    Rss for news feeds?
    13 Posts 6 Posters 27.5k Views 5 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @deadherring
      @deadherring can you post your config.js part of the newsfeed section completely, I get the no config file message when I start MM this is probably to a syntax error and there shouldn’t be a limit of newsfedd that can be added
        deadherring
        Here’s whats configured that currently IS working:
        module: ‘newsfeed’,
        position: ‘bottom_bar’,
        feeds: [
        title: “New York Times”,
        url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
        title: “CNN”,
        url: “http://rss.cnn.com/rss/cnn_topstories.rss”
        title: “Jerusalem Post”
        url: “http://www.jpost.com/Rss/RssFeedsFrontPage.aspx”
        title: “ESPN”,
        url: “http://www.espn.com/espn/rss/news”
        title: “Israel National News”,
        url: “http://www.israelnationalnews.com/RSS.aspx”
        			showSourceTitle: true,
        			showPublishDate: true
        Here’s what I tried to get working:
        module: ‘newsfeed’,
        feeds: [
        title: “CNN”,
        title: “Yahoo News”,
        url: “http://news.yahoo.com/rss”
        title: “ESPN”,
        title: “ESPN Baseball”,
        url: “http://www.espn.com/espn/rss/mlb/news”
        url: “http://israelnationalnews.com/RSS.aspx”
        title: “Ynet Breaking News”,
        url: “http://www.ynet.co.il/Integration/StoryRss3254.xml”
        title: “Reuters”,
        url: “http://feeds.reuters.com/reuters/topNews”
        title: “Reuters Sports”,
        url: “http://feeds.reuters.com/reuters/sportsNews”
        title: “Google News”,
        url: “https://news.google.com/output=rss”
        Note, that I also tried to enter each one of the above feeds individually in the config file and restarted MM and got the no config file message for each. The only feeds I could get working are the ones in the working section I described above.
        I feel like there must be something I am missing? Does the version of MM I am using matter? I’m not sure the command to tell which version I have, I searched the forum but couldn’t find anything.
        Thanks,
        Nathan
          bhepler Module Developer @deadherring
            Try this for a Google news url: https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss
              @deadherring you must have just used the wrong syntax i tested a couple and they all worked for me, make sure you only use one of those two quotes ' or " another will lead to wrong syntax
              https://imgur.com/a/cQ0lN
                deadherring
                Hey guys,
                Thanks a lot for the responses. Here’s what I think might be happening:
                The first three I configured that I got working
                title: “ESPN”,
                and one from CNN, I configured on the pi itself, modifying the config file with a mouse and keyboard on the pi. The rest that I shared that weren’t working, modified the config file on my mac via text edit and then ftp’d the file up to the pi. I suspect that the mac might be saving the file in a way the pi does not like, or, as was suggested, inputting the " s in a way the pi does not like. At least, that’s my theory right now, I need to test when I get home.
                This is the procedure I am following to edit config.js on my mac:
                1. Two-fingered click on config.js. Open with Text Edit
                2. Modify the file
                3. Save as: config.js. I leave the default plain text encoding (UTF-8)
                Is that the right procedure? My MM is installed in the wall in my bathroom and it would be a huge pain to have to connect a mouse and keyboard to it every time I want to modify anything. I suppose I can ssh into it and modify the config file via nano too. I don’t know if that solves the problem, I have to try later.
                Thanks again,
                Nathan
                K B 2 Replies Last reply Reply Quote 0
                • K Offline
                  KirAsh4 Moderator @deadherring
                  @deadherring said in Rss for news feeds?:
                  Either use SSH to get on the rpi, or, if you must, get a wireless mouse/keyboard combo. Those things are cheap on eBay.
                    I think you may be on to something here. Looking back at your complete list of feeds, this is what showed up from your copy & paste:
                    Now I don’t know about your Mac, but from here that looks like some unicode characters where there should be UTF-8. The quotes around Jerusalem Post and the URL value are jacked up. I think you’re better off SSH into the Pi and using nano to edit the config.js file.
                      deadherring
                      I got this working, the problem was indeed something with the formatting by editing as a text file on my mac. By sshing into the box and modifying the config file directly on the pi I got it working.
                      One question I still have: is there any way to tell the box to drop headlines after 2 days or so? I’m seeing headlines that are 5, 6, 7, 8 days old cycle through and they are no longer news. I’m seeing some new headlines make their way in but the majority are old. I want to have the MM drop headlines when they are stale, say after 2 days time.
                      I see there is a updateInterval tag but I believe that refers to the frequency it checks for new headlines, not when it drops old headlines off. Anyone else having the same issue?
                      Thanks,
                      Nathan
                        safaaelbrans Banned
