    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 290.2k Views 35 Watching
    • zerodegree79Z
      zerodegree79
      Hi guys, i am using the Strava-Module and over the Winter i am doing a lot of indoor-cycling with Zwift. I was wondering if it is possible to integrate “virtual cycling” into the module and if it’s possible, then how. Hope anyone can answer this. I don`t need the “swim” anyway, so i would like to interchange it with “virtual ride”
      I 1 Reply Last reply
      • I
        ianperrin @zerodegree79
        @zerodegree79
        You should be able to hide swim activities by adding the following to your config
        activities: ["ride", "run"]
        Adding other activity types will need some investigation of the Strava API as ActivityStats only returns totals for the three activity types currently available.
        I need to look at the module again shortly as there is an change to the API which requires a different authentication mechanism so I’ll try an pick this up then
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        zerodegree79Z 1 Reply Last reply
        • zerodegree79Z
          zerodegree79 @ianperrin
          @ianperrin said in MMM-Strava:
          @zerodegree79
          You should be able to hide swim activities by adding ‘’‘activities: [“ride”, “run”]’‘’ to your config
          Thanks for your reply. I know that i can hide “swim”, but just wanted to change it to “virtual ride”. So i just wait until you have looked at the API.
          Thanks in advance for your support.
          • I
            @zerodegree79 great - wasn’t sure from your comment whether you’d spotted the option on the config.
            After a quick look, I’ve pushed a change to the module which includes virtual activities in the chart stats. Take a look and let me know if this works as expected.
            • zerodegree79Z
              @ianperrin hi, thanks for the fast response. I tried to update, but now it is stuck in loading activities. I changed the MMM-Strava.js. What else do i need to edit? Below is my config:
               // Default module config.
                  defaults: {
                      strava_id: ['XXXXXX'],                      // List of strava_id's, could get this from current athlete - https://strava.github.io/api/v3/athlete/#get-details
                      access_token: ['XXXXXXXXXXXXXXXXX'],                   // List of acces_token's (corresponding to the strava_id's), see https://www.strava.com/settings/api
                      athlete_text: [''],                   // List of athlete_text's (corresponding to the strava_id's), will be diplayed instead of ativity_text
                      mode: 'table',                        // Possible values "table", "chart"
                      elevation: true,                     // Shows elevation in "table" mode
                      activities: ["ride", "run", "virtual"],  // Possible values "ride", "run", "swim"
                      period: "all",                     // Possible values "recent", "ytd", "all"
                      auto_rotate: true,                   // Rotate stats through each period starting from specified period
                      locale: config.language,
                      units: config.units,
                      fade: false,
                      fadePoint: 0.1,                       // Start on 1/4th of the list.
                      reloadInterval: 5 * 60 * 1000,        // every 5 minutes
                      updateInterval: 600 * 1000,            // 10 seconds
                      animationSpeed: 10 * 1000,           // 2.5 seconds
                      debug: false,                         // Set to true to enable extending logging
              No idea whats wrong. Thanks in advance.
              • I
                @zerodegree79
                You should avoid editing the module files and place your configuration in the config.js file - check the readme file for installation, update and configuration notes
                Once you’ve reverted your changes to the module files, pull the latest version of the module and make sure config.js is correctly configured.
                There is no need to add anything special to the config to include virtual activities as these will be rolled up into the ride and run totals in the chart like the table mode and your dashboard on the Strava website
                • zerodegree79Z
                  @ianperrin thanks for your help, changed back and now it`s working fine. Just one Question left. Is there a way to “isolate” the virtual rides? To show them separately in the charts?
                  • zerodegree79Z
                    zerodegree79
                    HEy @ianperrin, since Strava changed their API- Refreshing, i need to put in the Access Token manually every 6 hours. Can you change this in your module? Here is the API Handbook from Strava. I have no idea how this wors, so maybe you can fix it. https://developers.strava.com/docs/authentication/#Refresh expired
                    Thanks in advance.
                    C 1 Reply Last reply
                      ctatos @zerodegree79
                      @zerodegree79 I temporarily solved the problem with an external python script found at https://github.com/hozn/stravalib . The script retrieves a newly generated access token every 4-5h and find/replaces it in the config.js file. I then have a crontab that recycles the Magic Mirror.
                      There must be a better way, but I can’t complain for now…
                      I zerodegree79Z 2 Replies Last reply
                      • I
                        ianperrin @ctatos
                        @ctatos could you send me a pm with details of the script and cron setup you are using?
                        • zerodegree79Z
                          zerodegree79 @ctatos
                          @ctatos said in MMM-Strava:
                          That’s way over my head, but great effort. Maybe @ianperrin can implement this.
                          V 1 Reply Last reply
                          • V
                            Val07300 @zerodegree79
                            @zerodegree79 Any news about New Strava API integration ?
                            • zerodegree79Z
                              zerodegree79 @Val07300
                              @val07300 no, waiting for @ianperrin and @ctatos giving a response
                              • I
                                ianperrin
                                Not as yet I’m afraid.
                                Hoping to work on it in the coming weeks - work and other commitments permitting.
                                PRs welcome from those who might have the know how 😉
                                • zerodegree79Z
                                  No as yet I’m afraid.
                                  No worries, take your time. Meanwhile i just update manually
                                  • I
                                    ianperrin
                                    @zerodegree79 , @Val07300, @ctatos (and others I may have missed).
                                    A new (beta) version of the module with support for Strava’s new authentication flow is available.
                                    Much of the code for the module has been re-written/re-factored and includes a number of changes to the original module including
                                    • Support for multiple instances of the module
                                    • The table and chart and now generated via templates (rather than javascript)
                                    • A helper is included to simplify the initial authentication with Strava
                                    • chart mode now supports either the recent and ytd values in the period option
                                    • The stats displayed in table mode are configurable via the stats option
                                    • To support the new authentication flow, the client_id and client_secret must be included in the config in place of the deprecated strava_id and access_token options. The legacy options can still be used, but will trigger an alert on the mirror when the module is loaded and it is recommended they are removed.
                                    Please note - the module no longer supports multiple athlete id’s in one module instance. Multiple instances can be added to the config file to achieve similar results.
                                    Notes for beta testers
                                    This functionality is only available in the develop branch of the github repository at this time. Once any issues have been fixed, the master branch will be updated.
                                    To test the refresh token functionality and the new authentication flow in the Magic Mirror, you need to update the module using the following steps:
                                    • stop the Magic Mirror
                                    • switch to the develop branch and install the new dependencies
                                      cd ~/MagicMirror/modules/MMM-Strava
                                      git checkout develop && git pull
                                      npm install --production
                                    • edit the MMM-Strava configuration in config.js and
                                      • remove strava_id and access_token options
                                      • add client_id and client_secret options. The values for these options should be copied from the My API Application page in your Strava profile
                                    • restart the Magic Mirror
                                    When updated correctly, the module should display a Client id unauthorised message. The module can be authorised using the following steps:
                                    • Browse to http://localhost:8080/MMM-Strava/auth/ on the Magic Mirror. This can be done remotely if you have setup the ipWhitelist in the Magic Mirror
                                    • Select module and click Authorise
                                    • If prompted, log in to Strava
                                    • On the Strava Authorisation page, click Authorize
                                    • Once the successful authorisation message appears, restart your Magic Mirror.
                                    lavolp3L H 3 Replies Last reply
                                    • lavolp3L
                                      lavolp3 Module Developer @ianperrin
                                      @ianperrin
                                      From the new authorization process I’m getting a bad request from Strava:
                                        "message": "Bad Request",
                                        "errors": [
                                            "resource": "Application",
                                            "field": "redirect_uri",
                                            "code": "invalid"
                                      I have the feeling that I have an error in my Strava API config.
                                      There is a “website” and a “Callback domain” that I need to put in. Does this have to do anything with the address I’m using for the authentication process via /MMM-Strava/auth?
                                      EDIT: Can it be because I’m currently accessing the mirror through a ddns service, so the address is not localhost:8080 but something else?
                                      How to troubleshoot modules
                                      MMM-soccer v2, MMM-AVStock
                                      • I
                                        ianperrin @lavolp3
                                        @lavolp3 are you browsing to http://localhost:8080/MMM-Strava/auth/ and using the authorisation process there? If so, where is the bad request being displayed?
                                        It should look something like this:
                                        lavolp3L 1 Reply Last reply
                                        • lavolp3L
                                          @ianperrin No I’m browsing from a laptop like always. So it’s http://magicmirror:8080/MMM-Strava/auth/.
                                          Do you think that makes a difference?
                                          • I
                                            ianperrin @lavolp3
                                            @lavolp3 I’ve updated the comment above with clearer notes for beta testers.
                                            Everything you need should be done from the Magic Mirror, so if you can follow these steps again and let me know where the error occurs or your experience differs that would be great.
                                            • 2 / 7
