    MMM-MovieInfo
    13 Posts 3 Posters 5.1k Views 3 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @stuartiannaylor
      @stuartiannaylor I already had it installed, couldn’t see a problem.
      Tried again with --productive and --production.
      Can’t see a performance problem from here…
      Folder size
      with --productive 60mb
      with --production 11mb
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        stuartiannaylor
        Maybe it Pi Zero then I will do it once more… :face_screaming_in_fear:
        About an hour to reinstall on the lowly pi0w though
          stuartiannaylor
          Decided not to as have a hunch on what is happening as saw it download electron last time.
          It prob bypasses the server-only and guess launched electron on a Zero I will just leave it for someone else as it takes just too long to install on the Zero and will try it another time when I have the time to kill and install.
          • lavolp3L Offline
            @stuartiannaylor Sorry for the question but you are in the MMM-MovieInfo folder when doing the install and not in the MagicMirror folder, aren’t you?
              stuartiannaylor @lavolp3
              @lavolp3 Yeah hence why I was so surprised at what it fetched. It did look like the whole install again but in the mmm-movie module directory.
              Actually it wasn’t to be honest as it only took 10 - 15 minutes whilst mm takes approx 35 - 40 on the zero.
              I will give it a go but just not yet as just want to see if I can find ‘my’ perfect set of modules for what I would call ‘my’ complete mirror.
              I was almost there and finishing things off and did my usual of romping ahead without saving copies of config so starting from scratch.
              I will give it a go tomorrow as I am expecting on a zero if you do a --productive first that is what kills things.
              Also I think I have hit the worst thing about the zero and not running electron as I will not have any console logs?
              I think I can get them with the selenium webdriver for chromium but haven’t been back since I was playing with it.
              Or at least I can get some form of log browser side as at the moment I have none but then again could just do it with a command line input I guess.
                stuartiannaylor
                pi@raspberrypi:~/MagicMirror/modules/MMM-MovieInfo$ npm install --productive
                npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                npm notice created a lockfile as package-lock.json. You should commit this file.
                added 384 packages from 448 contributors and audited 1138 packages in 799.653s
                found 1 low severity vulnerability
                  run `npm audit fix` to fix them, or `npm audit` for details
                Node about 0.3%
                			module: 'MMM-MovieInfo',
                			position: 'top_right',
                					api_key: '50543fe5151a1e58768462815ce4d0f8',
                					discover: 	{
                						"primary_release_date.gte": "now",  //now
                						"primary_release_date.lte": "month" //day, week, month, quarter or year
                Well didn’t expect it to work but working ?!
                • lavolp3L Offline
                  @stuartiannaylor said in MMM-MovieInfo:
                  1st rule of MagicMirror Club: There is no complete MagicMirror.
                  :grinning_face_with_smiling_eyes:
                    stuartiannaylor
                    Lols it would seem so, as so far much effort but no completed magic mirror, but much fun :)
                    Its been really interesting introduction to nodejs and a whole previously hidden browser console.
                    I am still banging my head with this PiZero as really with any complexity the proc load goes crazy.
                    Great if you keep it relatively simple, but being trying ‘other’ browsers to be lighter and to my surprise chromium is by the the best. Midori & Epiphany even after java problems or bad animation are still no lighter from what I am seeing in Top.
                    Its a tremendous project and I will bung it a donation when I have a bit of cash.
