    MMM-PIR-Sensor brightness
    4 Posts 3 Posters 1.6k Views 3 Watching
    • QuesadaQ Offline
      Quesada
      I installed Pir sensor module and not everything is going well. The on/off of screen works well but my problem is when i walk in front of my mirror, the brightness is very low and little by little continues to rise slowly and i don’t know why this happen.
      • BKeyportB Online
        BKeyport Module Developer
        that’s sounding like you monitor is going bad, honestly.
        PIR-Sensor just turns on and off your monitor… The rest sounds like a failing backlight.
          bolish
          There are some monitors (TV mainly) which have automatic control of the brightness (based on a sensor). Maybe it’s that.
          Was it present before PIR instalation Y/N? this can guide you.
          From MHO, PIR sensor has Nothing to do with that (but not 100% Sure).
          Regards
          QuesadaQ 1 Reply Last reply Reply Quote 0
          • QuesadaQ Offline
            Quesada @bolish
            if I don’t have the sensor activated, the brightness goes perfectly. But if it is activated and I leave a few minutes without passing in front of it, when passing has a fairly low brightness, it takes a few long seconds to regain the brightness. In a beginning I opened this thread to know if the module towards something with the brightness etc.
            But it looks like it belongs to my (old) screen, I’ll try it on a newer screen.
            Thanks you
