    How do you convert xml to json (ideally without dependencies)
    7 Posts 4 Posters 2.7k Views 4 Watching
    • A
      AxLed Module Developer
      I use xml2json.js to convert xml to json in my module.js.
      For the further development of my module (MMM-Dreambox) I have to convert xml to json in node_helper.js.
      How can i do this (ideally without dependencies)
      I have not found any way to use xml2json.js in node_helper.js so far.
      Looking forward to your replies.
      AxLED
        sdetweil @AxLed
        @axled var xxx = require(‘xml2json’)
        if u need something other than code YOU write, that is a dependency
        create a package.json in your module folder and add those other things to the list to get installed after your module, with npm install
        • cowboysdudeC
          xml2js is the only way I know to do it. I know we try to not use dependencies but sometimes it can’t be helped.
          • lavolp3L
            lavolp3 Module Developer @cowboysdude
            @cowboysdude Do we? Didn’t know about that. Why? Because it’s getting too complex?
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • cowboysdudeC
              cowboysdude Module Developer @lavolp3
              @lavolp3 Well I use the principle that less moving parts tends to make things easier… :)
              lavolp3L 1 Reply Last reply Reply Quote 2
              • lavolp3L
                @cowboysdude well you’re right in the aspect that one dependency of your rfacts module messed up the whole module for me.
                Luckily it’s shining bright on my mirror now. And the facts are really good.
                Now back to OT…
                • A
                  @cowboysdude
                  @lavolp3
                  Thanks for your posts, i got some further.
                  1. i added following line in my node_helper.js
                  const parser = require("./MMM-Dreambox-xml2json.js");
                  So node_helper.js checks for MMM-Dreambox-xml2json.js within the same directory.
                  After this, i can use a function of MMM-Dreambox-xml2json.js inside of node_helper.js by calling parser.functionname() in my case parser.xml2json().
                  AxLED
