    MMM-SpotifyControl . Control your Spotify music player using Mk2 assistant.
    38 Posts 4 Posters 24.0k Views 9 Watching
    • ejay-ibmE
      ejay-ibm Project Sponsor Module Developer @Cr4z33
      @Cr4z33 try to just say “Bob Marley Spotify” so there’s no language interaction.
      Cr4z33C 2 Replies Last reply
      • Cr4z33C
        Cr4z33 @ejay-ibm
        @ejay-ibm just tried and again GA says he apologizes, but he doesn’t know right now how to help me.
        • Cr4z33C
          Cr4z33 @ejay-ibm
          @ejay-ibm perhaps it doesn’t work (yet) when using GA in another language than English?
          ejay-ibmE 1 Reply Last reply
          • ejay-ibmE
            @Cr4z33 Well i’m using it in french … so I don’t think so .
            I need to think a bit why your payload is incorrect.
            Cr4z33C F 2 Replies Last reply
            • Cr4z33C
              Cr4z33 @ejay-ibm
              @ejay-ibm sure take your time mate as I might probably not resume testing before tomorrow afternoon. ;)
              • F
                F17MC @ejay-ibm
                @ejay-ibm I thought your module only works to play/stop/next/previous. I have tried run “Bob Marley Spotify” and nothing happens. With other artist the same.
                If I can test something…
                Pd: Spanish + Spotify premium
                • ejay-ibmE
                  ejay-ibm Project Sponsor Module Developer @F17MC
                  @F17MC @Cr4z33
                  I don’t think the issue is with the module but with what the assistant return to the module .
                  the module is expecting something like “”(open.spotify.com - https://open.spotify.com/artist/2Gkz5N7rWiCE3jlCgsw1yp""
                  So i’m not getting why your assistant doesn’t understand what to search for.
                  I’ll continue digging
                  Ejay
                  Cr4z33C 1 Reply Last reply
                  • Cr4z33C
                    Cr4z33 @ejay-ibm
                    @ejay-ibm OK thanks I might ask also @Sean tomorrow to see if he knows anything we don’t. :D
                    • ejay-ibmE
                      @Cr4z33 I’m already working on it with @Sean ;)
                      quick question : if you just say “micheal jackson smooth criminal”
                      does it start playing youtube ?
                      if yes then just try “micheal jackson smooth criminal spotify”
                      and let me know
                      If that doesn’t work I’ll ask you some patience so I can implement the spotify search function directly in my module and not from the assistant. We will just use a hook in the assisant .
                      Ejay
                      F Cr4z33C 2 Replies Last reply
                      • F
                        F17MC @ejay-ibm
                        @ejay-ibm yes, with YouTube it works. But with Spotify no. I try with “artist + song Spotify”, “artist + song on Spotify” etc. Always run the video in YouTube.
                        • ejay-ibmE
                          @F17MC That is interesting … that mean the result of the assistant research never bring a spotify url but a youtube one . a openspotify url is what the module expect to work .
                          So we know now that under some circumpstance the module doesn’t get the right payload from assistant to work.
                          Thanks for testing and reporting this guys .
                          I’ll work with sean to implement a search function directly with the spotify APIs call . With that we will make the search directly on spotify ( and not on google ) so we will bypass this issue .
                          I’m wondering where the difference is between you and I, because it work fine here and as well another German guy Mantha who is the original code creator .
                          Anyway, there’s no problem … only solution .
                          I’ll keep you informed once the module is updated .
                          Ejay .
                          F 1 Reply Last reply
                          • F
                            F17MC @ejay-ibm
                            @ejay-ibm
                            I tried again and I receive this:
                            [AMK2] end-of-utterance
                            [AMK2] Transcription: los planetas Spotify  --- Done: true
                            [AMK2] openSpotify found: https://open.spotify.com/artist/0N1TIXCk9Q9JbEPXQDclEL
                            { requestId: '5c8b16da-0000-2878-a45c-...' } { profileFile: 'default.json', lang: 'es-ES' }
                            [AMK2] Device Action: { requestId: '5c8b16da-0000-2878-a45c-...' }
                            [AMK2] Assistant Text Response:
                            [HOTWORD] begins listening.
                            Refreshed access token because it has expired. Expired at: 11:26:53 now is: 11:27:56
                            Error while refreshing:
                            { StatusCodeError: 404 - {"error":{"status":404,"message":"Device not found"}}
                                at new StatusCodeError (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request-promise-core/lib/errors.js:32:15)
                                at Request.plumbing.callback (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request-promise-core/lib/plumbing.js:104:33)
                                at Request.RP$callback [as _callback] (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request-promise-core/lib/plumbing.js:46:31)
                                at Request.self.callback (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request/request.js:185:22)
                                at emitTwo (events.js:126:13)
                                at Request.emit (events.js:214:7)
                                at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request/request.js:1161:10)
                                at emitOne (events.js:116:13)
                                at Request.emit (events.js:211:7)
                                at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request/request.js:1083:12)
                              statusCode: 404,
                              message: '404 - {"error":{"status":404,"message":"Device not found"}}',
                              error: { error: { status: 404, message: 'Device not found' } },
                              options:
                               { url: 'https://api.spotify.com/v1/me/player/play',
                                 body:
                                  { context_uri: 'spotify:artist:0N1TIXCk9Q9JbEPXQDclEL',
                                    position_ms: 0 },
                                 qs: { device_id: 'a8caee9b12196a964f5a...' },
                                 headers:
                                  { Authorization: 'Bearer BQDuIGXWvxdIB5T...' },
                                 json: true,
                                 method: 'PUT',
                                 callback: [Function: RP$callback],
                                 transform: undefined,
                                 simple: true,
                                 resolveWithFullResponse: false,
                                 transform2xxOnly: false },
                              response:
                               IncomingMessage {
                                 _readableState:
                                  ReadableState {
                                    objectMode: false,
                                    highWaterMark: 16384,
                                    buffer: [Object],
                                    length: 0,
                                    pipes: null,
                                    pipesCount: 0,
                                    flowing: true,
                                    ended: true,
                                    endEmitted: true,
                                    reading: false,
                                    sync: true,
                                    needReadable: false,
                                    emittedReadable: false,
                                    readableListening: false,
                                    resumeScheduled: false,
                                    destroyed: false,
                                    defaultEncoding: 'utf8',
                                    awaitDrain: 0,
                                    readingMore: false,
                                    decoder: null,
                                    encoding: null },
                                 readable: false,
                                 domain: null,
                                 _events:
                                  { end: [Array],
                                    close: [Array],
                                    data: [Function],
                                    error: [Function] },
                                 _eventsCount: 4,
                                 _maxListeners: undefined,
                                 socket:
                                  TLSSocket {
                                    _tlsOptions: [Object],
                                    _secureEstablished: true,
                                    _securePending: false,
                                    _newSessionPending: false,
                                    _controlReleased: true,
                                    _SNICallback: null,
                                    servername: null,
                                    npnProtocol: false,
                                    alpnProtocol: false,
                                    authorized: true,
                                    authorizationError: null,
                                    encrypted: true,
                                    _events: [Object],
                                    _eventsCount: 9,
                                    connecting: false,
                                    _hadError: false,
                                    _handle: null,
                                    _parent: null,
                                    _host: 'api.spotify.com',
                                    _readableState: [Object],
                                    readable: false,
                                    domain: null,
                                    _writableState: [Object],
                                    writable: false,
                                    allowHalfOpen: false,
                                    _bytesDispatched: 479,
                                    _sockname: null,
                                    _pendingData: null,
                                    _pendingEncoding: '',
                                    server: undefined,
                                    _server: null,
                                    ssl: null,
                                    _requestCert: true,
                                    _rejectUnauthorized: true,
                                    parser: null,
                                    _httpMessage: [Object],
                                    read: [Function],
                                    _consuming: true,
                                    _idleNext: null,
                                    _idlePrev: null,
                                    _idleTimeout: -1,
                                    [Symbol(asyncId)]: 7397,
                                    [Symbol(bytesRead)]: 555 },
                                 connection:
                                  TLSSocket {
                                    _SNICallback: null,
                                    servername: null,
                                    npnProtocol: false,
                                    authorized: true,
                                    encrypted: true,
                                    _events: [Object],
                                    _eventsCount: 9,
                                    connecting: false,
                                    _hadError: false,
                                    _handle: null,
                                    _parent: null,
                                    readable: false,
                                    domain: null,
                                    writable: false,
                                    _sockname: null,
                                    _pendingData: null,
                                    server: undefined,
                                    _server: null,
                                    ssl: null,
                                    _requestCert: true,
                                    parser: null,
                                    read: [Function],
                                    _consuming: true,
                                    _idleNext: null,
                                    _idlePrev: null,
                                    _idleTimeout: -1,
                                 httpVersionMajor: 1,
                                 httpVersionMinor: 1,
                                 httpVersion: '1.1',
                                 complete: true,
                                 headers:
                                  { 'content-type': 'application/json; charset=utf-8',
                                    'cache-control': 'private, max-age=0',
                                    'access-control-allow-origin': '*',
                                    'access-control-allow-headers': 'Accept, Authorization, Origin, Content-Type, Retry-After',
                                    'access-control-allow-methods': 'GET, POST, OPTIONS, PUT, DELETE, PATCH',
                                    'access-control-allow-credentials': 'true',
                                    'access-control-max-age': '604800',
                                    'content-length': '76',
                                    date: 'Fri, 15 Mar 2019 10:27:56 GMT',
                                    via: '1.1 google',
                                    'alt-svc': 'clear',
                                    connection: 'close' },
                                 rawHeaders:
                                  [ 'Content-Type',
                                    'Cache-Control',
                                    'Access-Control-Allow-Origin',
                                    'Access-Control-Allow-Headers',
                                    'Access-Control-Allow-Methods',
                                    'Access-Control-Allow-Credentials',
                                    'true',
                                    'Access-Control-Max-Age',
                                    '604800',
                                    'Content-Length',
                                    '76',
                                    'Date',
                                    'Via',
                                    '1.1 google',
                                    'Alt-Svc',
                                    'clear',
                                    'Connection',
                                    'close' ],
                                 trailers: {},
                                 rawTrailers: [],
                                 upgrade: false,
                                 url: '',
                                 method: null,
                                 statusCode: 404,
                                 statusMessage: 'Not Found',
                                 client:
                                  TLSSocket {
                                    _SNICallback: null,
                                    servername: null,
                                    npnProtocol: false,
                                    authorized: true,
                                    encrypted: true,
                                    _events: [Object],
                                    _eventsCount: 9,
                                    connecting: false,
                                    _hadError: false,
                                    _handle: null,
                                    _parent: null,
                                    readable: false,
                                    domain: null,
                                    writable: false,
                                    _sockname: null,
                                    _pendingData: null,
                                    server: undefined,
                                    _server: null,
                                    ssl: null,
                                    _requestCert: true,
                                    parser: null,
                                    read: [Function],
                                    _consuming: true,
                                    _idleNext: null,
                                    _idlePrev: null,
                                    _idleTimeout: -1,
                                 _consuming: true,
                                 _dumped: false,
                                 req:
                                  ClientRequest {
                                    domain: null,
                                    _events: [Object],
                                    _eventsCount: 5,
                                    output: [],
                                    outputEncodings: [],
                                    outputCallbacks: [],
                                    outputSize: 0,
                                    writable: true,
                                    _last: true,
                                    upgrading: false,
                                    chunkedEncoding: false,
                                    shouldKeepAlive: false,
                                    useChunkedEncodingByDefault: true,
                                    sendDate: false,
                                    _removedConnection: false,
                                    _removedContLen: false,
                                    _removedTE: false,
                                    _contentLength: null,
                                    _hasBody: true,
                                    _trailer: '',
                                    finished: true,
                                    _headerSent: true,
                                    socket: [Object],
                                    connection: [Object],
                                    _header: 'PUT /v1/me/player/play?device_id=a8caee9b1219... HTTP/1.1\r\nAuthorization: Bearer BQDuIGXWvxdIB5TBbyg...\r\nhost: api.spotify.com\r\naccept: application/json\r\ncontent-type: application/json\r\ncontent-length: 71\r\nConnection: close\r\n\r\n',
                                    _onPendingData: [Function: noopPendingOutput],
                                    agent: [Object],
                                    socketPath: undefined,
                                    timeout: undefined,
                                    method: 'PUT',
                                    path: '/v1/me/player/play?device_id=a8caee9b12196...',
                                    _ended: true,
                                    res: [Circular],
                                    aborted: undefined,
                                    timeoutCb: null,
                                    upgradeOrConnect: false,
                                    parser: null,
                                    maxHeadersCount: null,
                                    [Symbol(outHeadersKey)]: [Object] },
                                 request:
                                  Request {
                                    domain: null,
                                    _events: [Object],
                                    _eventsCount: 5,
                                    body: '{"context_uri":"spotify:artist:0N1TIXCk9Q9JbEPXQDclEL","position_ms":0}',
                                    headers: [Object],
                                    method: 'PUT',
                                    readable: true,
                                    writable: true,
                                    explicitMethod: true,
                                    _qs: [Object],
                                    _auth: [Object],
                                    _oauth: [Object],
                                    _multipart: [Object],
                                    _redirect: [Object],
                                    _tunnel: [Object],
                                    _rp_resolve: [Function],
                                    _rp_reject: [Function],
                                    _rp_promise: [Object],
                                    _rp_callbackOrig: undefined,
                                    callback: [Function],
                                    _rp_options: [Object],
                                    setHeader: [Function],
                                    hasHeader: [Function],
                                    getHeader: [Function],
                                    removeHeader: [Function],
                                    localAddress: undefined,
                                    pool: {},
                                    dests: [],
                                    __isRequestRequest: true,
                                    _callback: [Function: RP$callback],
                                    uri: [Object],
                                    proxy: null,
                                    tunnel: true,
                                    setHost: true,
                                    originalCookieHeader: undefined,
                                    _disableCookies: true,
                                    _jar: undefined,
                                    port: 443,
                                    url: [Object],
                                    _json: true,
                                    httpModule: [Object],
                                    agentClass: [Object],
                                    agent: [Object],
                                    _started: true,
                                    href: 'https://api.spotify.com/v1/me/player/play?device_id=a8caee9b12196a96...',
                                    req: [Object],
                                    ntick: true,
                                    response: [Circular],
                                    originalHost: 'api.spotify.com',
                                    originalHostHeaderName: 'host',
                                    responseContent: [Circular],
                                    _destdata: true,
                                    _ended: true,
                                    _callbackCalled: true },
                                 toJSON: [Function: responseToJSON],
                                 caseless: Caseless { dict: [Object] },
                                 read: [Function],
                                 body: { error: [Object] } } }
                            The result is perfect.
                            But I get error 404, Device not found. I try while I listen to music on my laptop and my magic mirror with raspotify, and I get the same error.
                            I have edit my deviceID and my Authorization in the code for privacy.
                            EDIT:
                            I think I know what is the problem.
                            I have tried with two devices, and it don’t work. But when I try it with the device which is the deviceID that I wrote in the module code, it works.
                            If I don’t say a command before, I get error 404.
                            Working:
                            [AMK2] Transcription: para la música  --- Done: true
                            { requestId: '5c883e4a-0000-24fa-b7be-...' } { profileFile: 'default.json', lang: 'es-ES' }
                            [AMK2] Device Action: { requestId: '5c883e4a-0000-24fa-b7be-...' }
                            [AMK2] Conversation Completed
                            Refreshed access token because it has expired. Expired at: 11:45:40 now is: 11:48:02
                            [HOTWORD] <<  espejito  >> is detected. //My hotword
                            [HOTWORD] stops listening
                            [AMK2] assistant ready
                            [AMK2] Conversation starts.
                            [AMK2] Transcription: Rafa Pons en Spotify  --- Done: true
                            [AMK2] openSpotify found: https://open.spotify.com/artist/0DnmOp2SUaeavTi6a32pGY
                            { requestId: '5c884094-0000-27db-94c8-...' } { profileFile: 'default.json', lang: 'es-ES' }
                            [AMK2] Device Action: { requestId: '5c884094-0000-27db-94c8-...' }
                            play on: a8caee9b12196a964f5a9b0fafaf7ef1
                            • ejay-ibmE
                              @F17MC
                              So in your config.js you have set your device id to ; a8caee9b12196a964f5a9b0fafaf7ef1
                              at this step
                              { StatusCodeError: 404 - {“error”:{“status”:404,“message”:“Device not found”}}
                              currentDeviceID variable is passed by case ‘PLAY_SPOTIFY’:
                              payload[“deviceId”] = this.config.deviceId;
                              "If I don’t say a command before, I get error 404. " what do you mean ? could you clarify ?
                              “But when I try it with the device which is the deviceID that I wrote in the module code, it works.”
                              Yes that is expected .
                              For now you can only start playing on the device ID given in the config file as mentioned in the readme :
                              This Module allow to control Spotify player on your Mirror . For now you can only control a single device. It could be your mirror if you are running Raspotify on it. Request to play a song it will be played on your select device in the config.js file. other command doesn’t need a device to be set. So if you are already playing a song on another device, the modules allow you to control this device from your module. But if you request a new song or playlist the set device in config file will play it on it you can not start a new song on a different device from now .
                              Does that clarify the point ?
                              Ejay
                              • F
                                F17MC @ejay-ibm
                                @ejay-ibm said in MMM-SpotifyControl . Control your Spotify music player using Mk2 assistant.:
                                @F17MC
                                at this step
                                Ejay
                                I wanted to erase this sentence but I could not edit my post. It should not be there.
                                Yes, the module is working perfect now!
                                Thanks.
                                • ejay-ibmE
                                  Fantastic news !
                                  So just for other user.
                                  Could you clarify what you did wrong earlier ? and what you changed to make it work ?
                                  Any special sentence to call the module ? any change in config file ?
                                  thank you
                                  • F
                                    F17MC @ejay-ibm
                                    @ejay-ibm
                                    I really want the module to control only one device. I configured that device in the configuration file, but then used the magicmirror as an output device. Then that was the error.
                                    I started disabling youtube and its automatic playback of mmm-assistantmk2, but then I turned it back on.
                                    A doubt. As I really only want to control a device with your module, I could do that if, for example, I’m listening to spotify on my computer, but I say to magicmirror: “start music on spotify” make the change directly to the deviceID that I have in the config file and start the music?
                                    • ejay-ibmE
                                      @F17MC said in MMM-SpotifyControl . Control your Spotify music player using Mk2 assistant.:
                                      Yes That is correct .
                                      BUT
                                      in all the API call i’m using the device is optional .
                                      If you want to control only one device that is the current playing device you can comment line 216 of /core/SpotifyConnector.js
                                      That way you don’t pass the device ID to the api.
                                      that should work
                                      The only condition for this to work is you must have an active device.
                                      The constraint is that if you want to play a song on your mirror, then you have to select it manually as a device from the spotify app.
                                      hope this helps.
                                      Ejay
                                      • Cr4z33C
                                        Cr4z33 @ejay-ibm
                                        and let me know
                                        Ejay
                                        Look there might be some misunderstanding because I NEVER configured something in MagicMirror to be able to run YouTube. :smiling_face_with_open_mouth_cold_sweat:
                                        In fact the sentence ‘michael jackson smooth criminal’ brings me always to the voice GA reply ‘I am sorry, but I don’t know how to help you’.
                                        • ejay-ibmE
                                          @Cr4z33
                                          Then That is maybe your issue . Youtube should work by default . nothing to configure .
                                          If your GA doesn’t bring you a youtube video when you say ‘michael jackson smooth criminal’ then I guess that explain why it doesn’t work as well for spotify .
                                          Anyway we are working with sean to rebuild this module completely and so we should get rid of this issue .
                                          Please be patient and wait for the update ;)
                                          Ejay
                                          • Cr4z33C
                                            Cr4z33 @ejay-ibm
                                            @ejay-ibm huh really?
                                            Can you then please link me where is it mentioned that MagicMirror or MMM-AssistantMk2 has embedded YouTube playing? :hushed_face:
                                            I have never seen that.
