    MMM-NetworkScanner help needed
    21 Posts 8 Posters 15.3k Views 8 Watching
      @cowboysdude said in MMM-NetworkScanner help needed:
      I can verify mac addresses not working for me either… I installed it to play with and the only way I can show anything online is using ip addresses…
      A quick fix, so far:
      I went into my FIOS router and assigned a “static lease” on the IP addresses of the devices that would not show in NetworkScanner with their MAC addresses. Went back into my config.js and changed the macAddress to ipAddress for each device and put in the static IP addresses I just assigned in the router.
      It’s working now, all except for the machine I am working on now (my desktop). It doesn’t show as active, even with a static lease on the IP address. That’s sort of alright, as I really just wanted the cell phones to appear, which they do, but odd, nonetheless. :-/
      Now two things that remain:
      1. I want to move the entire cell that contains NetworkScanner on the screen to the left. Could someone tell me where to find that?
      2. The phrase “was last seen 5 minutes ago” in NetworkScanner. Where do I go to edit that?
        pugsly
        The mac address scanner was working up until yesterday when a new version came out. If you look at your logs you can see it is doing MAC scanning. Mine keeps throwing an error saying the module ‘ping’ is missing.
        I don’t want to scan by IP address because I have some machines that I don’t have ping enabled.
          @cowboysdude
          After I assigned static IP addresses via my FIOS router the scanner started working, somewhat. Then I rearranged my mirror, somewhat.
          slametpsS 1 Reply Last reply Reply Quote 0
          • slametpsS Offline
            slametps @Mykle1
            @Mykle1 yap, mine is no longer working after updating the module :'( I think there is something wrong with the new module for MAC comparison. Hope the author fix this soon.
            regards,
            Slamet PS
              Mykle1 Project Sponsor Module Developer @slametps
              @slametps I think so too. I could not get it to work with MAC addresses. Assigning static IP addresses is the only way I could get it to work, and even that was not perfect, as it would not show my desktop as active , even with a static ip address
                pugsly
                Im sure because you have the firewall on, it won’t ping if thats the case. This is one of the reasons I want to do it by MAC address.
                • slametpsS Offline
                  slametps @Mykle1
                  @Mykle1 said in MMM-NetworkScanner help needed:
                  Unfortunately, mine was not working, neither MAC nor IP. :sob:
                  While I tracing the execution through console log, the problem is in here:
                  payload.forEach(function (item) {
                                  var device = self.getDeviceByMacAddress(item); // device is null, although self.getDeviceByMacAddress() return not null. still no idea.
                                  console.log("devices: " + device);
                                  if (device) {
                                      device.online = true;
                                      device.lastSeen = moment();
                                      self.networkDevices.push(device);
                  regards,
                  Slamet PS
                  • I Offline
                    izanbard
                    in this context self has no meaning - add var self = this; to the top of the function or replace self with this
                    • slametpsS Offline
                      slametps @izanbard
                      @izanbard said in MMM-NetworkScanner help needed:
                      self is already defined in the original complete code. the original author @ianperrin will take a look into the latest code (v0.0.2, I presume).
                      @Mykle1 : For now, I downloaded the previous version (tags v0.0.1 before the official bugs free the new version v0.0.2 fixed/released), and work like a charm.
                      git clone --tags v0.0.1 https://github.com/ianperrin/MMM-NetworkScanner.git
                      regards,
                      Slamet PS
                        @slametps said in MMM-NetworkScanner help needed:
                        Very good. :thumbsup:
                        • slametpsS Offline
                          slametps @Mykle1
                          I just fresh cloned the (new) latest version (rather than update/git pull), it is working flawlessly now. Thx to @ianperrin.
                          regards,
                          Slamet PS
                          • FlatPepsiF Offline
                            FlatPepsi
                            And easy question I hope you guys can help with – is this module active or passive?
                            For example, if I take my magic mirror to work to show it off, will this module activly send out network traffic to the network and trigger security alerts (getting me in big trouble)?
                            I’m hoping the answer is that it only looks for IP and Mac addresses listed in the configuration.
                            • slametpsS Offline
                              slametps @FlatPepsi
                              @FlatPepsi it is active since arp-scan will executed every updateInterval setting. Of course, it will trigger such a security alert if violate the security policy of your office. No, arp-scan will scan all available devices in the network.
                              regards,
                              Slamet PS
                              • 3 Offline
                                35110 @slametps
                                @Mykle1 try to execute the following in shell:
                                arp-scan -l -q
                                Compare all the scanned MAC with your MAC device entries in MMM-NetworkScanner.
                                I have run the command sudo arp-scan -l -q and somehow find only devices that are in the LAN, but no device what is in the WIFI - so unfortunately no mobile. My MM always shows me only “NO DEVICE ONLINE”.
                                I proceeded as follows:
                                cd ~ /
                                sudo apt-get install arp-scan
                                cd ~ / MagicMirror / modules
                                git clone https://github.com/ianperrin/MMM-NetworkScanner.git
                                cd ~ / MagicMirror / modules / MMM-NetworkScanner
                                npm install
                                cd ~ / MagicMirror / config
                                nano config.js
                                                        module: "MMM-NetworkScanner",
                                                        position: "bottom_right",
        device: [
        { macAddress: "XX:XX:XX:XX:XX:XX", name: "I", icon: "mobile"},
                                                        showUnknown: true,
                                • E Offline
                                  epi
                                  In my case, all the devices on LAN and 2.4 networks are found, while 5ghz network is not seen even through sudo arp-scan -l -q
