    Facial Recognition Module - Step by Step Guide
    28 Posts 14 Posters 32.8k Views 22 Watching
    • K Offline
      konradwalsh
      Hi all,
      Due to there being no guide on this and I was looking for one… I have decided to just make one…
      I only start figuring it out last night and so I am still setting up. So I will complete this post as I progress.
      I am using the following hardware
      • Raspberry Pi 3
      • Logitech 1080 HD USB Webcam
      • MagicMirror is installed and confirmed functioning correctly.
      The software I am using to do this is Mobaxterm.
      It might be easier to do all of this on the PI directly.
      The steps I have taken to get this working:
      Set up the tools
      1. Facial Recognition Tools
      on the github page click download as zip
      extract zip and remove -master from the end of the folder. Note: its the internal folder that you want with the same name.
      copy to MagicMirror/modules using your FTP or whatever folder browser you are using.
      run this:
      sudo apt-get update
      sudo apt-get install libopencv-dev python-opencv
      sudo npm install python-shell
      sudo apt-get install python-pip
      change to the tools module folder
      cd /MagicMirror/modules/MMM-Facial-Recognition-Tools
      run
      sudo npm install
      pip install -r requirements.txt
      Capturing training images
      Run
      python capture.py
      Decide whether you want to capture images from your web cam or convert existing .jpg images.
      Enter the name of the person you are about to capture. Images will be stored in a folder named after the captured person in training_data/.
      Follow screen instructions.
      Training model
      Make sure you have captured all your images. Run ``` python train.py ``` The script will automatically scan the directory training_data/ for your images. Wait. You will end up with a training.xml file in the current directory. Copy down the ['name', 'name2','name3'] part because you will later need it for setting up your mirror's face recognition and to test your face recognition model.
      1. Test your steps so far
      Make sure your training.xml from running train.py is in this directory - /MagicMirror/modules/MMM-Facial-Recognition-Tools
      specify the face recognition algorithm in the environment with
      export FACE_ALGORITHM=1
      specify your user labels in the environment with
      export FACE_USERS=Alice,Bob,Casey,Doug
      Run
      python facerecognition.py.
      Success?
      1. Set up the module for the mirror
        on the github page for the MMM-Facial-Recognition page, click download as zip
      Visit the terminal window and go to your newly create folder - /MagicMirror/Modules/MMM-Facial-Recognition and run
      sudo npm install
      Open your config.js file and add:
      	module: 'MMM-Facial-Recognition',
      		// 1=LBPH | 2=Fisher | 3=Eigen
      		recognitionAlgorithm: 1,
      		// Threshold for the confidence of a recognized face before it's considered a
      		// positive match.  Confidence values below this threshold will be considered
      		// a positive match because the lower the confidence value, or distance, the
      		// more confident the algorithm is that the face was correctly detected.
      		lbphThreshold: 50,
      		fisherThreshold: 250,
      		eigenThreshold: 3000,
      		// force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
      		useUSBCam: false,
      		// Path to your training xml
      		trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
      		// recognition intervall in seconds (smaller number = faster but CPU intens!)
      		interval: 2,
      		// Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
      		logoutDelay: 15,
      		// Array with usernames (copy and paste from training script)
      		users: [],
      		//Module set used for strangers and if no user is detected
      		defaultClass: "default",
      		//Set of modules which should be shown for every user
      		everyoneClass: "everyone",
      		// Boolean to toggle welcomeMessage
      		welcomeMessage: true
      Change the line to the actual location. It’s probably still under the Tools Module
      for me, I changed it to
      trainingFile: 'modules/MMM-Facial-Recognition-Tools/training.xml',
      Also, change the line called Users to add you list of users that you set up during the Capture.py section above.
      users: ['Joe'],
      Finally, change the line, if applicable
      useUSBCam: True,
      FINAL STEP!
      For each module in your config.js, set the profile under which it should load. E.g -
      	module: 'example_module',
      	position: 'top_left',
      	//Set your classes here seperated by a space.
      	//Shown for all users
      	classes: 'default everyone',
      	module: 'example_module2',
      	classes: 'Joe',
      So now the first example module will load for everyone and the second will only load for Joe.
      THIS IS AS FAR AS I AM .. I AM DOCUMENTING AS I GO
      @paviro
      Module Developer - Please feel free to copy this or use as you see fit. I hope it is helpful to anyone else
      M A 2 Replies Last reply Reply Quote 5
      • K Offline
        konradwalsh
        reserved
          MichiMauch @konradwalsh
          Hi @konradwalsh Maybe you have an idea for my problem: https://forum.magicmirror.builders/topic/9055/usb-cam-is-not-recognized-but-works
          thanks very much and greeetings
          michael
            MichiMauch @MichiMauch
            @michimauch said in Facial Recognition Module - Step by Step Guide:
            michael
            Remember to set the name list environment variable FACE_USERS
            Using default FACE_ALGORITM: 1
            Loading training data...
            mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
            mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
            Exception in thread Thread-1:
              File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
                self.run()
              File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/picam.py", line 27, in run
                with picamera.PiCamera() as camera:
              File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 431, in __init__
                self._init_camera(camera_num, stereo_mode, stereo_decimate)
              File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 460, in _init_camera
                "Camera is not enabled. Try running 'sudo raspi-config' "
            PiCameraError: Camera is not enabled. Try running 'sudo raspi-config' and ensure that the camera has been enabled.
            Training data loaded!
            OpenCV Error: Assertion failed (scn == 3 || scn == 4) in cvtColor, file /build/opencv-U1UwfN/opencv-2.4.9.1+dfsg1/modules/imgproc/src/color.cpp, line 3737
              File "facerecognition.py", line 58, in <module>
                image = cv2.cvtColor(frame, cv2.COLOR_RGB2GRAY)
            cv2.error: /build/opencv-U1UwfN/opencv-2.4.9.1+dfsg1/modules/imgproc/src/color.cpp:3737: error: (-215) scn == 3 || scn == 4 in function cvtColor
              paulGu
              @konradwalsh said in Facial Recognition Module - Step by Step Guide:
              trainingFile: ‘modules/MMM-Facial-Recognition/training.xml’,
              I got a issue when i add the facial module. the Facial-tools work fine, it’s seems like python script issues.
              Could anyone help me with this issue ?
              Whoops! There was an uncaught exception…
              TypeError: PythonShell is not a constructor
              at Class.python_start (/home/csc/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:11:21)
              at Class.socketNotificationReceived (/home/csc/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:40:14)
              at Socket. (/home/csc/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
              at Socket.emit (events.js:182:13)
              at /home/csc/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
              at process._tickCallback (internal/process/next_tick.js:61:11)
              ^CShutting down server…
                sumrag @paulGu
                @paulgu Hi I am having the same issue. Were you able to resolve it?
                • I Offline
                  Irfan ali
                  I also have same issue can anybody help me
                  at Class.python_start (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:11:21)
                  at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:40:14)
                  • I Offline
                    Irfan ali @MichiMauch
                    @MichiMauch Are You using Webcam ?
                    • N Offline
                      naktah
                      im not sure what to do with this. do i have to write this in the terminal? because everytime i restart my pi, the facial recognition doesnt recognize my face
                        sdetweil @naktah
                        @naktah u need to put that in your logon profile
