    My first Mirror (45cm x 65cm) with 24" monitor (Netherlands)
    9 Posts 4 Posters 9.3k Views 4 Watching
    • htilburgsH Offline
      htilburgs
      After being infected with the Magic Mirror virus, I’ve decided to build one.
      It’s my first attempt with an 24" monitor. The frame is prepared for an 27" monitor, but because it’s my first mirror I first started with an old 24".
      Used parts:
      • Raspberry Pi 3B+
      • 8GB SD Card
      • PIR Infrared Motion Sensor (HC-SR501)
      • Spymirror Silver (45cm x 65 cm) – Pyrasied
      • HP 24″ LCD Scherm
      • 2x surface-mounted outlet
      • Wood – inner frame
      • Wood – outer frame
      Modules:
      • Clock
      • MMM-MyGarbage
      • MMM-DarkSkyForecast
      • MMM-MyCalendar
      • MMM-Remote-Control
      • MMM-RPI-LED
      alt text
      alt text
      alt text
      alt text
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      • H Offline
        hardbats
        Hello fellow dutchy!
        I saw you also use a mirror from pyrasied. Did you get the spy mirror or something else?
          htilburgs
          I have the spymirror. If you click on the word Pyrasied, you see what I ordered (As I said in the bullet 😉)
            jmigoliva
            Hello, just a simple question.
            How do you use the pir sensor?
            Turn off the screen or leds.
            Thanks.
              htilburgs
              @jmigoliva, I use a simple python script for the PIR sensor. I’ve used the instructions on https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/
              This page provided me everything I needed to get the PIR sensor working.
                jmigoliva
                thanks again.
                • ScrewyoudriverS Offline
                  Screwyoudriver
                  Is you’re MMM-MyGarbage based on a csv file?
                  I am looking for one that can read ical… From HVC :P
                  • Mooi spiegeltje! :P
                  htilburgsH 1 Reply Last reply Reply Quote 0
                    htilburgs @Screwyoudriver
                    @Screwyoudriver (Currently) it’s not possible to read ical files. One of the reasons is that every waste company uses it’s own formats / dates / ect. I will gone take a look at that in the near future, but currently I’ve not enought spare time :disappointed_face:
                    En bedankt! :face_with_stuck-out_tongue_winking_eye:
                    ScrewyoudriverS 1 Reply Last reply Reply Quote 1
                      Screwyoudriver @htilburgs
                      @htilburgs I’ve looked at cure-afvalbeheer.nl and hvcinzameling.nl… its looks the same.
                      I’m going to make a request … someday.
                      Or I’m going to adjust the calendar
