    MMM-NetworkScanner help needed
    21 Posts 8 Posters 16.2k Views 8 Watching
    • pugslyP
      pugsly
      Im sure because you have the firewall on, it won’t ping if thats the case. This is one of the reasons I want to do it by MAC address.
      • slametpsS
        slametps @Mykle1
        @Mykle1 said in MMM-NetworkScanner help needed:
        @slametps I think so too. I could not get it to work with MAC addresses. Assigning static IP addresses is the only way I could get it to work, and even that was not perfect, as it would not show my desktop as active , even with a static ip address
        Unfortunately, mine was not working, neither MAC nor IP. :sob:
        While I tracing the execution through console log, the problem is in here:
        payload.forEach(function (item) {
                        var device = self.getDeviceByMacAddress(item); // device is null, although self.getDeviceByMacAddress() return not null. still no idea.
                        console.log("devices: " + device);
                        if (device) {
                            device.online = true;
                            device.lastSeen = moment();
                            self.networkDevices.push(device);
        regards,
        Slamet PS
        • I
          izanbard
          in this context self has no meaning - add var self = this; to the top of the function or replace self with this
          slametpsS 1 Reply Last reply
          • slametpsS
            slametps @izanbard
            @izanbard said in MMM-NetworkScanner help needed:
            self is already defined in the original complete code. the original author @ianperrin will take a look into the latest code (v0.0.2, I presume).
            @Mykle1 : For now, I downloaded the previous version (tags v0.0.1 before the official bugs free the new version v0.0.2 fixed/released), and work like a charm.
            git clone --tags v0.0.1 https://github.com/ianperrin/MMM-NetworkScanner.git
            regards,
            Slamet PS
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @slametps
              @slametps said in MMM-NetworkScanner help needed:
              Very good. :thumbsup:
              • slametpsS
                slametps @Mykle1
                I just fresh cloned the (new) latest version (rather than update/git pull), it is working flawlessly now. Thx to @ianperrin.
                regards,
                Slamet PS
                • FlatPepsiF
                  FlatPepsi
                  And easy question I hope you guys can help with – is this module active or passive?
                  For example, if I take my magic mirror to work to show it off, will this module activly send out network traffic to the network and trigger security alerts (getting me in big trouble)?
                  I’m hoping the answer is that it only looks for IP and Mac addresses listed in the configuration.
                  • slametpsS
                    slametps @FlatPepsi
                    @FlatPepsi it is active since arp-scan will executed every updateInterval setting. Of course, it will trigger such a security alert if violate the security policy of your office. No, arp-scan will scan all available devices in the network.
                    regards,
                    Slamet PS
                      35110 @slametps
                      @Mykle1 try to execute the following in shell:
                      arp-scan -l -q
                      Compare all the scanned MAC with your MAC device entries in MMM-NetworkScanner.
                      I have run the command sudo arp-scan -l -q and somehow find only devices that are in the LAN, but no device what is in the WIFI - so unfortunately no mobile. My MM always shows me only “NO DEVICE ONLINE”.
                      I proceeded as follows:
                      cd ~ /
                      sudo apt-get install arp-scan
                      cd ~ / MagicMirror / modules
                      git clone https://github.com/ianperrin/MMM-NetworkScanner.git
                      cd ~ / MagicMirror / modules / MMM-NetworkScanner
                      npm install
                      cd ~ / MagicMirror / config
                      nano config.js
                                              module: "MMM-NetworkScanner",
                                              position: "bottom_right",
                                                      device: [
                                                              { macAddress: "XX:XX:XX:XX:XX:XX", name: "I", icon: "mobile"},
                                              showUnknown: true,
                      • E
                        epi
                        In my case, all the devices on LAN and 2.4 networks are found, while 5ghz network is not seen even through sudo arp-scan -l -q
