -180
      				localPlayer: 'omxplayer',
      				remotePlayer: 'none',
      				showSnapWhenPaused: false,
      				remoteSnaps: false,
      				stream1: {
      						url: 'http://****/1:0:1:5:7918:217C:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						frameRate: 'undefined',
      						width: 440,
      						height: 247
      				stream2: {
      						name: 'Rai 3 HD',
      						url: 'http://****/1:0:1:2191:5:13E:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream3: {
      						name: 'Rai 3 TGR Puglia',
      						url: 'http://****/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream4: {
      						name: 'Deejay TV HD',
      						url: 'http://****/1:0:1:29:7918:217C:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream5: {
      						url: 'http://****/1:0:2:9:204:1D:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream6: {
      						name: 'Radio Capital',
      						url: 'http://****/1:0:2:A:204:1D:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      				stream7: {
      						url: 'http://****/1:0:2:1FA7:32A:110:EEEE0000:0:0:0:',
      						protocol: "tcp",
      						width: 440,
      						height: 247
      			module: "alert",
      				alert_effect: "genie",
      				effect: "genie"
      			module: "updatenotification",
      			position: "top_bar"
      			module: "newsfeed",
      			position: "bottom_bar",
      			disabled: false,
      				feeds: [
      						title: "Cambio Euro/Dollaro",
      						url: "https://eur.fxexchangerate.com/usd.xml",
      						encoding: "ISO-8859-16"
      						title: "Agenzia ANSA - Ultima Ora",
      						url: "https://www.ansa.it/sito/notizie/topnews/topnews_rss.xml",
      						title: "Agenzia ANSA - Mondo",
      						url: "https://www.ansa.it/sito/notizie/mondo/mondo_rss.xml"
      						title: "Hardware Upgrade",
      						url: "https://feeds.hwupgrade.it/rss_hwup.xml",
      						title: "HDblog.it",
      						url: "http://feeds.feedburner.com/hd-blog?format=xml"
      						title: "Tom's Hardware",
      						url: "https://www.tomshw.it/feed/"
      						title: "LeccePrima",
      						url: "http://www.lecceprima.it/rss/"
      				showSourceTitle: true,
      				showPublishDate: true,
      				showDescription: true,
      				wrapTitle: false
      			module: "MMM-AssistantMk2",
      			position: "top_bar",
      			disabled: false,
      					//onIdle: {
      					//		timer: 1000*10, //After 10sec of last query,
      					//		command: "RTSP_ACTIVATE"
      					onActivate: {
      							timer: 0,
      							command: "RTSP_DEACTIVATE"
      					transcriptionHook: {
      								"CHANNEL_1": {
      										pattern: "Sky TG24",
      										command: "CHANGE_CHANNEL_1"
      								"CHANNEL_2": {
      										pattern: "Rai3",
      										command: "CHANGE_CHANNEL_2"
      								"CHANNEL_3": {
      										pattern: "Puglia",
      										// pattern: "TGR",
      										command: "CHANGE_CHANNEL_3"
      								"CHANNEL_4": {
      										pattern: "Deejay Tv",
      										command: "CHANGE_CHANNEL_4"
      								"CHANNEL_5": {
      										pattern: "Radio Deejay",
      										command: "CHANGE_CHANNEL_5"
      								"CHANNEL_6": {
      										pattern: "Radio Capital",
      										command: "CHANGE_CHANNEL_6"
      								"CHANNEL_7": {
      										pattern: "Radio 105",
      										command: "CHANGE_CHANNEL_7"
      								"PROFILE1": {
      										pattern: "Famiglia",
      										command: "CHANGE_PROFILE_1"
      								"PROFILE2": {
      										pattern: "Mio",
      										command: "CHANGE_PROFILE_2"
      					command: {
      							"CHANGE_CHANNEL_1": {
      										notificationExec: {
      													notification: "RTSP-PLAY",
      													payload: "stream1"
      							"CHANGE_CHANNEL_2": {
      										notificationExec: {
      													payload: "stream2"
      							"CHANGE_CHANNEL_3": {
      										notificationExec: {
      													payload: "stream3"
      							"CHANGE_CHANNEL_4": {
      										notificationExec: {
      													payload: "stream4"
      							"CHANGE_CHANNEL_5": {
      										notificationExec: {
      													payload: "stream5"
      							"CHANGE_CHANNEL_6": {
      										notificationExec: {
      													payload: "stream6"
      							"CHANGE_CHANNEL_7": {
      										notificationExec: {
      													payload: "stream7"
      							//"RTSP_ACTIVATE": {
      							//			notificationExec: {
      							//						notification: "RTSP-PLAY",
      							//						payload: "all"
      							"RTSP_DEACTIVATE": {
      										notificationExec: {
      													notification: "RTSP-STOP",
      													payload: "all"
      							"CHANGE_PROFILE_1": {
      										moduleExec: {
      												module:[],
      												exec: (module, params, key) => {
      																var modules = ["alert", "updatenotification", "newsfeed", "MMM-AssistantMk2", "MMM-Hotword", "clock", "MMM-MyWeather"]
      																if (modules.indexOf(module.name) >= 0) {
      																					module.show()
      																					} else {
      																					module.hide()
      							"CHANGE_PROFILE_2": {
      										moduleExec: {
      												module:[],
      																var modules = ["MMM-RTSPStream", "MMM-CalendarExt2", "alert", "updatenotification", "newsfeed", "MMM-AssistantMk2", "MMM-PushBulletNotifications", "MMM-NowPlayingOnSpotify", "MMM-Hotword", "clock", "MMM-MyWeather"]
      																					module.show()
      																					} else {
      																					module.hide()
      			record: {
      					recordProgram : "arecord",
      					device: null,
      					// device: "plughw:2,0",
      			responseScreen: false, // If available, Assistant will response with some rendered HTML
      			responseAlert: false,
      			notifications: {
      						ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
      						ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
      			deviceLocation: {
      						coordinates: {
      								latitude: ****,
      								longitude: ****
      			profiles: {
      					"default": {
      							profileFile: "default.json",
      							lang: "it-IT"
      			module: "clock",
      			disabled: false,
      				displaySeconds: false,
      				clockBold: true
      			module: 'MMM-PushBulletNotifications',
      			header: 'Notifications',
      			position: 'top_right',	// This can be any of the regions.
      			disabled: false,
      				accessToken: "****", //PushBullet API Access Token
      				numberOfNotifications: 3,
      				showPushesSentToAllDevices: true,
      				onlyAllowCommandsFromSourceDevices: [],
      				fetchLimitPushBullet: 50,
      				showPushes: true,
      				showPushesOnLoad: true,
      				showDismissedPushes: true,
      				showMirroredNotifications: true,
      				onlyShowLastNotificationFromApplication: false,
      				showIndividualNotifications: false,
      				showSMS: true,
      				showMessage: true,
      				showIcons: true,
      				showDateTime: true,
      				localesDateTime: 'it-IT',
      				playSoundOnNotificationReceived: true,
      				soundFile: 'modules/MMM-PushBulletNotifications/sounds/new-message.mp3',
      				maxMsgCharacters: 50,
      				maxHeaderCharacters: 32,
      				showModuleIfNoNotifications: false,
      				noNotificationsMessage: "Nessuna nuova notifica",
      				debugMode: false,
      			module: "MMM-NowPlayingOnSpotify",
      			disabled: false,
      				clientID: "****",
      				clientSecret: "****",
      				refreshToken: "****"
      			module: "MMM-Hotword",
      			disabled: false,
      				snowboy: [
      					hotwords: "ehi specchio", //this will be sent to other module for distinguishing which hotword is detected.
      					file: "resources/models/ehi_specchio.pmdl",
      					sensitivity: '0.5',
      					hotwords: "ok specchio",
      					file: "resources/models/ok_specchio.pmdl",
      					sensitivity: '0.5',
      				record: {
      					recordProgram: "arecord",
      					device: null,
      				autostart:true,
      				onDetected: {
      					notification: function (payload) {
      									return "ASSISTANT_ACTIVATE"
      				payload: function (payload){
      								return {
      									profile: payload.hotword
      			module: "MMM-DarkSkyForecast",
      			header: "Meteo",
      			classes: "default everyone",
      			disabled: false,
      					apikey: "****",
      					latitude: "****",
      					longitude: "****",
      					language: "it",
      					forecastHeaderText: "****",
      					label_timeFormat: "hh:mm",
      					iconset: "4c",
      					concise: false,
      					showSummary: false,
      					forecastLayout: "table"
      • justjim1220J Offline
        justjim1220 Module Developer @Cr4z33
        @cr4z33
        line 1 needs a /* at the very top left
        the output you posted tells you where to look for the errors
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          @cr4z33
          try: npm run config:check
          Jim Hallock - 1995
          Cr4z33C 2 Replies Last reply Reply Quote 0
          • Cr4z33C Offline
            Cr4z33 @justjim1220
            @justjim1220 thanks didn’t know about that. :)
            Will run it as soon as I get home.
            • BKeyportB Offline
              BKeyport Module Developer
              You have to be in the MM directory, FWIW.
              I have a script set up in my root directory:
              cd ~
              Cr4z33C 1 Reply Last reply Reply Quote 1
              • Cr4z33C Offline
                Cr4z33 @BKeyport
                @bkeyport I know it. 😜
                • Cr4z33C Offline
                  Cr4z33 @justjim1220
                  @justjim1220 the command stopped already at line 8 so I couldn’t find out where the error was.
                  pi@raspberrypi:~/MagicMirror $ npm run config:check
                  > magicmirror@2.6.0 config:check /home/pi/MagicMirror
                  > node tests/configs/check_config.js
                  Checking file...  /home/pi/MagicMirror/config/config.js
                  Line 1 col 2 Expected an assignment or function call and instead saw an expression.
                  Line 1 col 7 Missing semicolon.
                  Line 1 col 8 Expected an assignment or function call and instead saw an expression.
                  Line 1 col 14 Missing semicolon.
                  Line 1 col 15 Expected an assignment or function call and instead saw an expression.
                  Line 1 col 21 Missing semicolon.
                  Line 2 col 2 Misleading line break before '*'; readers may interpret this as an expression boundary.
                  Line 3 col 2 Expected an identifier and instead saw '*'.
                  Line 3 col 2 Expected an assignment or function call and instead saw an expression.
                  Line 3 col 3 Missing semicolon.
                  Line 3 col 4 Expected an assignment or function call and instead saw an expression.
                  Line 3 col 6 Missing semicolon.
                  Line 3 col 7 Expected an assignment or function call and instead saw an expression.
                  Line 3 col 14 Missing semicolon.
                  Line 3 col 15 Expected an assignment or function call and instead saw an expression.
                  Line 3 col 20 Missing semicolon.
                  Line 4 col 2 Label 'http' on * statement.
                  Line 4 col 2 Expected an identifier and instead saw '*'.
                  Line 4 col 2 Expected an assignment or function call and instead saw an expression.
                  Line 4 col 3 Missing semicolon.
                  Line 4 col 4 Expected an assignment or function call and instead saw an expression.
                  Line 4 col 7 Missing semicolon.
                  Line 5 col 2 Expected an identifier and instead saw '*'.
                  Line 5 col 2 Expected an assignment or function call and instead saw an expression.
                  Line 5 col 3 Missing semicolon.
                  Line 6 col 2 Expected an identifier and instead saw '*'.
                  Line 6 col 2 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 3 Missing semicolon.
                  Line 6 col 4 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 7 Missing semicolon.
                  Line 6 col 8 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 12 Missing semicolon.
                  Line 6 col 13 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 24 Missing semicolon.
                  Line 6 col 25 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 28 Missing semicolon.
                  Line 6 col 29 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 32 Missing semicolon.
                  Line 6 col 33 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 36 Missing semicolon.
                  Line 6 col 37 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 48 Missing semicolon.
                  Line 6 col 49 Expected an assignment or function call and instead saw an expression.
                  Line 6 col 53 Missing semicolon.
                  Line 7 col 2 Misleading line break before '*'; readers may interpret this as an expression boundary.
                  Line 7 col 4 Expected an assignment or function call and instead saw an expression.
                  Line 7 col 7 Missing semicolon.
                  Line 8 col 2 Label 'https' on * statement.
                  Line 9 col 2 Unbegun comment.
                  Line 8 col 2 Expected an identifier and instead saw '*'.
                  Line 8 col 2 Too many errors. (1% scanned).
                  justjim1220J 2 Replies Last reply Reply Quote 0
                    @cr4z33
                    Jim Hallock - 1995
                      @cr4z33
                      looks like the missing /* is causing all the rest of the error, fix that one and you should be good to go.
                      Jim Hallock - 1995
                      • Cr4z33C Offline
                        Cr4z33 @justjim1220
                        @justjim1220 good catch there thanks, but unfortunately I still get the config error. :disappointed_face:
                        • Cr4z33C Offline
                          Cr4z33 @justjim1220
                          @justjim1220 sorry didn’t read properly your suggestion and missed that forward slash! :smiling_face:
                          Everything is sorted now thanks again!
                          justjim1220J bheplerB 2 Replies Last reply Reply Quote 1
                            @cr4z33 glad to hear and you are fery welcome! :smiling_face_with_sunglasses:
                            Jim Hallock - 1995
                            • bheplerB Offline
                              bhepler Module Developer @Cr4z33
                              @cr4z33 - I’m glad you got it figured out. Don’t forget to mark the topic as solved!
                                showbizkid
                                This site was helpful for me. As with everything MagicMirror everyone contributes to help everyone. Just erase the code on this page and copy and paste your code to see where your errors are. Works great for me. https://jshint.com/
