    MMM-SpotifyControl . Control your Spotify music player using Mk2 assistant.
    38 Posts 4 Posters 19.6k Views 9 Watching
    • ejay-ibmE Offline
      ejay-ibm Project Sponsor Module Developer @F17MC
      @F17MC @Cr4z33
      I don’t think the issue is with the module but with what the assistant return to the module .
      the module is expecting something like “”(open.spotify.com - https://open.spotify.com/artist/2Gkz5N7rWiCE3jlCgsw1yp""
      So i’m not getting why your assistant doesn’t understand what to search for.
      I’ll continue digging
      Ejay
      Cr4z33C 1 Reply Last reply Reply Quote 1
      • Cr4z33C Offline
        Cr4z33 @ejay-ibm
        @ejay-ibm OK thanks I might ask also @Sean tomorrow to see if he knows anything we don’t. :D
        ejay-ibmE 1 Reply Last reply Reply Quote 0
        • ejay-ibmE Offline
          ejay-ibm Project Sponsor Module Developer @Cr4z33
          @Cr4z33 I’m already working on it with @Sean ;)
          quick question : if you just say “micheal jackson smooth criminal”
          does it start playing youtube ?
          if yes then just try “micheal jackson smooth criminal spotify”
          and let me know
          If that doesn’t work I’ll ask you some patience so I can implement the spotify search function directly in my module and not from the assistant. We will just use a hook in the assisant .
          Ejay
          F Cr4z33C 2 Replies Last reply Reply Quote 0
          • F Offline
            F17MC @ejay-ibm
            @ejay-ibm yes, with YouTube it works. But with Spotify no. I try with “artist + song Spotify”, “artist + song on Spotify” etc. Always run the video in YouTube.
            • ejay-ibmE Offline
              @F17MC That is interesting … that mean the result of the assistant research never bring a spotify url but a youtube one . a openspotify url is what the module expect to work .
              So we know now that under some circumpstance the module doesn’t get the right payload from assistant to work.
              Thanks for testing and reporting this guys .
              I’ll work with sean to implement a search function directly with the spotify APIs call . With that we will make the search directly on spotify ( and not on google ) so we will bypass this issue .
              I’m wondering where the difference is between you and I, because it work fine here and as well another German guy Mantha who is the original code creator .
              Anyway, there’s no problem … only solution .
              I’ll keep you informed once the module is updated .
              Ejay .
              • F Offline
                F17MC @ejay-ibm
                @ejay-ibm
                I tried again and I receive this:
                [AMK2] end-of-utterance
                [AMK2] Transcription: los planetas Spotify  --- Done: true
                [AMK2] openSpotify found: https://open.spotify.com/artist/0N1TIXCk9Q9JbEPXQDclEL
                { requestId: '5c8b16da-0000-2878-a45c-...' } { profileFile: 'default.json', lang: 'es-ES' }
                [AMK2] Device Action: { requestId: '5c8b16da-0000-2878-a45c-...' }
                [AMK2] Assistant Text Response:
                [HOTWORD] begins listening.
                Refreshed access token because it has expired. Expired at: 11:26:53 now is: 11:27:56
                Error while refreshing:
                { StatusCodeError: 404 - {"error":{"status":404,"message":"Device not found"}}
                    at new StatusCodeError (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request-promise-core/lib/errors.js:32:15)
                    at Request.plumbing.callback (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request-promise-core/lib/plumbing.js:104:33)
                    at Request.RP$callback [as _callback] (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request-promise-core/lib/plumbing.js:46:31)
                    at Request.self.callback (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request/request.js:185:22)
                    at emitTwo (events.js:126:13)
                    at Request.emit (events.js:214:7)
                    at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request/request.js:1161:10)
                    at emitOne (events.js:116:13)
                    at Request.emit (events.js:211:7)
                    at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-SpotifyControl/node_modules/request/request.js:1083:12)
                  statusCode: 404,
                  message: '404 - {"error":{"status":404,"message":"Device not found"}}',
                  error: { error: { status: 404, message: 'Device not found' } },
                  options:
                   { url: 'https://api.spotify.com/v1/me/player/play',
                     body:
                      { context_uri: 'spotify:artist:0N1TIXCk9Q9JbEPXQDclEL',
                        position_ms: 0 },
                     qs: { device_id: 'a8caee9b12196a964f5a...' },
                     headers:
                      { Authorization: 'Bearer BQDuIGXWvxdIB5T...' },
                     json: true,
                     method: 'PUT',
                     callback: [Function: RP$callback],
                     transform: undefined,
                     simple: true,
                     resolveWithFullResponse: false,
                     transform2xxOnly: false },
                  response:
                   IncomingMessage {
                     _readableState:
                      ReadableState {
                        objectMode: false,
                        highWaterMark: 16384,
                        buffer: [Object],
                        length: 0,
                        pipes: null,
                        pipesCount: 0,
                        flowing: true,
                        ended: true,
                        endEmitted: true,
                        reading: false,
                        sync: true,
                        needReadable: false,
                        emittedReadable: false,
                        readableListening: false,
                        resumeScheduled: false,
                        destroyed: false,
                        defaultEncoding: 'utf8',
                        awaitDrain: 0,
                        readingMore: false,
                        decoder: null,
                        encoding: null },
                     readable: false,
                     domain: null,
                     _events:
                      { end: [Array],
                        close: [Array],
                        data: [Function],
                        error: [Function] },
                     _eventsCount: 4,
                     _maxListeners: undefined,
                     socket:
                      TLSSocket {
                        _tlsOptions: [Object],
                        _secureEstablished: true,
                        _securePending: false,
                        _newSessionPending: false,
                        _controlReleased: true,
                        _SNICallback: null,
                        servername: null,
                        npnProtocol: false,
                        alpnProtocol: false,
                        authorized: true,
                        authorizationError: null,
                        encrypted: true,
                        _events: [Object],
                        _eventsCount: 9,
                        connecting: false,
                        _hadError: false,
                        _handle: null,
                        _parent: null,
                        _host: 'api.spotify.com',
                        _readableState: [Object],
                        readable: false,
                        domain: null,
                        _writableState: [Object],
                        writable: false,
                        allowHalfOpen: false,
                        _bytesDispatched: 479,
                        _sockname: null,
                        _pendingData: null,
                        _pendingEncoding: '',
                        server: undefined,
                        _server: null,
                        ssl: null,
                        _requestCert: true,
                        _rejectUnauthorized: true,
                        parser: null,
                        _httpMessage: [Object],
                        read: [Function],
                        _consuming: true,
                        _idleNext: null,
                        _idlePrev: null,
                        _idleTimeout: -1,
                        [Symbol(asyncId)]: 7397,
                        [Symbol(bytesRead)]: 555 },
                     connection:
                      TLSSocket {
                        _SNICallback: null,
                        servername: null,
                        npnProtocol: false,
                        authorized: true,
                        encrypted: true,
                        _events: [Object],
                        _eventsCount: 9,
                        connecting: false,
                        _hadError: false,
                        _handle: null,
                        _parent: null,
                        readable: false,
                        domain: null,
                        writable: false,
                        _sockname: null,
                        _pendingData: null,
                        server: undefined,
                        _server: null,
                        ssl: null,
                        _requestCert: true,
                        parser: null,
                        read: [Function],
                        _consuming: true,
                        _idleNext: null,
                        _idlePrev: null,
                        _idleTimeout: -1,
                     httpVersionMajor: 1,
                     httpVersionMinor: 1,
                     httpVersion: '1.1',
                     complete: true,
                     headers:
                      { 'content-type': 'application/json; charset=utf-8',
                        'cache-control': 'private, max-age=0',
                        'access-control-allow-origin': '*',
                        'access-control-allow-headers': 'Accept, Authorization, Origin, Content-Type, Retry-After',
                        'access-control-allow-methods': 'GET, POST, OPTIONS, PUT, DELETE, PATCH',
                        'access-control-allow-credentials': 'true',
                        'access-control-max-age': '604800',
                        'content-length': '76',
                        date: 'Fri, 15 Mar 2019 10:27:56 GMT',
                        via: '1.1 google',
                        'alt-svc': 'clear',
                        connection: 'close' },
                     rawHeaders:
                      [ 'Content-Type',
                        'Cache-Control',
                        'Access-Control-Allow-Origin',
                        'Access-Control-Allow-Headers',
                        'Access-Control-Allow-Methods',
                        'Access-Control-Allow-Credentials',
                        'true',
                        'Access-Control-Max-Age',
                        '604800',
                        'Content-Length',
                        '76',
                        'Date',
                        'Via',
                        '1.1 google',
                        'Alt-Svc',
                        'clear',
                        'Connection',
                        'close' ],
                     trailers: {},
                     rawTrailers: [],
                     upgrade: false,
                     url: '',
                     method: null,
                     statusCode: 404,
                     statusMessage: 'Not Found',
                     client:
                      TLSSocket {
                        _SNICallback: null,
                        servername: null,
                        npnProtocol: false,
                        authorized: true,
                        encrypted: true,
                        _events: [Object],
                        _eventsCount: 9,
                        connecting: false,
                        _hadError: false,
                        _handle: null,
                        _parent: null,
                        readable: false,
                        domain: null,
                        writable: false,
                        _sockname: null,
                        _pendingData: null,
                        server: undefined,
                        _server: null,
                        ssl: null,
                        _requestCert: true,
                        parser: null,
                        read: [Function],
                        _consuming: true,
                        _idleNext: null,
                        _idlePrev: null,
                        _idleTimeout: -1,
                     _consuming: true,
                     _dumped: false,
                     req:
                      ClientRequest {
                        domain: null,
                        _events: [Object],
                        _eventsCount: 5,
                        output: [],
                        outputEncodings: [],
                        outputCallbacks: [],
                        outputSize: 0,
                        writable: true,
                        _last: true,
                        upgrading: false,
                        chunkedEncoding: false,
                        shouldKeepAlive: false,
                        useChunkedEncodingByDefault: true,
                        sendDate: false,
                        _removedConnection: false,
                        _removedContLen: false,
                        _removedTE: false,
                        _contentLength: null,
                        _hasBody: true,
                        _trailer: '',
                        finished: true,
                        _headerSent: true,
                        socket: [Object],
                        connection: [Object],
                        _header: 'PUT /v1/me/player/play?device_id=a8caee9b1219... HTTP/1.1\r\nAuthorization: Bearer BQDuIGXWvxdIB5TBbyg...\r\nhost: api.spotify.com\r\naccept: application/json\r\ncontent-type: application/json\r\ncontent-length: 71\r\nConnection: close\r\n\r\n',
                        _onPendingData: [Function: noopPendingOutput],
                        agent: [Object],
                        socketPath: undefined,
                        timeout: undefined,
                        method: 'PUT',
                        path: '/v1/me/player/play?device_id=a8caee9b12196...',
                        _ended: true,
                        res: [Circular],
                        aborted: undefined,
                        timeoutCb: null,
                        upgradeOrConnect: false,
                        parser: null,
                        maxHeadersCount: null,
                        [Symbol(outHeadersKey)]: [Object] },
                     request:
                      Request {
                        domain: null,
                        _events: [Object],
                        _eventsCount: 5,
                        body: '{"context_uri":"spotify:artist:0N1TIXCk9Q9JbEPXQDclEL","position_ms":0}',
                        headers: [Object],
                        method: 'PUT',
                        readable: true,
                        writable: true,
                        explicitMethod: true,
                        _qs: [Object],
                        _auth: [Object],
                        _oauth: [Object],
                        _multipart: [Object],
                        _redirect: [Object],
                        _tunnel: [Object],
                        _rp_resolve: [Function],
                        _rp_reject: [Function],
                        _rp_promise: [Object],
                        _rp_callbackOrig: undefined,
                        callback: [Function],
                        _rp_options: [Object],
                        setHeader: [Function],
                        hasHeader: [Function],
                        getHeader: [Function],
                        removeHeader: [Function],
                        localAddress: undefined,
                        pool: {},
                        dests: [],
                        __isRequestRequest: true,
                        _callback: [Function: RP$callback],
                        uri: [Object],
                        proxy: null,
                        tunnel: true,
                        setHost: true,
                        originalCookieHeader: undefined,
                        _disableCookies: true,
                        _jar: undefined,
                        port: 443,
                        url: [Object],
                        _json: true,
                        httpModule: [Object],
                        agentClass: [Object],
                        agent: [Object],
                        _started: true,
                        href: 'https://api.spotify.com/v1/me/player/play?device_id=a8caee9b12196a96...',
                        req: [Object],
                        ntick: true,
                        response: [Circular],
                        originalHost: 'api.spotify.com',
                        originalHostHeaderName: 'host',
                        responseContent: [Circular],
                        _destdata: true,
                        _ended: true,
                        _callbackCalled: true },
                     toJSON: [Function: responseToJSON],
                     caseless: Caseless { dict: [Object] },
                     read: [Function],
                     body: { error: [Object] } } }
                The result is perfect.
                But I get error 404, Device not found. I try while I listen to music on my laptop and my magic mirror with raspotify, and I get the same error.
                I have edit my deviceID and my Authorization in the code for privacy.
                EDIT:
                I think I know what is the problem.
                I have tried with two devices, and it don’t work. But when I try it with the device which is the deviceID that I wrote in the module code, it works.
                If I don’t say a command before, I get error 404.
                Working:
                [AMK2] Transcription: para la música  --- Done: true
                { requestId: '5c883e4a-0000-24fa-b7be-...' } { profileFile: 'default.json', lang: 'es-ES' }
                [AMK2] Device Action: { requestId: '5c883e4a-0000-24fa-b7be-...' }
                [AMK2] Conversation Completed
                Refreshed access token because it has expired. Expired at: 11:45:40 now is: 11:48:02
                [HOTWORD] <<  espejito  >> is detected. //My hotword
                [HOTWORD] stops listening
                [AMK2] assistant ready
                [AMK2] Conversation starts.
                [AMK2] Transcription: Rafa Pons en Spotify  --- Done: true
                [AMK2] openSpotify found: https://open.spotify.com/artist/0DnmOp2SUaeavTi6a32pGY
                { requestId: '5c884094-0000-27db-94c8-...' } { profileFile: 'default.json', lang: 'es-ES' }
                [AMK2] Device Action: { requestId: '5c884094-0000-27db-94c8-...' }
                play on: a8caee9b12196a964f5a9b0fafaf7ef1
                • ejay-ibmE Offline
                  @F17MC
                  So in your config.js you have set your device id to ; a8caee9b12196a964f5a9b0fafaf7ef1
                  at this step
                  { StatusCodeError: 404 - {“error”:{“status”:404,“message”:“Device not found”}}
                  currentDeviceID variable is passed by case ‘PLAY_SPOTIFY’:
                  payload[“deviceId”] = this.config.deviceId;
                  "If I don’t say a command before, I get error 404. " what do you mean ? could you clarify ?
                  “But when I try it with the device which is the deviceID that I wrote in the module code, it works.”
                  Yes that is expected .
                  For now you can only start playing on the device ID given in the config file as mentioned in the readme :
                  This Module allow to control Spotify player on your Mirror . For now you can only control a single device. It could be your mirror if you are running Raspotify on it. Request to play a song it will be played on your select device in the config.js file. other command doesn’t need a device to be set. So if you are already playing a song on another device, the modules allow you to control this device from your module. But if you request a new song or playlist the set device in config file will play it on it you can not start a new song on a different device from now .
                  Does that clarify the point ?
                  Ejay
                  • F Offline
                    F17MC @ejay-ibm
                    @ejay-ibm said in MMM-SpotifyControl . Control your Spotify music player using Mk2 assistant.:
                    @F17MC
                    at this step
                    Ejay
                    I wanted to erase this sentence but I could not edit my post. It should not be there.
                    Yes, the module is working perfect now!
                    Thanks.
                    • ejay-ibmE Offline
                      Fantastic news !
                      So just for other user.
                      Could you clarify what you did wrong earlier ? and what you changed to make it work ?
                      Any special sentence to call the module ? any change in config file ?
                      thank you
                      • F Offline
                        F17MC @ejay-ibm
                        @ejay-ibm
                        I really want the module to control only one device. I configured that device in the configuration file, but then used the magicmirror as an output device. Then that was the error.
                        I started disabling youtube and its automatic playback of mmm-assistantmk2, but then I turned it back on.
                        A doubt. As I really only want to control a device with your module, I could do that if, for example, I’m listening to spotify on my computer, but I say to magicmirror: “start music on spotify” make the change directly to the deviceID that I have in the config file and start the music?
                        • 3 / 4
