    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 271.4k Views 35 Watching
    • I Offline
      ianperrin @ctatos
      @ctatos could you send me a pm with details of the script and cron setup you are using?
      "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
      • zerodegree79Z Offline
        zerodegree79 @ctatos
        @ctatos said in MMM-Strava:
        @zerodegree79 I temporarily solved the problem with an external python script found at https://github.com/hozn/stravalib . The script retrieves a newly generated access token every 4-5h and find/replaces it in the config.js file. I then have a crontab that recycles the Magic Mirror.
        There must be a better way, but I can’t complain for now…
        That’s way over my head, but great effort. Maybe @ianperrin can implement this.
        • V Offline
          Val07300 @zerodegree79
          @zerodegree79 Any news about New Strava API integration ?
          zerodegree79Z 1 Reply Last reply Reply Quote 0
            zerodegree79 @Val07300
            @val07300 no, waiting for @ianperrin and @ctatos giving a response
            • I Offline
              ianperrin
              Not as yet I’m afraid.
              Hoping to work on it in the coming weeks - work and other commitments permitting.
              PRs welcome from those who might have the know how 😉
                zerodegree79 @ianperrin
                @ianperrin said in MMM-Strava:
                No as yet I’m afraid.
                No worries, take your time. Meanwhile i just update manually
                • I Offline
                  ianperrin
                  @zerodegree79 , @Val07300, @ctatos (and others I may have missed).
                  A new (beta) version of the module with support for Strava’s new authentication flow is available.
                  Much of the code for the module has been re-written/re-factored and includes a number of changes to the original module including
                  • Support for multiple instances of the module
                  • The table and chart and now generated via templates (rather than javascript)
                  • A helper is included to simplify the initial authentication with Strava
                  • chart mode now supports either the recent and ytd values in the period option
                  • The stats displayed in table mode are configurable via the stats option
                  • To support the new authentication flow, the client_id and client_secret must be included in the config in place of the deprecated strava_id and access_token options. The legacy options can still be used, but will trigger an alert on the mirror when the module is loaded and it is recommended they are removed.
                  Please note - the module no longer supports multiple athlete id’s in one module instance. Multiple instances can be added to the config file to achieve similar results.
                  Notes for beta testers
                  This functionality is only available in the develop branch of the github repository at this time. Once any issues have been fixed, the master branch will be updated.
                  To test the refresh token functionality and the new authentication flow in the Magic Mirror, you need to update the module using the following steps:
                  • stop the Magic Mirror
                  • switch to the develop branch and install the new dependencies
                    cd ~/MagicMirror/modules/MMM-Strava
                    git checkout develop && git pull
                    npm install --production
                  • edit the MMM-Strava configuration in config.js and
                    • remove strava_id and access_token options
                    • add client_id and client_secret options. The values for these options should be copied from the My API Application page in your Strava profile
                  • restart the Magic Mirror
                  When updated correctly, the module should display a Client id unauthorised message. The module can be authorised using the following steps:
                  • Browse to http://localhost:8080/MMM-Strava/auth/ on the Magic Mirror. This can be done remotely if you have setup the ipWhitelist in the Magic Mirror
                  • Select module and click Authorise
                  • If prompted, log in to Strava
                  • On the Strava Authorisation page, click Authorize
                  • Once the successful authorisation message appears, restart your Magic Mirror.
                  lavolp3L H 3 Replies Last reply Reply Quote 1
                  • lavolp3L Offline
                    lavolp3 Module Developer @ianperrin
                    @ianperrin
                    From the new authorization process I’m getting a bad request from Strava:
                      "message": "Bad Request",
                      "errors": [
                          "resource": "Application",
                          "field": "redirect_uri",
                          "code": "invalid"
                    I have the feeling that I have an error in my Strava API config.
                    There is a “website” and a “Callback domain” that I need to put in. Does this have to do anything with the address I’m using for the authentication process via /MMM-Strava/auth?
                    EDIT: Can it be because I’m currently accessing the mirror through a ddns service, so the address is not localhost:8080 but something else?
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    • I Offline
                      ianperrin @lavolp3
                      @lavolp3 are you browsing to http://localhost:8080/MMM-Strava/auth/ and using the authorisation process there? If so, where is the bad request being displayed?
                      It should look something like this:
                      • lavolp3L Offline
                        @ianperrin No I’m browsing from a laptop like always. So it’s http://magicmirror:8080/MMM-Strava/auth/.
                        Do you think that makes a difference?
                        • I Offline
                          ianperrin @lavolp3
                          @lavolp3 I’ve updated the comment above with clearer notes for beta testers.
                          Everything you need should be done from the Magic Mirror, so if you can follow these steps again and let me know where the error occurs or your experience differs that would be great.
                          • lavolp3L Offline
                            @ianperrin Did it again as described, but still a “Bad Request” Message. Maybe I’m doing something wrong: Error message says invalid redirect_uri, so I guess I need to play around with it a bit more.
                            • lavolp3L Offline
                              lavolp3 Module Developer @lavolp3
                              @ianperrin OK now it works.
                              I set my ddns domain “xxxx.ddns.net” as callback domain in the Authentication profile.
                              Then it works. The link for the authorisation inquires that the request is being sent from inside that domain. I had set localhost as the callback domain and made the request from the ddns which in that specific case did not work.
                              Maybe you could include a description for anyone trying to do the authentication from a browser not on the RasPi itself. You would need to set the callback domain appropriately.
                              • I Offline
                                ianperrin @lavolp3
                                @lavolp3 that makes sense, I understand your issue now. Good pick up and we’ll done for finding that solution. I’ll look to update the read me with notes for creating the application as well as authorising the modules.
                                In the meantime, let me know how the token refresh works, or if any other errors appear.
                                • lavolp3L Offline
                                  @ianperrin Table mode doesn’t seem to rotate the actual data into monthly data for me. I have done a run of 6.4 km on Tuesday. But much more in Jan and Feb :-)
                                  Can you confirm that?
                                  • I Offline
                                    ianperrin @lavolp3
                                    @lavolp3 said in MMM-Strava:
                                    Hi @lavolp3 - can you post your config for the module and if possible the output from the log?
                                    • lavolp3L Offline
                                      rom the log?
                                      My config:
                                              //disabled: true,
                                              module: 'MMM-Strava',
                                              position: 'bottom_right',
                                                  client_id: "2xxxx",
                                                  client_secret: "9bdxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                                  // strava_id: '23128899',
                                                  // access_token: 'af1a3e4xxxxxxxxxxxxxxxxxxxxxxxxxxxx',
                                                  // period: 'recent',
                                                  auto_rotate: true,
                                                  animationSpeed: 0,
                                                  mode: "chart",
                                                  debug: true
                                      Regarding logs: This comes from the developer’s tab:
                                      Load script: modules/MMM-Strava//MMM-Strava.js loader.js:182:4
                                      Check MagicMirror version for module 'MMM-Strava' - Minimum version:  2.2.0 - Current version: 2.6.0 module.js:469:3
                                      Module registered: MMM-Strava module.js:477:2
                                      Bootstrapping module: MMM-Strava loader.js:152:3
                                      Scripts loaded for: MMM-Strava loader.js:157:4
                                      Load stylesheet: modules/MMM-Strava/MMM-Strava.css loader.js:197:4
                                      Styles loaded for: MMM-Strava loader.js:159:5
                                      MMM-Strava - Load translation: translations/de.json translator.js:172:5
                                      MMM-Strava - Load translation fallback: translations/en.json translator.js:174:5
                                      Translations loaded for: MMM-Strava loader.js:161:6
                                      Starting module: MMM-Strava MMM-Strava.js:114:9
                                      MMM-Strava received a system notification: ALL_MODULES_STARTED module.js:156:4
                                      MMM-Strava received a system notification: MODULE_DOM_CREATED module.js:156:4
                                      MMM-Strava received a system notification: DOM_OBJECTS_CREATED module.js:156:4
                                      MMM-Strava: "Receiving notification: DATA for module_25_MMM-Strava" MMM-Strava.js:201:13
                                      MMM-Strava received a module notification: DARK_SKY_FORECAST_WEATHER_UPDATE from sender: MMM-DarkSkyForecast
                                      npm start dev does only give me:
                                      MMM-Strava: "Received notification: SET_CONFIG"
                                      • I Offline
                                        ianperrin @lavolp3
                                        @lavolp3 - thanks and good spot. Currently rotation is only supported for table mode. I’ve pushed a fix to the develop branch to enforce this behaviour. Please use git pull to get and test the changes.
                                        • lavolp3L Offline
                                          @ianperrin Confirmed! Chart is not rotating anymore.
                                          However it might be worth to think about several rotating charts. Like for weekdays and a range of several months?
                                          • I Offline
                                            ianperrin @lavolp3
                                            @ianperrin … it might be worth to think about several rotating charts. Like for weekdays and a range of several months?
                                            Good idea, could you add it as an issue in the Github repository so I don’t forget it?
                                            • 2 / 7
