    [MMM-MusicOnDemand] - Play music from deezer with a browser in the background
    16 Posts 5 Posters 14.1k Views 5 Watching
    • Cr4z33C Offline
      Cr4z33 @ptrk95
      @ptrk95 getting a black screen when I launch MagicMirror no matter if I use default Chromium or puppeteer.
      Actually I was going now to delete the puppeteer package, but it wasn’t installed at all. :thinking_face:
      Running everything on a Raspberry Pi 3 B+.
        ptrk95 Module Developer
        Thanks for pointing that out! The dependencies in the package.json weren’t set. I uploaded a changed version but unfortunatley this build won’t work for me right now, so I have to do a deeper look into it.
        Edit: It`s again working on the new build, was a problem with the puppeteer version and the chromium version installed on raspbian.
        • Cr4z33C Offline
          Cr4z33 @ptrk95
          @ptrk95 it keeps displaying a black screen.
          This is my config section for this module:
          			module: "MMM-MusicOnDemand",
          			disabled: false,
          				chromiumPath : "/usr/bin/chromium-browser",
          				// chromiumPath : null,
          				showCover : true,
          				email : "****",
          				password : "****",
          and this is the MM dev log:
          pi@raspberrypi:~/MagicMirror $ npm start dev
          > magicmirror@2.6.0 start /home/pi/MagicMirror
          > sh run-start.sh "dev"
          Starting MagicMirror: v2.6.0
          Loading config ...
          Loading module helpers ...
          Module helper loaded: MMM-Remote-Control
          Module helper loaded: MMM-AssistantMk2
          Module helper loaded: MMM-PushBulletNotifications
          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'puppeteer'
          App threw an error during load
              at Module._resolveFilename (module.js:543:15)
              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
              at Function.Module._load (module.js:473:25)
              at Module.require (module.js:586:17)
              at require (internal/module.js:11:18)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_helper.js:4:19)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_helper.js:310:3)
              at Module._compile (module.js:642:30)
              at Object.Module._extensions..js (module.js:653:10)
              at Module.load (module.js:561:32)
          { Error: Cannot find module 'puppeteer'
              at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
          Launching application.
            That’s strange.
            Try cd in the MusicOnDemand folder and then:
            npm install puppeteer@1.11.0
            • Cr4z33C Offline
              Cr4z33 @ptrk95
              @ptrk95 but then why should I need puppeteer if we have already Chromium installed in the Pi? :confused_face:
                ptrk95 Module Developer @Cr4z33
                @cr4z33 with puppeteer you can control the browser with Javascript. But it will install a version of chromium inside the puppeteer folder which you can delete to save space if you use the preinstalled chromium of raspbian :)
                • Cr4z33C Offline
                  Cr4z33 @ptrk95
                  @ptrk95 OK thanks now MM is loading properly, but yout module keeps saying ‘Initializing…’ and nothing happens. :grimacing_face:
                  This is the error in log:
                  Error: Failed to launch chrome!
                  TROUBLESHOOTING: https://github.com/GoogleChrome/puppeteer/blob/master/docs/troubleshooting.md
                      at onClose (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:342:14)
                      at ChildProcess.helper.addEventListener (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:332:60)
                      at emitTwo (events.js:131:20)
                      at ChildProcess.emit (events.js:214:7)
                      at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                    @cr4z33 that’s most likely a versioning problem with puppeteer and chromium.
                    I assume you already did:
                    cd ~/MagicMirror/modules/MMM-MusicOnDemand
                    Please check your chromium version. My version is the latest one: version 65.0.3325.181.
                    If it’s not, try:
                    sudo apt-get install chromium-browser
                    And check that your chromium path in the config file is “/usr/bin/chromium-browser”, which I guess it is. Because on Raspberry Pi the browser of puppeteer isn’t working.
                    If that’s also not launching your browser I honestly don’t know why :/
                    In the latest build I added the option “showBrowser” in the config-file. If you set it to true, you are able to see the browser and what it is doing in the browser.
                    Cr4z33C 2 Replies Last reply Reply Quote 0
                    • Cr4z33C Offline
                      Cr4z33 @ptrk95
                      @ptrk95 did everything you said, browser version is the same, added that config line, but the module keeps sitting at the ‘Initializing…’ word.
                      If I can’t do anything else maybe someone here is willing to contribute? :man_shrugging_medium_skin_tone:
                      • Cr4z33C Offline
                        Cr4z33 @ptrk95
                        @ptrk95 tried to give your module another try, but if I try using the (latest) default Chromium browser it keeps sitting at the ‘Logging into deezer’ text and if I try using Puppeteer I get this:
                        /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 18: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: ?Udmv~�����������: not found
                        /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 1: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: �
                        @8
                          @,*@@@hh���,+r,+r0r0r0r: not found
                        /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 1: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: ELF: not found
                        /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 19: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: Syntax error: ")" unexpected
                            at Interface.helper.addEventListener (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:331:50)
                            at emitNone (events.js:111:20)
                            at Interface.emit (events.js:208:7)
                            at Interface.close (readline.js:370:8)
                            at Socket.onend (readline.js:149:10)
                            at Socket.emit (events.js:208:7)
                            at endReadableNT (_stream_readable.js:1056:12)
                            at _combinedTickCallback (internal/process/next_tick.js:138:11)
                        • ejay-ibmE Offline
                          ejay-ibm Project Sponsor Module Developer
                          Fantastic !
                          I’m preparing as well a stand alone module to control spotify with the mk2 assistant as well . I should be able to release and share in a couple of days . I just need to fix one big bug and it will be OK .
                          Thanks for your module We will have all we need to control music with our mirror !
                          so cool
                          Ejay
                          • F Offline
                            F17MC @ejay-ibm
                            @ejay-ibm said in [MMM-MusicOnDemand] - Play music from deezer with a browser in the background:
                            Fantastic !
                            so cool
                            Ejay
                            Wow! That is fantastic!
                            I have a question. I’m living in Spain, and I’m using a Spotify account from other country.
                            All works fine, and I don’t need VPN to play my music.
                            Do you think that I could be able to use my Spotify account with your module?
                            Thanks!
                            • Cr4z33C Offline
                              Cr4z33 @F17MC
                              @F17MC mate imho you should contact him in private chat.
                              This is a topic about a Deezer module and from another developer after all. :winking_face:
                                dodol45
                                can’t stop music with MMM-assistantMk2, can’t input any command after music playing, anyone know how to solve it ?
