    NOAA v3 using too many requests?
    28 Posts 4 Posters 14.9k Views 4 Watching
      motdog @Mykle1
      @Mykle1 I have not changed the update interval Is that in the css? I only have the one module running. What seems weird is that it runs fine then all of the sudden spikes.
      Mykle1M 1 Reply Last reply
        motdog @dazza120
        @dazza120 I am running a Pi 3B the Pi doesn’t lock up. Occasionally if I try to do something a bit funky with a gif in the eye candy module it has but as soon as I use a different gif I am ok.
        D 1 Reply Last reply
          dazza120 @motdog
          @motdog not overclocked? My Pi would still work just ment that it was working overtime doing the weather connection every second.
          M 2 Replies Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @motdog
            @motdog said in NOAA v3 using too many requests?:
            It is in the MMM-NOAA3.js file. Please verify the value. It can also be placed in the config entry which would override the module.js value.
            Have you gotten a new API key?
            Have your deleted you NOAA install and re-installed?
            Have you tried NOAA by itself? No other modules running, or at most just the defaults of MM?
              motdog @dazza120
              @dazza120 no clue.
                motdog @Mykle1
                @Mykle1 I haven’t modified the js file. I did get a new key. One thing I changed at darksky was to limit the number of requests. The default had me at 1000. I lowered it to 750 so I shouldn’t hit the maximum. I’ll give it a few days to monitor. The number of requests stays low most of the time but occasionally spikes up
                • Mykle1M
                  Well, something is causing the module to fetch the data. I do not believe it’s the module itself based on your answers
                    motdog @Mykle1
                    @Mykle1 what should I look for? I had 475 requests today.
                    • Mykle1M
                      @motdog
                      Are you absolutely sure that this is your setting in the config entry?
                      updateInterval: 30 * 60 * 1000,
                      Mykle1M M 2 Replies Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Mykle1
                        @motdog
                        Post your NOAA config entry in a code block please. It should look like this.
                                  disabled: false,
                                  module: 'MMM-NOAA3',
                                  position: 'top_right',
                                      provider: "darksky",
                                      apiKey: "YOUR API KEY",
                                      airKey: "YOUR AIR KEY", // IF you want Air Quality Index
                                      css: "NOAA4",
                                      userlat: "40.123456",
                                      userlon: "-74.123456",
                                      updateInterval: 30 * 60 * 1000,  // VERY IMPORTANT!
                          motdog @Mykle1
                          @Mykle1 from the NOAA3.js
                          Module.register("MMM-NOAA3", {
                              defaults: {
                                  animationSpeed: 0,
                                  initialLoadDelay: 8000,
                                  rotateInterval: 60 * 1000,
                                  apiKey: "",
                                  airKey: "",
                                  pws: "",
                                  css: "",
                                  frow: true,
                          		nupdate: false,
                          		userlat: "",
                          		userlon: "",
                            motdog @Mykle1
                            @Mykle1 from my main config
                            		position: 'bottom_left',
                            			    apiKey: "xxxx",
                            			    airKey: "xxxx",
                            		        css: "NOAA4",
                            			userlat: "38.751389",
                            		        userlon: "-90.565948"
                              motdog @dazza120
                              @dazza120 interesting, Im now up to 600 requests and it locked up.
                              • Mykle1M
                                @motdog
                                Yikes! I’m out of ideas other than to see if this behavior exists when NOAA3 is the only module running. I’m not suggesting that you re-install MM but that is what I would do. Good luck.
                                  motdog @Mykle1
                                  @Mykle1 yeah its crazy. I don’t lock up often and I don’t know if it is a correlation. I may just try a different weather module to see if thats the solution
                                  • Mykle1M
                                    Try one what uses the darksky api key that you have. If the same thing happens then the key is the problem. Keep me posted.
                                      motdog @Mykle1
                                      @Mykle1 will do. I have tried a different key. Weird thing is that the first few days has a small amount of requests then it spikes
