    Facial Recognition Module - Step by Step Guide
    28 Posts 14 Posters 34.6k Views 22 Watching
    • K Offline
      konradwalsh
      reserved
        MichiMauch @konradwalsh
        Hi @konradwalsh Maybe you have an idea for my problem: https://forum.magicmirror.builders/topic/9055/usb-cam-is-not-recognized-but-works
        thanks very much and greeetings
        michael
          MichiMauch @MichiMauch
          @michimauch said in Facial Recognition Module - Step by Step Guide:
          michael
          Remember to set the name list environment variable FACE_USERS
          Using default FACE_ALGORITM: 1
          Loading training data...
          mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
          mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
          Exception in thread Thread-1:
            File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
              self.run()
            File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/picam.py", line 27, in run
              with picamera.PiCamera() as camera:
            File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 431, in __init__
              self._init_camera(camera_num, stereo_mode, stereo_decimate)
            File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 460, in _init_camera
              "Camera is not enabled. Try running 'sudo raspi-config' "
          PiCameraError: Camera is not enabled. Try running 'sudo raspi-config' and ensure that the camera has been enabled.
          Training data loaded!
          OpenCV Error: Assertion failed (scn == 3 || scn == 4) in cvtColor, file /build/opencv-U1UwfN/opencv-2.4.9.1+dfsg1/modules/imgproc/src/color.cpp, line 3737
            File "facerecognition.py", line 58, in <module>
              image = cv2.cvtColor(frame, cv2.COLOR_RGB2GRAY)
          cv2.error: /build/opencv-U1UwfN/opencv-2.4.9.1+dfsg1/modules/imgproc/src/color.cpp:3737: error: (-215) scn == 3 || scn == 4 in function cvtColor
            paulGu
            @konradwalsh said in Facial Recognition Module - Step by Step Guide:
            trainingFile: ‘modules/MMM-Facial-Recognition/training.xml’,
            I got a issue when i add the facial module. the Facial-tools work fine, it’s seems like python script issues.
            Could anyone help me with this issue ?
            Whoops! There was an uncaught exception…
            TypeError: PythonShell is not a constructor
            at Class.python_start (/home/csc/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:11:21)
            at Class.socketNotificationReceived (/home/csc/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:40:14)
            at Socket. (/home/csc/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
            at Socket.emit (events.js:182:13)
            at /home/csc/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
            at process._tickCallback (internal/process/next_tick.js:61:11)
            ^CShutting down server…
              sumrag @paulGu
              @paulgu Hi I am having the same issue. Were you able to resolve it?
              • I Offline
                Irfan ali
                I also have same issue can anybody help me
                at Class.python_start (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:11:21)
                at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:40:14)
                • I Offline
                  Irfan ali @MichiMauch
                  @MichiMauch Are You using Webcam ?
                  • N Offline
                    naktah
                    specify your user labels in the environment with
                    export FACE_USERS=Alice,Bob,Casey,Doug
                    im not sure what to do with this. do i have to write this in the terminal? because everytime i restart my pi, the facial recognition doesnt recognize my face
                      sdetweil @naktah
                      @naktah u need to put that in your logon profile
                      • N Offline
                        naktah @sdetweil
                        @sdetweil im not sure how to do that. can you show me how? im pretty much new to this stuff and this issue has been bothering me for days now.
