    [MMM-MusicOnDemand] - Play music from deezer with a browser in the background
    16 Posts 5 Posters 14.3k Views 5 Watching
    • Cr4z33C Offline
      Cr4z33 @ptrk95
      @ptrk95 but then why should I need puppeteer if we have already Chromium installed in the Pi? :confused_face:
        ptrk95 Module Developer @Cr4z33
        @cr4z33 with puppeteer you can control the browser with Javascript. But it will install a version of chromium inside the puppeteer folder which you can delete to save space if you use the preinstalled chromium of raspbian :)
        • Cr4z33C Offline
          Cr4z33 @ptrk95
          @ptrk95 OK thanks now MM is loading properly, but yout module keeps saying ‘Initializing…’ and nothing happens. :grimacing_face:
          This is the error in log:
          Error: Failed to launch chrome!
          TROUBLESHOOTING: https://github.com/GoogleChrome/puppeteer/blob/master/docs/troubleshooting.md
              at onClose (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:342:14)
              at ChildProcess.helper.addEventListener (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:332:60)
              at emitTwo (events.js:131:20)
              at ChildProcess.emit (events.js:214:7)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
            @cr4z33 that’s most likely a versioning problem with puppeteer and chromium.
            I assume you already did:
            cd ~/MagicMirror/modules/MMM-MusicOnDemand
            npm install puppeteer@1.11.0
            Please check your chromium version. My version is the latest one: version 65.0.3325.181.
            If it’s not, try:
            sudo apt-get install chromium-browser
            And check that your chromium path in the config file is “/usr/bin/chromium-browser”, which I guess it is. Because on Raspberry Pi the browser of puppeteer isn’t working.
            If that’s also not launching your browser I honestly don’t know why :/
            In the latest build I added the option “showBrowser” in the config-file. If you set it to true, you are able to see the browser and what it is doing in the browser.
            Cr4z33C 2 Replies Last reply Reply Quote 0
            • Cr4z33C Offline
              Cr4z33 @ptrk95
              @ptrk95 did everything you said, browser version is the same, added that config line, but the module keeps sitting at the ‘Initializing…’ word.
              If I can’t do anything else maybe someone here is willing to contribute? :man_shrugging_medium_skin_tone:
              • Cr4z33C Offline
                Cr4z33 @ptrk95
                @ptrk95 tried to give your module another try, but if I try using the (latest) default Chromium browser it keeps sitting at the ‘Logging into deezer’ text and if I try using Puppeteer I get this:
                /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 18: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: ?Udmv~�����������: not found
                /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 1: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: �
                @8
                  @,*@@@hh���,+r,+r0r0r0r: not found
                /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 1: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: ELF: not found
                /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: 19: /home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/.local-chromium/linux-609904/chrome-linux/chrome: Syntax error: ")" unexpected
                    at Interface.helper.addEventListener (/home/pi/MagicMirror/modules/MMM-MusicOnDemand/node_modules/puppeteer/lib/Launcher.js:331:50)
                    at emitNone (events.js:111:20)
                    at Interface.emit (events.js:208:7)
                    at Interface.close (readline.js:370:8)
                    at Socket.onend (readline.js:149:10)
                    at Socket.emit (events.js:208:7)
                    at endReadableNT (_stream_readable.js:1056:12)
                    at _combinedTickCallback (internal/process/next_tick.js:138:11)
                • ejay-ibmE Offline
                  ejay-ibm Project Sponsor Module Developer
                  Fantastic !
                  I’m preparing as well a stand alone module to control spotify with the mk2 assistant as well . I should be able to release and share in a couple of days . I just need to fix one big bug and it will be OK .
                  Thanks for your module We will have all we need to control music with our mirror !
                  so cool
                  Ejay
                  • F Offline
                    F17MC @ejay-ibm
                    @ejay-ibm said in [MMM-MusicOnDemand] - Play music from deezer with a browser in the background:
                    Fantastic !
                    so cool
                    Ejay
                    Wow! That is fantastic!
                    I have a question. I’m living in Spain, and I’m using a Spotify account from other country.
                    All works fine, and I don’t need VPN to play my music.
                    Do you think that I could be able to use my Spotify account with your module?
                    Thanks!
                    • Cr4z33C Offline
                      Cr4z33 @F17MC
                      @F17MC mate imho you should contact him in private chat.
                      This is a topic about a Deezer module and from another developer after all. :winking_face:
                        dodol45
                        can’t stop music with MMM-assistantMk2, can’t input any command after music playing, anyone know how to solve it ?
