    MMM-CalendarExt2
    486 Posts 83 Posters 933.9k Views 83 Watching
      dmd
      @Sean First of all, thanks for the great module! We’re using it at work for car reservation calendar. Can you help me customise it? He’re the config:
                              module: "MMM-CalendarExt2",
                              position: "upper_third",
                                      calendars : [
                                      url: "https://outlook.office365.com/owa/calendar/supersecret.ics
                                      views: [
                                      mode: "weekly",
                                      scenes: [
      screenshot:
      What I’d like to change:
      • hide past days
      • show let’s say 10 markings per week
      • show no more than two weeks / current week only
      • hide the module logo at the center of the screen
        A Former User @dmd
        @dmd
        hide past days
        In calendar configuration, set beforeDays:0 or in view configuration, set filterPassedEvent: true.
        https://github.com/eouia/MMM-CalendarExt2/wiki/2b.-Configuration:Calendar
        https://github.com/eouia/MMM-CalendarExt2/wiki/2c.-Configuration:View
        Sorry I cannot understand what this means. I’m not good at English, sorry. Tell me more detailed description or example.
        I think you are using view:weekly. set fromNow:0 and slotCount:1 on your view configuration.
        https://github.com/eouia/MMM-CalendarExt2/wiki/2c.-Configuration%3AView
        https://github.com/eouia/MMM-CalendarExt2/wiki/2c2.-View:weekly,-monthly
        You might have set the position of module itself. MMM-CalendarExt2 doesn’t need position for module itself. remove it from your configuration.
          module: 'MMM-CalendarExt2',
          // here you don't need to describe position of module itself.
        https://github.com/eouia/MMM-CalendarExt2/wiki/2.-Configuration
          A Former User @gregp
          @gregp
          I’ve updated. Now you can transform the event properties as your wish.
          // In your targeted view configuration, add this.
          transform: (event)=>{
            if (event.title.search("Birthday") > -1) { // If the event might include "Birthday" in its title,
              event.icon = "fxemoji-birthdaycake" // Set icon of that event to "fxemoji-birthdaycake"
            return event // Return that event.
          G BKeyportB 2 Replies Last reply Reply Quote 1
          • G Offline
            gregp @Guest
            @sean Wow! Fantastic! Will give it a whirl.
              dmd @Guest
              @sean “show let’s say 10 markings per week”
              What I meant was that there were two items missing on week 6. Therefore the “+2” like in the screenshot. Fixed it with:
              hideOverflow: true
              “You might have set the position of module itself. MMM-CalendarExt2 doesn’t need position for module itself. remove it from your configuration.”
              Ah, of course. Set position under “views” and now it’s working as desired. Thank you!
                code999
                Great job!
                I was almost done with MMM-CalendarExt then you make it better, now my question is “is there a way to update it to MMM-CalendarExt2”?
                Thanks.
                  A Former User @code999
                  @code999
                  Not upgradable. Both are similar but different from structure to css rules.
                    code999
                    alright thanks
                    • F Offline
                      fnudd
                      First of all, thanks for this module, so far it’s filled all my needs of a calendar. One thing I’m struggling with though is that it seems to redraw itself every minute? And since I’m running MM on a raspberry pi zero the drawing takes something like 3 seconds, which makes it a little irritating. Is there anyway to control the re-drawing? I’ve tried setting the scanInterval, but that doesn’t have any effect.
                      I also get some CALEXT2_CALENDAR_MODIFIED notifications at fairly regular intervals, even when my calendar hasn’t been changed, but they don’t seem correlated to the redrawing. I’m only using google calendars, if that’s of any help.
                      Thanks again, awesome module!
                        A Former User @fnudd
                        @fnudd
                        https://github.com/eouia/MMM-CalendarExt2/wiki/2e.-Configuration:Others#other-configurations
                        rotateInterval(When you are using multi-scenes) or updateInterval would be an answer.
                        • 48
                        • 49
                        • 1 / 49
